Viewing 15 posts - 406 through 420 (of 1,130 total)
  • #11741
    qbie
    • Replies 5
    Hi All,
    I wouldn’t mind a copy of the new firmware, just for testing. I’ve been getting quite a few CRC errors on my line lately and been struggling to track down the cause with my ISP (Zen) so this new G.INP setting might be useful.
    I’ve been using a DSL AC-55U for 3 years with no issues until a few weeks back, and I even just purchased a replacement one from Amazon to see if it was the router going faulty, but nope :(
    An unrelated issue that someone might be able to shed some light on (I’ll open a new thread about this if needed) – on my Windows 10 PC that’s hardwired into the router I get random disconnections 2 or 3 times a day. In the router logs it looks like this:
    2021-01-30 12:26:15 kernel: Link State: LAN_4 down.
    2021-01-30 12:26:18 kernel: Link State: LAN_4 up.
    (Where the number changes if I try a different port). In windows it shows as media disconnected then reconnected a couple of seconds later. I can see the logs in the NetworkProfile section of Event Viewer showing network disconnected.
    I’ve now tried two different routers (as the same happens with the new one I got the other day), new cables, different driver versions (it’s a Realtek NIC on my mobo), and I even put in a PCIe NIC and it does the same thing so at this point all I can think of it there’s something running in Windows doing it, but I’m at a loss as to what!
    Ta,
    q
    #11743
    • Replies 8,738
    The latest firmware with the G.inp option (2021_01_19_v9.1.2.3_925-g93a8d29) has been dropped due to issues with the router upgrading firmware automatically, ASUS are working on a fix
    If u could start a new thread for the (2021-01-30 12:26:15 kernel: Link State: LAN_4 down.)  option I can explain what you need to do (hopefully) As I seem to remember my Sons gaming PC having the same issue
    #11807
    • Replies 8,738
    New DSL ASUSWRT Beta firmware v9.1.2.3_928-g26a9f02 now available, this version addressed the Live Update issue you raised earlier plus other bug fixes/ enhancements. Release note will be provided later. Thanks.
    Note: usual UKTH ASUS Beta T&C’s apply, (top of forum)
    2021_02_02_v9.1.2.3_928-g26a9f02
    https://www.asuswebstorage.com/navigate/a/#/s/51D1F1C4F97E4F3DB68A23654F9ED5FAY
    #11808
    byrallier
    • Replies 21
    going to test it
    #11809
    • Replies 8,738
    [quote quote=11808]going to test it[/quote]
    #11826
    AvatarAdnan008
    • Replies 10
    v9.1.2.3_928 on dsl-ac55u didn’t rogue update firmware for 20hr its installed so that’s a good sign :D waiting for changelog
    #11827
    • Replies 8,738
    [quote quote=11826]v9.1.2.3_928 on dsl-ac55u didn’t rogue update firmware for 20hr its installed so that’s a good sign :D waiting for changelog[/quote]
    Good news about no rogue update and I will chase ASUS for changelog
    #11831
    • Replies 8,738
    Changelog as promised:
    – Update help message to ‘G.INP Stability Adjustment’ option
    – Fix the issue that beta firmware is always forced to upgrade
    – Fix the issue that iPhone Airplay cannot continuously connect to Apple TV
    #11838
    Avatarsam
    • Replies 12
    hi,
    still v9.1.2.3_925
    just downloaded 2 times DSL-N55U-C1_v9.1.2.3_928-g26a9f02
    when upload to router it say Invalid firmware then reboot
    before this latest firmware it was only when try live upgrade
    now its not upgrade even when upload
    this is MD5 for trx and zip files
    DSL-N55U-C1_v9.1.2.3_928-g26a9f02.trx
    MD5: 17a8cc869deca4f0fdc0e0131ab8f9a9
    DSL-N55U-C1_v9.1.2.3_928-g26a9f02.Zip
    MD5: 9ec0317fd16b0a996297e7602a6fdbe7
    thanks
    #11839
    • Replies 8,738
    @sam – Understood, hopefully somebody else with a DSL-N55U-C1_v9 can confirm they are also having the same problem with this beta firmware release ?
    #11840
    byrallier
    • Replies 21
    Hey guys, I have a short question. I use Asus ac55u with a VDSL connection and it’s very stable but whenever I restart to the modem, DSL Link is not up quickly. What’s the reason for this situation? Before I bought that modem, I had a more simple modem and it was getting connected in a minute but with this, it takes 3-5 minutes to getting ready the connection. It’s a little bit weird. Is it an expected or configuration issue?
    #11841
    • Replies 8,738
    [quote quote=11840]Hey guys, I have a short question. I use Asus ac55u with a VDSL connection and it’s very stable but whenever I restart to the modem, DSL Link is not up quickly. What’s the reason for this situation? Before I bought that modem, I had a more simple modem and it was getting connected in a minute but with this, it takes 3-5 minutes to getting ready the connection. It’s a little bit weird. Is it an expected or configuration issue?[/quote]
    The DSL-AC55U has only 128 Mb Ram and what would be considered nowadays a low end CPU,  3 – mins does not sound unreasonable to myself.
    #11847
    byrallier
    • Replies 21
    [quote quote=11841]
    The DSL-AC55U has only 128 Mb Ram and what would be considered nowadays a low end CPU, 3 – mins does not sound unreasonable to myself. [/quote]
    I got your point but it doesn’t make sense when I compared it with 10-20$ vdsl modems. That’s the why I am thinking that might be an issue :D
    #11852
    • Replies 8,738
    Understood, hopefully other DSL-AC55U users running this firmware can check also
    #11881
    AvatarAdnan008
    • Replies 10
    your dsl-ac55 is fine, i have similiar issue, it depends on your isp. don’t worry, be happy.
