- This topic has 1,438 replies, 106 voices, and was last updated 7 months ago by
alt.james.
November 10, 2021 at 6:27 pm #16151
As far as I am aware, ASUS never got round to fully finishing the DSL-AC88U for a WAN port connection to a separate modem.
adjusting QOS may help, what qos if any are you using ?
November 10, 2021 at 6:31 pm #16152I’m not an expert but I didn’t think this router had many options for QoS. I did try it but turned it back off
November 10, 2021 at 6:36 pm #16153I’m surprised it’s working at all as router, when I had it I couldn’t get it working as router connected to separate modem.
November 10, 2021 at 6:40 pm #16154[quote quote=16153]I’m surprised it’s working at all as router, when I had it I couldn’t get it working as router connected to separate modem.[/quote]
I remember that conversation on this Forum, happy days (not)
November 10, 2021 at 6:41 pm #16155[quote quote=16152]I’m not an expert but I didn’t think this router had many options for QoS. I did try it but turned it back off[/quote]
Alas If QoS is Off and you are still having issues, then unfortunately the DSL-AC88U needs to be replaced, especially if you are a gamer
November 10, 2021 at 7:06 pm #16156There’s 1 thing I want to check although it doesn’t explain the high cpu. But so far In terms of gaming this week, I haven’t had any ping spikes. I want to see if when another computer starts a video call if it affects my PC gaming.
With virgin the upload is 10mbs less.
November 10, 2021 at 7:23 pm #16158[quote quote=16156]There’s 1 thing I want to check although it doesn’t explain the high cpu[/quote]
High CPU is probable due to WAN port running bad (unfinished) code, hence excessive CPU usage .
Edit: Your original shell ISP connection was using DSL-AC88U inbuilt Modem and Router
Your New Virgin connection is only using the DSL-AC88U as Router, hence higher CPU usage due to WAN port problems probable ?
November 11, 2021 at 8:56 am #16165I think this could be the case. I do have an old n56u.
I could try plugging that in and see if the CPU goes high
November 11, 2021 at 11:00 am #16166
the N56U is liked taking a step back in terms of wifi, but good for a test ?
November 12, 2021 at 3:22 pm #16173I tried setting the n56u up. I put automatic wan IP on the quick setup but I’m getting no connection. Am I doing something wrong?
November 12, 2021 at 3:56 pm #16174[quote quote=16173]I tried setting the n56u up. I put automatic wan IP on the quick setup but I’m getting no connection. Am I doing something wrong?[/quote]
Can you start a new Thread for this
March 13, 2022 at 7:24 pm #18251Hello guys
how do you force flash merlin or dd wrt on this dsl ac88u .
dnt care about the modem part any more have a draytek 167 for that. and i got protectli coming for the routing i and the original fw cant do AP only and setting the router to e wan dont some how pic up the isp ip thx guys
March 13, 2022 at 7:44 pm #18254March 13, 2022 at 7:54 pm #18255Alas as the DSL-AC88U uses the Broadcom BCM63138 for its main CPU, there is no ASUSWRT or ASUSWRT-Merlin suitable alternative for this model.
Also, @GNUton produces ASUSWRT-Merlin fork for ASUS DSL modem / router units (DSL-AC68U DSL-AX82U) etc. but not for the DSL-AC88U.
The DSL-AC88U does have a WAN port, so can act as a Router only, but firmware is far from stable.
Even though there is a DD-WRT for the RT-AC88U, the Processor, Wifi and Ethernet Chip are different to that of the DSL-AC88U, so no real joy as far as I am aware.
March 13, 2022 at 7:57 pm #18256 -
