- This topic has 198 replies, 13 voices, and was last updated 2 years, 3 months ago by
March 16, 2019 at 10:42 pm #2388
We do Indeed, just not this time. But what I can see I need to tinker now to get things back on track. Probably more drastic measures required. Kill or cure even I will upload the nvram as soon as I reconfigure my router again to connect to the internet
March 16, 2019 at 11:13 pm #2389March 17, 2019 at 3:28 am #2390March 17, 2019 at 7:41 am #2393March 17, 2019 at 11:57 am #2394This was a nvram log was after a memory clear so the user/pass is not the one I normally use. Mac address I’m not to worried about. If any of the “booji” settings are in their then I can always change things this end.
March 17, 2019 at 11:59 am #2395This was a nvram log was after a memory clear so the user/pass is not the one I normally use. Mac address I’m not to worried about. If any of the “booji” settings are in their then I can always change things this end.
No problem, just thought it best to double check with you ;-)
March 17, 2019 at 2:04 pm #2399OK I’ve only had time for a very quick scan through.
One thing stands out a mile:
model=RT-AC68U
Try entering the following
nvram set model=”RT-AC68U”
nvram set asuscfemodel=”RT-AC68U”
nvram set asuscfecommit=1
nvram commit
Then do a power down reboot
Telnet back in again and do the NVRAM show and check that the model setting has stuck.
March 17, 2019 at 2:06 pm #2401March 17, 2019 at 2:27 pm #2402It must have crept though when I tried to change the router to a RT-AC68U last week to see if it cleared the issue when changing to a DSL-AC68U.
btw should it be
nvram set model=”DSL-AC68U”
nvram set asuscfemodel=”DSL-AC68U”
nvram commit
I wont try anything yet
March 17, 2019 at 2:29 pm #2403If @booji wants to keep his DSL-AC68U as a DSL-AC68U, then he will need to use “DSL-AC68U” instead of “RT-AC68U” with his current firmware (DSL) and check log afterwards as @six spotted reference to RT-AC68U, which should not be there ? (I think) ;-)
March 17, 2019 at 2:41 pm #2404Caught it immediately after I posted it, couldn’t do anything about the email copy that was sent to you.
That setting will not have been changed by flashing the standard firmware, it doesn’t touch it.
March 17, 2019 at 2:45 pm #2406Trouble is its a right pain as only one router, every time I try something the internet drops. The NVram show was from a default settings (apart from telenet enabled) so I will do the mod on that one to see if it sets to the right model.
March 17, 2019 at 2:56 pm #2407March 17, 2019 at 4:35 pm #2414OK another anomaly
odmpid=
this should be
odmpid=DSL-AC68U
UK Sentinel can you check what ‘dsl_enable=’ is set to on a functioning DSL-AC68U?
I’ve not got a full dump of a clean DSL-AC to compare.
March 17, 2019 at 6:07 pm #2415Mine is ( dsl_enable=1 ) and DSL is setup and working, tested it the other day.
Alas my DSL-AC68U is far from clean ;-)
