Viewing 15 posts - 796 through 810 (of 1,130 total)
  • #18019
    AvatarKaan
    • Replies 31
    Of course. I’m using 1.1.2.3_960 firmware with this settings. This firmware really good. Thank you and thank ASUS for this firmware.
    #18020
    • Replies 8,724
    [quote quote=18019]Of course. I’m using 1.1.2.3_960 firmware with this settings. This firmware really good. Thank you and thank ASUS for this firmware.[/quote]
    Good to hear the latest firmware is working well
    #18106
    Jim JetJim Jet
    • Replies 2
    hi and thanks the forum.
    what is the latest firmware for DSL-N55U D1 ;
    #18107
    • Replies 8,724
    The latest Stock firmware for the  DSL-N55U D1 is Version 1.1.2.3_790
    Latest Beta from ASUS is DSL-N55U-D1_v9.1.2.3_959-gce72599
    https://www.asuswebstorage.com/navigate/a/#/s/D5ADA14397F840459F3C7616C7956F36Y
    #18140
    Avatarboyelroy
    • Replies 10
    this vpn problem on fw.959 and 960, whats wrong:
    [Informational] WEB: Configuration changed: LogAccess_ClearLog
    [Informational] kernel: tun: Universal TUN/TAP device driver, 1.6
    [Informational] kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [Informational] kernel: ADDRCONF(NETDEV_UP): tun14: link is not ready
    [Informational] kernel: device tun14 entered promiscuous mode
    [Notice] vpnclient4[5553]: OpenVPN 2.4.11 mips-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 13 2021
    [Notice] vpnclient4[5553]: library versions: OpenSSL 1.1.1e 17 Mar 2020, LZO 2.09
    [Error] vpnclient4[5558]: OpenSSL: error:2406C06E:random number generator:RAND_DRBG_instantiate:error retrieving entropy
    [Error] vpnclient4[5558]: OpenSSL: error:2406B072:random number generator:RAND_DRBG_generate:in error state
    [Error] vpnclient4[5558]: RAND_bytes() failed
    [Error] vpnclient4[5558]: Assertion failed at crypto.c:1811 (rand_bytes(output, len))
    [Notice] vpnclient4[5558]: Exiting due to fatal error
    #18141
    • Replies 8,724
    Did this happen with older firmware versions before fw.959 ?
    The errors reads like the ‘entropy source is not configured properly maybe caused by OpenSSL ‘  ?
    #18153
    Avatarcrc
    • Replies 14
    I also tried the new firmware. By default, they are setting the SNR margin as 15db, and as a result, my bandwidth is around ~80mpbs now, but CRC errors are much lower now (1 minute/CRC to 5 minute/CRC). I’ll try different settings after checking the default ones for 24 hours.
    edit: I’ve noticed that I forgot the update the other trials I’m doing. The disconnection log thing was about TV and PC indeed. When I completely disconnected them, I don’t see the warnings. About the AM radio test, I still couldn’t find an old AM radio but as soon as I find one, I’ll try that one as well.
    #18155
    • Replies 8,724
    Thanks for the update and  feedback
    #18186
    Avatarcrc
    • Replies 14
    Another update: after trying with default settings, the CRC errors went high (around 1 minute/CRC).
    Then, I’ve tried the suggested settings (disable everything except bitswap etc.) while keeping SNR margin as 15db. after 48 hours, CRC was around 2.5 minute/CRC which is acceptable for me.
    As a last trial, I’ll use 8db as the margin to see if it helps to reduce CRC errors (so increasing my bandwidth from 80 Mbps to 100 Mbps). I will update here when I get the results.
    #18188
    • Replies 8,724
    [quote quote=18188] [/quote]
    i returned area:)
    #18204
    • Replies 8,724
    Welcome back
    #18205
    [quote quote=18204]Welcome back [/quote]
    thanks, i changing iss for you :))
    #18222
    Avatarattrib
    • Replies 3
    Hi, I’m having issue using the DNS-O-Matic DDNS for the latest firmware on DSL-AC52U (1.1.2.3_960).
    It fails to update the IP since it redirect to https which it did not support
    https://support.opendns.com/hc/en-us/community/posts/360071971352/comments/360012471952
    I have contact with support previously which provided beta firmware (DSL-AC52U_9.1.2.3_893-gcc8fd6a.trx.zip) that fixes this issue but unfortunately not in this latest version…
    DDNS log snippet:
    <!–more–>
    [Informational] kernel: DDNS Fail retry(5)
    [Informational] kernel: ddns_execute(), interface[ppp100]
    [Notice] ddns update: ez-ipupdate: starting…
    [Notice] ddns update: connected to updates.dnsomatic.com (146.112.255.155) on port 80.
    [Notice] ddns update: unknown return code: 301
    [Notice] ddns update: server response: Moved Permanently
    [Notice] ddns update: asusddns_update: 1
    [Notice] ddns update: exit_main
    [Informational] kernel: Reach DDNS MAX retry times
    Hope that this issue will be fixed, have to revert to the working version for now. Wish ASUS can give options to manually configure the DDNS, instead of choosing pre-defined list.
    #18223
    • Replies 8,724
    I will speak with ASUS and make them aware of the DNS-O-Matic DDNS issue with 1.1.2.3_960
    Can you send a Feedback form using (DSL-AC52U_9.1.2.3_893-gcc8fd6a.trx.zip) firmware explaining this issues with firmware 1.1.2.3_960 and mention ‘UK Sentinel’ at the beginning of message as I can then ask them to look for the feedback form ?
    Let me know when feedback has been sent ?
