Sky ipv6 connection Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless Sky ipv6 connection Hey guy’s anyone created ipv6 DNS connection? Am connected via Dns ipv4 via Google domain not through the Asus router though.just created the connection on single device, I have available...
Viewing 15 posts - 16 through 30 (of 39 total)
  • #29292
    AvatarKi11sh0t87
    • Replies 41
    I will tonight pal, when I get in , cheers .
    AvatarKi11sh0t87
    • Replies 41
    I spoken to sky and they said it’s. Static connection.
    • Replies 8,461
    So SKY full fibre uses Static IPv6 for connection type for IPv6
    Learn something new every day I do and thanks for sharing
    #29299
    AvatarKi11sh0t87
    • Replies 41
    Yeh pal apparently,all sky members are static he said that I may have to log back into the sky router account and turn off the firewall on that side first to allow it to connect Asus one .
    • Replies 8,461
    Nice, let us know how it goes as I am sure other SKY Full Fibre customers will find this useful if they are searching online
    #29301
    AvatarKi11sh0t87
    • Replies 41
    Will do pal
    AvatarKi11sh0t87
    • Replies 41
    Right guy’s I know I to do it ... ipv6 only work’s on 5.1ghz and above so never test on 2.1. it’s native.. connection on 64 profix for sky customers
    • Replies 8,461
    I am surprised, I was using BT IPv6 last year before I switched to Plusnet and my ASUS RT-AC86U worked well with IPv6 for both 2.4 and 5 GHz wifi channels including guest wifi.
    if you have time over the next couple of days, I think it might be worth examining how you are setup and configuration etc. especially as you have a couple of XT8 I believe
    #29312
    AvatarKi11sh0t87
    • Replies 41
    That’s how I did it pal, trying to work out to connect DNS but I actually thing most devices don’t have the capability apart from two in my house anyway hahaha
    AvatarKi11sh0t87
    • Replies 41
    Normal DNS is
    ip address
    Gateway
    Prefix
    Dns1
    Dns2
    Is the gateway the same same ipv4 .. I don’t think it is ?
    AvatarKi11sh0t87
    • Replies 41
    Trying to work out the ipv6 DNS sorry.
    AvatarKi11sh0t87
    • Replies 41
    If you set DNS director up does it connect automatically to device you able it to on DHCP settings of the device, would be brilliant if it did saves you adding all the data on static every time
    • Replies 8,461
    It does, DNS Director forces LAN clients by Mac Address to ignore router / dhcp DNS configuration settings and use what you have specified via DNS Director.
    Handy if you want say kids PC to use a family DNS filter (adult content filter), but adults use normal (unfiltered) DNS settings etc.
    #29319
    AvatarKi11sh0t87
    • Replies 41
    Aww brilliant,so if I put the Dns details on director and then connect via lan only is it or work on wireless too??
    AvatarKi11sh0t87
    • Replies 41
    Most test I’ve done ipv4 is still faster than ipv6 which I wouldn’t of thought.but am guessing because most site’s don’t use it
