Viewing 15 posts - 211 through 225 (of 714 total)
  • #13392
    Avataryakumo
    • Replies 19
    Well, this is why I would not have tried this if there were not going to be updates or custom firmware. I would like to try cake
    #13396
    • Replies 8,734
    [quote quote=13392]Well, this is why I would not have tried this if there were not going to be updates or custom firmware. I would like to try cake [/quote]
    Ok, so I have had feedback from ASUS and they will look into allowing future QoS rules to be re-prioritized (movable), no guarantee .
    CAKE, or simular, lovely to have but does require good hardware and subsequent cooling abilities, not sure if the DSL-AX82U is designed for the level of CPU usage and heat generation and given the history of HEAT Generation problem the DSL-AC88U had,  a RISK
    #13399
    Avatardwskittles
    • Replies 12
    might order one of these does anyone have a screenshot of the dsl settings page and dsl stats page?
    #13400
    • Replies 8,734
    @dwskittles welcome, luckily I have my DSl-AX82U plugged in currently as re-testing QoS etc.
    Screen dumps of DSL Settings and DSL Log attached as requested on latest beta firmware
    #13424
    Avatardwskittles
    • Replies 12
    any idea what the Stability Adjustment setting does?
    #13426
    • Replies 8,734
    [quote quote=13424]any idea what the Stability Adjustment setting does?[/quote]
    SRA ensures that the line bandwidth is reduced to ensure that there is adequate noise margin on the line. When the noise on the line increases, SRA is used to reduce the bandwidth on the line, without dropping the line, and therefore, without interrupting the service.
    Services like Plusnet do not support SRA and I believe SRA is only available via Huawei cabinets (not ECI).
    Unsure about BT as they trailled SRA, but unsure how far the rollout proceed ?
    Update: I read your question incorrectly, I thought it said SRA (seamless rate adjustment) FFS
    #13428
    Black Bird
    • Replies 146
    SNR Margin Tweak: Better quality lines can provide higher connection speed.
    Avatardwskittles
    • Replies 12
    [quote quote=13428]
    SNR Margin Tweak: Better quality lines can provide higher connection speed.[/quote]
    only works for adsl ?
    #13432
    • Replies 8,734
    @dwskittles Have you tried it with VDSL ?
    #13433
    Avatardwskittles
    • Replies 12
    [quote quote=13432] @dwskittles Have you tried it with VDSL ?[/quote]
    yeah doesnt do anything on my vdsl2 line
    #13434
    • Replies 8,734
    When I last checked with ASUS around March, they still did not have the Stability Adjustment working for VDSL
    Even when I tried below cmd, still no joy
    xdslctl configure1 –snr XXX
    #13435
    Black Bird
    • Replies 146
    [quote quote=13431]
    only works for adsl ?[/quote]
    VDSL is also available
    (with new firmware update)
    #13437
    AvatarChelsea maniac
    • Replies 44
    Ax Wifi 6 cards going cheap on Amazon if anyone needs one https://www.amazon.co.uk/gp/product/B08DTNJFFK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    #13441
    • Replies 44
    Need help tried looking on internet but beyond me, 160 MHz Wi-Fi Channels should I enable yes or no I am putting in a new ax card in my laptop, but most of my stuff is old 5GHz or 2.4GHZ
    #13444
    • Replies 44
    ^^^^^^^ Please ignore all sorted and answered
