› UKTH forums › π§ PC & Laptop Gaming › Gaming Desktops › RAIJINTEK – SFF chassis Opinions – PAEAN MINI A friend has asked my view on the RAIJINTEK chassis – PAEAN MINI as part of a gaming rig setup for around Β£1000 custom build Looks good as far as...
- This topic has 39 replies, 3 voices, and was last updated 4 years, 7 months ago by
December 28, 2021 at 5:23 pm #16863
Well I took a look at the AMD market place and given the budget of Β£1000, AMD comes in nicely with compromises on Graphics cards etc
Motherboard: GIGABYTE B550I Aorus Pro AX Β£170 Gigabyte X570 I AORUS PRO WIFI (AMD AM4) DDR4 X570 Chipset Mini-ITX Motherboard Β£210 CPU: AMD Ryzen 5 5600X Zen 3 CPU Base: 3.7GHz, Turbo: 4.6GHz – 6 Cores, 12 Threads Β£280 AMD Ryzen 7 5800X 8-Core 16-Thread AM4 Unlocked 100-100000063WOF Β£330 AMD Ryzen 9 5900X 12-Core 24-Thread AM4 Unlocked 100-100000061WOF Β£450 RAM: Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200Mhz Β£97 Graphics: MSI GeForce GTX 1050 Ti 4GB LP Graphics Card Β£219 Gigabyte GeForce GTX 1660 SUPER 6GB OC GAMING Graphics Card Β£450 Power Supply: Corsair SF Series, SF450, 450 Watt, Β£82 Corsair SF600 600W SFX Β£100 Drive: Crucial P2 1TB PCIe M.2 2280SS SSD Β£99 SanDisk Ultra 3D SSD 1TB Β£107 Samsung 870 EVO 1TB SATA Β£125 chassis: RAIJINTEK SFF β PAEAN MINI Β£89 You need to login in order to vote
December 28, 2021 at 5:45 pm #16866So the choice is as follows, doesn’t included licenses / CPU heatsink, CD-rom etc, but given budget is a good compromise I believe
Motherboard: Gigabyte X570 I AORUS PRO WIFI (AMD AM4) DDR4 X570 Chipset Mini-ITX Motherboard Β£210 CPU: AMD Ryzen 5 5600X Zen 3 CPU Base: 3.7GHz, Turbo: 4.6GHz β 6 Cores, 12 Threads Β£280 RAM: Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200Mhz Β£97 Graphics: MSI GeForce GTX 1050 Ti 4GB LP Graphics Card Β£219 Power Supply: Corsair SF Series, SF450, 450 Watt, Β£82 Drive: Crucial P2 1TB PCIe M.2 2280SS SSD Β£99 chassis: RAIJINTEK SFF β PAEAN MINI Β£89 You need to login in order to vote
December 29, 2021 at 12:41 am #16867[quote quote=16840]That is what I am finding, prices are way to high. Anything ASUS from a gaming perspective is good, shame about the hybrid HDD /SSD but a good purchase considering the NVIDIA GeForce RTX 3070 is worth Β£700 + on its own . I doubt it will be in stock anytime soon
[/quote]John Lewis said they will order new stock in mid Jan 22.Β If price is close to that I will buy.Β The NVMe SSD and HDD are separate.
December 29, 2021 at 12:42 am #16868[quote quote=16866]So the choice is as follows, doesnβt included licenses / CPU heatsink, CD-rom etc, but given budget is a good compromise I believe
>Motherboard: Gigabyte X570 I AORUS PRO WIFI (AMD AM4) DDR4 X570 Chipset Mini-ITX Motherboard Β£210 CPU: AMD Ryzen 5 5600X Zen 3 CPU Base: 3.7GHz, Turbo: 4.6GHz β 6 Cores, 12 Threads Β£280 RAM: Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200Mhz Β£97 Graphics: MSI GeForce GTX 1050 Ti 4GB LP Graphics Card Β£219 Power Supply: Corsair SF Series, SF450, 450 Watt, Β£82 Drive: Crucial P2 1TB PCIe M.2 2280SS SSD Β£99 chassis: RAIJINTEK SFF β PAEAN MINI Β£89 [/quote]
Great balanced spec in my opinion
December 29, 2021 at 7:57 am #16873[quote quote=16867]John Lewis said they will order new stock in mid Jan 22.Β If price is close to that I will buy.Β The NVMe SSD and HDD are separate.[/quote]
‘The NVMe SSD and HDD are separate’, that is much better,
[quote quote=16868]Great balanced spec in my opinion[/quote]
It was tricky to get a semi good gaming system for around Β£1000, luckily I have a few old PC’s so can scavenge Ribbons, CD drives etc if my friend needs them.
AMD definitely provided better cost savings
December 29, 2021 at 6:51 pm #16875Just noted this via CCLonline for Β£1189 with a decent GPU ? (Radeon RX 6600 XT)
Horizon 5 AMD RX 6600 XT Gaming PC – AMD Ryzen 5 3600 3.6GHz CPU,
https://www.cclonline.com/pc/gaming-pcs/orion/horizon-5-amd-rx-6600-xt-gaming-pc/
December 29, 2021 at 11:02 pm #168786600XT is a better GPU.
Try this website:
https://www.pcspecialist.co.uk/
You can find pre-built and try custom build as well from here:
https://www.pcspecialist.co.uk/computers/amd-am4-gen3-pc/
My current PC is from them
December 30, 2021 at 8:41 am #16880January 26, 2022 at 5:38 pm #17399Just bought this system from Very.Β As I suspected the price went up substantially after coming back in stock.Β It is now Β£1,800 at John Lewis and for Β£1600 from Very.
Bonus was that I had Β£500 Very vouchers applied to the account so ended up paying Β£1,100.
January 26, 2022 at 6:16 pm #17400Very very nice looking rig, shame John Lewis is some Β£200 more than Very,
Case looks very sharp and only noticed a single fan on case, (excluding CPU and GPU) so will be interesting to see if temps are maintained etc.
January 27, 2022 at 9:01 pm #17429Got next day delivery and it got delivered in the morning.
There are actually 2 case fans.Β 1 x 120mm (I think that is the size) in the front and 1 x 80mm at the back.
On first start-up all the the fans are quite audible.Β After entering windows they are whisper quiet on idle.
Nearly damaged the front hot-swappable SSD trays.Β I never knew there are different sized SSD’s?
I had 2 SSD’s and the first one would not fit.Β Tried to jam it in and nearly damaged the SSD and the hot-swappable tray.Β It was near impossible to get the SSD back out.Β Had to use a pliers to remove.
I then tried the other SSD and it just fitted in perfectly.Β Lesson learnt……
January 27, 2022 at 9:24 pm #17431January 27, 2022 at 9:50 pm #17432I got this Dell monitor a while ago directly from Dell with the updated panel for Β£275
January 27, 2022 at 9:56 pm #17435Proper Gaming monitor , very nice
I am still using my old BenQ 27″ monitor, one day I will upgrade also
January 28, 2022 at 9:41 pm #17467This is upgrade upgrade after 10 years.Β The last build was intel i7-3770k where I only upgraded GPU to RTX 2070.
The system has now been given to my son, still plenty fast enough for him coming from an AMD FX8370 and a GTX 1060.
