Asus RT-AC86u Just bought one from Amazon for £160.93p
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asus RT-AC86u Just bought one from Amazon for £160.93p
Viewing 15 posts - 1 through 15 (of 88 total)
  • #889
    Bully
    • Replies 386
    #894
    [quote quote=889]Just picked one up from Amazon for £160.93p[/quote]
    I thought you was going for the RT-AC86U? or am I loosing the plot ;)
    #895
    Bully
    • Replies 386
    Miss typed and edited now.
    #898
    [quote quote=895]Miss typed and edited now.[/quote]
    ;-) are you going to flash it with RMerlin firmware, be careful as RMerlin firmware’s does not support AiMesh , only stock ASUSWRT does
    #899
    Bully
    • Replies 386
    [quote quote=898]
    😉 are you going to flash it with RMerlin firmware, be careful as RMerlin firmware’s does not support AiMesh , only stock ASUSWRT does[/quote]
    Yes that is my plan, i will not use AiMesh.
    #901
    Enjoy your new toy and do not forget to disable AirTime Fairness on wifi, this should provide greater wifi connection stability.
    #903
    Bully
    • Replies 386
    [quote quote=901]Enjoy your new toy and do not forget to disable AirTime Fairness on wifi, this should provide greater wifi connection stability.[/quote]
    Thanks.
    It will arrive tomorrow.
    #911
    Bully
    • Replies 386
    Will I be able to access my Draytek Modem via its UI  behind this router without the Merlin FW?
    #913
    [quote quote=911]Will I be able to access my Draytek Modem via its UI behind this router without the Merlin FW?[/quote]
    Yes, should require no further setting up. (I believe)
    Edit: They key is to ensure both Modem and ROUTER are on different IP subnets, I believe the DrayTeK comes figured with the IP address http://192.168.2.1 and the ASUS DSL-AC86U is http://192.168.50.1 which is all that is needed.
    #917
    Bully
    • Replies 386
    Thanks.
    Any tips on getting open NAT on multiple xbox’s?
    #918
    With RMerlin Firmware, ASUSWRT-Merlin support Full Cone NAT and is ideal at supporting multiple Xbox’s / PS etc in OPEN NAT /Nat Type 1
    With ASUS stock Firmware, their NAT is of the Symmetric NAT type, which has its challenges, but from when I used it last, as long as you enable UPnP then this has worked well in the past for multiple Xbox’s (for myself)
    Key I think is not to assign devices, there unique IP addresses and let router handle all that via DHCP etc.
    #940
    Bully
    • Replies 386
    All setup and running well.  currently using std Asus firmware.
    #964
    Bully
    • Replies 386
    My old rt ac66u use to log what time clients connected to the router in the system log, the 86u is not doing this, I have checked if I have to tell it to do this but can’t find anything anywhere in the settings.
    #965
    Was your RT-AC66u running RMerlin firmware ? I assume you are running upto date firmware for your RT-AC86U? (Version 3.0.0.4.384.32799 )
    #966
    Bully
    • Replies 386
    Yes my 66u was running Merlin FW, and yes I am running the latest Asus FW.
