- March 22, 2022 at 10:16 am #18345
Please update the pppd package to version 2.4.9. Because 2.4.7 has serious security vulnerabilities such as CVE-2020-8597
I will ask ASUS to add this request to there list
<noscript>
</noscript>also, can you say for update kernel core? linux image is oldest
Half-Life 1 Server IP: hl.oyunsen.com:27015
We will re-write code of world…
March 22, 2022 at 10:23 am #18346also, can you say for update kernel core? linux image is oldest
What do you mean ‘Linux Image’, do you mean Linux Version from which image/build is created ?
March 22, 2022 at 12:40 pm #18349also, can you say for update kernel core? linux image is oldest
yes, you can mean linux version
March 22, 2022 at 3:55 pm #18352when write
uname -a
command writing 2.6 version.. asus can update this kernel..
March 22, 2022 at 4:00 pm #18353command writing 2.6 version.. asus can update this kernel..
Update Kernel to what version – 5.0.21 ?
March 22, 2022 at 4:40 pm #18354command writing 2.6 version.. asus can update this kernel..
The hardware can be up to whichever version is available.
March 22, 2022 at 5:43 pm #18355For asus ac51, 965 is no longer a problem, I think, it was the 2nd day, as there is no problem, the crc error is quite low.
March 22, 2022 at 5:45 pm #18356For asus ac51, 965 is no longer a problem, I think, it was the 2nd day, as there is no problem, the crc error is quite low.
March 22, 2022 at 5:48 pm #18357The hardware can be up to whichever version is available.
I will have a chat with ASUS, but I realise that is a little more complicated than just upgrading the Kernel, there is commercial/business considerations etc.
March 22, 2022 at 6:04 pm #18358The hardware can be up to whichever version is available.
thanks, we are waiting for positive answers :)
March 23, 2022 at 10:23 am #18359The same problem continues with ASUS AC51 965, all the lights are on, no internet, but after turning it off and on, it is fixed ASUS does not work with turknet in turkey, it is problematic ASUS should take this into account and intervene, but old software is recommended 790 and before, which is dangerous in terms of security.
March 23, 2022 at 2:55 pm #18363The same problem continues with ASUS AC51 965, all the lights are on, no internet, but after turning it off and on, it is fixed ASUS does not work with turknet in turkey, it is problematic ASUS should take this into account and intervene, but old software is recommended 790 and before, which is dangerous in terms of security.
please can you try different modems? i lived same problem at Turknet and i passed Ttkom and problem solved
March 24, 2022 at 10:13 am #18366I would like to give a little information for friends who have internet problems, unfortunately the asus modem is terrible, I have to say that I have been following this forum for a very long time. First of all, I would like to say that you need to find and enter your mtu settings in the asus modem, for example, I have 1452 mtu value fully settled. It worked. But I tried another modem airties 5650, the mtu works perfectly without touching it. If I don’t enter the correct value for Asus ac51 mtu, there is internet but it seems like it doesn’t exist.
internet sorun yaşayan arkadaşlar için ufak bir bilgi vermek isterim ne yazıkki asus modem çok berbat bunu kesinlikle söylemem gerekiyor bu forum çok uzun zamandır takip ediyorum.Öncelikle şunu söylemek istiyorum asus modem de mtu ayarlarınızı size uygun değeri bulup girmeniz gerekiyor mesela bende 1452 mtu değeri tam oturaklı çalıştı.Ama 2. başka modem airties 5650 denedim mtu hiç ellemeden kusursuz çalışıyor.Asus ac51 mtu değeri doğru değeri girmezsem internet var ama yok gibi oluyor
March 24, 2022 at 11:00 am #18367I would like to give a little information for friends who have internet problems, unfortunately the asus modem is terrible, I have to say that I have been following this forum for a very long time. First of all, I would like to say that you need to find and enter your mtu settings in the asus modem, for example, I have 1452 mtu value fully settled. It worked. But I tried another modem airties 5650, the mtu works perfectly without touching it. If I don’t enter the correct value for Asus ac51 mtu, there is internet but it seems like it doesn’t exist.
Welcome and thank you for sharing your good information of MTU 1452 for ASUS modem in Turkey
Can I ask what MTU value is the Airties 5650, for reference ?
March 24, 2022 at 11:25 am #18368I use airties 5650 mtu 1492 without doing anything, but I have to do 1452 for asus dsmart.
airties 5650 mtu 1492 hiçbir işlem yapmadan kullanıyorum ama asus dsmart için 1452 yapmak zorunda kalıyorum.Yoksa internet geliyor gözüküyor ama yok
