› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc.
- This topic has 1,438 replies, 106 voices, and was last updated 7 months ago by
alt.james.
March 13, 2022 at 8:04 pm #18257March 13, 2022 at 8:23 pm #18258
[quote quote=18257]Thx Guys then il just get a AX AP when my protectcli arrives[/quote]
March 13, 2022 at 9:11 pm #18259It was meant as general guide, if he cant download a Merlin or Gnuton-version it is evident, that he cant change firmware for this router.
March 13, 2022 at 9:27 pm #18260[quote quote=18259]It was meant as general guide, if he cant download a Merlin or Gnuton-version it is evident, that he cant change firmware for this router.
[/quote]
March 14, 2022 at 5:45 am #18262Only Got one regret i should stayed with my old rt ac68u
and bought a seperate modem when i moved .
was using merlin on that one and it was stable af .Then i got this when it came out and nothing but issues .was hoping to be able to set this over to ap mode like on the rt models when i get a proper pfsense box like the vault .
on a seperate question any one know how the draytek 167 stacks up as a router not for wifi only the dhcp part ?and then just double nat wifi stuff for now so i only lose wifi when it locks up
March 14, 2022 at 7:55 am #18265Can purchase an RT-AC68U on Ebay for around £50
I read the 167 is actually using a MediaTeK chipset (EcoNet EN7556N) , and have seen early reports that stability is a concern for some at higher synch rates.
Shame they seem to have moved away from Broadcom/Lantiq DSL chipsets
March 14, 2022 at 9:05 am #18266thx thats good to know .
i was thinking of geting a unifi ap ax one of those disks and just run the 167 as pure modem
March 14, 2022 at 9:33 am #18267Hard to judge as MediaTeK track record in the modem world has not been positive.
There is the ZyXEL VMG3006-D70A VDSL2 which uses a Lantiq PXB 4389-720 chipset and supports SuperVectoring and seems feedback is positive .
https://www.zyxel.com/de/de/products_services/VDSL2-SuperVectoring-Bridge-Modem-VMG3006-D70A/
unsure regarding language options etc, but maybe worth a look ?
March 14, 2022 at 1:02 pm #18268thx mate
the draytek 167 got a quite good recommendation
in modem mode
with the latest fw update it got a router and dhcp mode
March 14, 2022 at 1:31 pm #18269If you do purchase the DrayTek 167, let us know how you got on with it
March 14, 2022 at 3:11 pm #18270i already got its working fine but cant use it with the 88u becouse it dont pick up the isp ip running pppoe it registrates ok the password but it does not get a ip same in modem mode and in router mode on the 167 with pppoe pasthrue so not using it atm
March 14, 2022 at 3:49 pm #18271I didn’t realise, at least that explains why you are thinking of the unifi ap ax as the DSL-AC88U is not up-gradable
March 18, 2022 at 12:37 pm #18292hi guys quick question could it be a FW issue the e wan issue im having .il try a older fw to see im on the latest atm
March 18, 2022 at 12:39 pm #18293shit i was thinking and typing bad combo the real question was had anyone tried the e wan funktion ?
March 18, 2022 at 1:52 pm #18294 -
