Asus RT-AC86u Just bought one from Amazon for £160.93p
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asus RT-AC86u Just bought one from Amazon for £160.93p
Viewing 15 posts - 61 through 75 (of 88 total)
  • #1686
    oxygen8
    • Replies 38
    Now, can you put the DrayTeK in bridge mode? and let the RT-AC86U do everything, you won’t need double firewall with the RT-AC86U, and go and grab your RMerlin firmware https://asuswrt.lostrealm.ca/
    #1687
    AvatarMharv
    • Replies 25
    [quote quote=1686]Now, can you put the DrayTeK in bridge mode? and let the RT-AC86U do everything, you won’t need double firewall with the RT-AC86U, and go and grab your RMerlin firmware https://asuswrt.lostrealm.ca/%5B/quote%5D
    modem will be arriving shortly, do you mean the draytek has a firewall built in? i was informed the configuration was auto for the draytek adsl/vdsl… just plug in and away you go, for the ?RMerlin what will it give the router extra…
    #1688
    AvatarMharv
    • Replies 25
    Trying out Purevpn considering i could never get it to work with dsl 88 u piece of junk lol
    using dedicated ip and found the following… netflix will not work says a proxy is being used lol
    BT Sport via Plusnet will not work screen goes black IPC6011 issue… which is  vague
    But Amazon Prime video and music work fine
    Just nice to know software works with settings in router
    #1689
    • Replies 8,737
    [quote quote=1688]Trying out Purevpn considering i could never get it to work with dsl 88 u piece of junk lol using dedicated ip and found the following… netflix will not work says a proxy is being used lol BT Sport via Plusnet will not work screen goes black IPC6011 issue… which is vague But Amazon Prime video and music work fine Just nice to know software works with settings in router[/quote]
    Maybe worth trying RMerlins firmware as he has added some very good work around VPN’s (independent of ASUS)  which maybe more suitable for your needs?
    #1690
    AvatarMharv
    • Replies 25
    Really impressed how you can monitor real time stats from clients and apps on the router showing usage of GB’s in visual format…
    #1691
    • Replies 8,737
    [quote quote=1690]Really impressed how you can monitor real time stats from clients and apps on the router showing usage of GB’s in visual format…[/quote]
    If you look under adaptive QoS, > Bandwidth Monitor, you can spy on what sites users are currently visiting ;)
    #1692
    oxygen8
    • Replies 38
    [quote quote=1687]modem will be arriving shortly, do you mean the draytek has a firewall built in? i was informed the configuration was auto for the draytek adsl/vdsl… just plug in and away you go, for the ?RMerlin what will it give the router extra…[/quote]
    Well, maybe DrayTek doesn’t have a firewall enabled but surely it won’t be in bridge mode by default so you will have double NAT which in your case there is no need, hence I suggest that you set the DrayTek in bridge mode and leave all the routing to the RT-AC86U, but I’m not really sure how is the DrayTek configured by default, I’m guessing using the historical data I have about routers in general.
    That’s how I have it, but in my case my cable modem is in bridge mode so my firewall and NAT is all handled by the Asus router.
    #1693
    oxygen8
    • Replies 38
    Here it is (I hope I have found the router you bought) how to set it to bridge mode:
    https://www.draytek.com/en/faq/faq-connectivity/connectivity.wan/how-to-use-pppoe-pass-through-and-bridge-mode-on-vigor130/
    #1694
    oxygen8
    • Replies 38
    Actually it is quite confusing the way they explain it, if your Asus router has a WAN IP that looks like external then your router is in bridge mode, the idea is to prevent the ADSL from doing the NAT (Network Address Translation) and that it serves as a bridge instead of a router.
    Bridge mode is brainless, in that the router will do no CPU work hence it will be faster, that way it will not be a bottleneck for your RT-AC86U speed if you know what I mean.
    #1695
    AvatarMharv
    • Replies 25
    [quote quote=1693]Here it is (I hope I have found the router you bought) how to set it to bridge mode: https://www.draytek.com/en/faq/faq-connectivity/connectivity.wan/how-to-use-pppoe-pass-through-and-bridge-mode-on-vigor130/[/quote]
    Oxygen8 thanks for the heads up and will do that much appreciated.
    #1696
    AvatarMharv
    • Replies 25
    [quote quote=1694]Actually it is quite confusing the way they explain it, if your Asus router has a WAN IP that looks like external then your router is in bridge mode, the idea is to prevent the ADSL from doing the NAT (Network Address Translation) and that it serves as a bridge instead of a router. Bridge mode is brainless, in that the router will do no CPU work hence it will be faster, that way it will not be a bottleneck for your RT-AC86U speed if you know what I mean.[/quote]
    understand you much more on that cheers.
    #1697
    AvatarMharv
    • Replies 25
    [quote quote=1691]
    If you look under adaptive QoS, > Bandwidth Monitor, you can spy on what sites users are currently visiting 😉[/quote]
    Yes this router is imho a better router than the dsl 88u…
    #1719
    AvatarMharv
    • Replies 25
    Upgraded to RMerlin 384 and really impressed with the extra settings and info available. So far not one problem
    #2533
    Bully
    • Replies 386
    Should I have AiProtection enabled on this router?  I’m worried if I turn it on it will hinder its performance?
    #2534
    • Replies 8,737
    [quote quote=2533]Should I have AiProtection enabled on this router? I’m worried if I turn it on it will hinder its performance?
    [/quote]
    Generally, unless you are using wifi /network for lots of high bandwidth file transfers, better to leave AiProtection enabled, especially if you are worried about the Internet and security etc.
    Mine is also Enabled for my RT-AC86U
