Viewing 15 posts - 781 through 795 (of 1,130 total)
  • #17941
    [quote quote=17937]Great news and I think @TSuNaMi will be happy <noscript><noscript></noscript>Just had a look and seems also new stock firmware for …
    • DSL-AC51
    • DSL-N16
    • DSL-AC55U
    [/quote]
    there is crc problem at this version :(
    #17943
    [quote quote=17941]there is crc problem at this version :([/quote]
    Did you try a factory reset ? and what is your SNR (up-down) ?
    #17944
    [quote quote=17943]
    Did you try a factory reset ? and what is your SNR (up-down) ?[/quote]
    yes, i resetted to factory reset with reset button. i use snr margin 5db. I was also using snry 5db in firmware version 959 but I was seeing 24 max 60-70 crc function on it. I just made new settings and 2 crc errors occurred in 30 minutes. Let’s see, after 24 hours, I will write the full results, it seems that there is no problem at the moment.
    #17945
    If you still have high CRC’s maybe worth looking at setting your QoS to 85% of your synch rate to see if that helps reduce CRC’s etc ?
    #17947
    What does CRC have to do with QoS?
    CRC happens on the modulated line independent of load or whatever has to be transmitted.
    I dont say that there cant be an effect but I only want to understand why this could happen or how it may be relevant and related to CRC.
    Possibly chip doesnt work correctly on high load I could assume.
    #17949
    Cyclic Redundancy Check (CRC) Error indicates when data is corrupted which can be caused by any number of factors.
    MediaTeK based modems suffer from High U1 U2 and D1 D2 frequency issues and by reducing frequencies, this can help reduce CRC and FEC etc.
    But, this can also be achieved in part by limiting synch rate, which inturn ensure cab/modem does not run at full synch rate.
    Another option is to force SNR to a higher value as SNR is Signal to Noise Ratio – in other words a measurement in decibels of the Signal strength to the level of Noise on the line.
    QoS to a degree can reduce FEC and CRC by not allowing full data transmission which can overcome errors/issues/congestion on the line/cab etc.
    Trail and error I am afraid
    What would you suggest ?
    #17950
    I dont see any differences while my modems are in sync with no load or full load.
    CRC and/or FEC counters will be at the same level all the time.
    So I think this might be something specific for special chips/modems.
    Of course SNR and used frequencies have direct dependencies to signal quality and so transmission errors.
    #17952
    MediaTeK, 😪
    #17953
    [quote quote=17952]MediaTeK, 😪[/quote]
    no problem left, i got 23 crc error in 14 hours(5db snr margin) . Thank you to Asus and you guys for your hard work for the new firmware.
    tr; herhangi bir sorun kalmadı, 14 saatte 23 crc hatası aldım(5db snr margin) . Asus’a ve emeklerinizden dolayı sizlere yeni firmware için teşekkür ederim.
    [quote quote=17956]
    Best regards
    #17975
    Avatargökhan
    • Replies 6
    Ayarlarını nasıl yaptın sevgili kardeşim paylaşabilir misin…
    (Admin: English Language required )
    “How did you do your settings, can you share my dear brother”
    #18015
    AvatarKaan
    • Replies 31
    My settings is on the screenshot. I’m getting really good performance with this settings. You can change dB value as higher if you don’t have a stable connection. In addition, If you use 5Ghz Use 40mhz because  I got disconnect problem with 80mhz, but 40mhz is perfect for 5GHz.
    #18018
    @Kaan – Thanks for sharing your configuration settings, have you tried the new Version 1.1.2.3_960 ?
