ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless ASUS ZenWiFi ET12 and Pro ET12– Official Thread New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.4.388.21739 2022/11/28 Version 3.0.0.4.388.21739 1. Supported WireGuard VPN server and client. 2. Supported VPN fusion. It can easily achieve VPN connection to network...
Viewing 9 posts - 76 through 84 (of 84 total)
  • #35985
    AvatarIvan Singleton
    • Replies 5
    Looks like Asus pulled the build.  It’s no longer available, or never really was in the first place.
    Main Router: 1 x RT-BE96U merlin FW running 3006.102.3 with 2GB Swap
    aiMesh Nodes: 3 x Zenwifi ET12 Pro running Stock 3.0.0.6.102_36564
    AddOns: AMTM 5.2.1, Skynet 7.6.4, Diversion 5.4.4, scMerlin 2.5.10, MerlinAU 1.4.2, uDivstats 4.0.9, BACKUPMON 1.8.22
    #35986
    • Replies 8,457
    Looks like this build release has been pulled.
    Asus ET12 new firmware 3.0.0.6.102_36382
    byu/rsnhakan inASUS
    #36310
    • Replies 5
    I installed this build from the link posted on SNB and my ET12 mesh is running super solid!  There is NO VLAN support (port assigning) as earlier confirmed, but Guest Network Pro is working with my be96U main router!  It is a huge step up from the last beta 9.0.0.6.102.4856 aside from no longer being able to assign vlans to ports.
    https://www.snbforums.com/threads/asus-zenwifi-pro-et12-firmware-version-3-0-0-6-102_36382-2025-03-12.94094/#post-949068
    #36317
    • Replies 8,457
    Was this “ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.6.102_36382” as this was pulled by ASUS I thought ?
    But good to see stability has improved over previous Beta release.
    #36318
    • Replies 5
    This seems to be newer (3.0.0.6.102_36564) than the one that was pulled.  On the download page it has 9.0.0.6.102_36564 as the id number, but once it is installed has the production build number.  I’m assuming as are other folks that it is a QA build and will be pushed live after final tests, but not sure.  I never know what to expect from Asus, just kind of go with the flow.  It was posted to the Asus Web Storage download on the 20th of March.
    #36320
    • Replies 8,457
    That makes sense, I missed the 9.0.0.6.102_36564 reference, but sounds like ASUS pushing out a quick release.
    Great news the new 9.0.0.6.102_36564 (3.0.0.6.102_36564) is working well and hopefully will be available to all via ASUS download servers with working VLAN shortly
    • This reply was modified 1 year ago by UK SentinelUK Sentinel. Reason: Added VLAN ref
    #37188
    • Replies 8,457
    New ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.6.102_36597
    2025/04/17
    1. Fixed a UI issue in Chrome.
    3. Improved input parameter handling methods to improve data processing stability and system security.
    4. Improved system access control mechanisms.
    5. Improved system stability and security by fixing a kernel integrity check issue.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-pro-et12/helpdesk_bios?model2Name=ASUS-ZenWiFi-Pro-ET12
    #37408
    • Replies 8,457
    Another Quick Release, ASUS ZenWiFi Pro ET12 Firmware version 3.0.0.6.102_36602
    2025/05/05
    • Improved compatibility with certain IoT devices.
    #39939
    • Replies 8,457
    ASUS ZenWIFI Pro ET12 Firmware version 3.0.0.6.102_36637
    2025/10/23
    – Enhanced system stability
    – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
Close ✖
Search forums
Advanced forum search
Back to basic search
