Viewing 15 posts - 376 through 390 (of 1,421 total)
  • #17252
    [quote quote=17251]No screams heard yet, so I think that’s a positive sign![/quote]
    Life on the edge, if your good lady is still happy after Friday, this will be a great sign
    #17272
    • Replies 634
    Excellent news , people in other forums say they experienced different problems.  But they did not factory reset and are reluctant to do so.  I always factory reset after updating just to rule out as much as possible.
    #17273
    AvatarDave
    • Replies 17
    This forum has been a real life saver the past few months since I got my XT8.
    I tried the upgrade myself this morning – no factory reset
    Had a 6 hour Teams call today – 2 hours in and the issues started – frequent disconnects, the mrs was in the other room and at the same time started to get the same issues.
    Had to revert back to 42095 – stability resumed.
    I’ll try a factory reset over the weekend to see if that helps and report back
    Thanks for the help everyone
    #17274
    [quote quote=17273]I’ll try a factory reset over the weekend to see if that helps and report back[/quote]
    Welcome, let us know if the factory reset provides better stability, would be a good example as you have problems currently
    #17291
    • Replies 634
    I will be sticking with this latest firmware 46061.  Thumbs up from me after a whole week .
    Thanks ASUS, please do not ruin it again with subsequent updates.
    #17292
    Great news, thanks for all your testing and good feedback 👍
    #17293
    AvatarDave
    • Replies 17
    Good to hear that.
    Do you think it’s the factory reset that made the difference?
    Also I’m only running in AP mode, my router doesn’t have a bridge mode unfortunately.
    #17294
    • Replies 634
    [quote quote=17293]Good to hear that. Do you think it’s the factory reset that made the difference? Also I’m only running in AP mode, my router doesn’t have a bridge mode unfortunately.[/quote]
    I cannot say as I always factory reset after updating.  I also change nothing on my ISP mode/router other than to turn off the Wi-FI.  The 4 x XT8’s provide WI-FI throughout my flat.
    #17299
    • Replies 634
    Just had all 3 nodes lose connection.  They are all connected via wireless backhaul.  Sent feedback to ASUS via UI.
    #17300
    was it the wireless that disconnected/dropped or maybe the front end router/modem that re synced with local cabinet that gave the impression that the Zen wifi dropped ?
    Sometimes difficult to distinguish unless you are specifically looking at the time ?
    Either way, hope it was just a one off
    #17301
    • Replies 634
    The actual Hyperoptic modem/router did not lose connection as my TV is connected to it via ethernet.  That was still working.  Nothing was connecting to the XT8’s.
    #17302
    • Replies 634
    After a few of these ‘error’:
    Jan 21 21:19:39 wlceventd: wlceventd_proc_event(508): eth4: Disassoc XX:XX:XX:XX:XX:XX, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
    Got this:
    May  5 06:05:18 crashlog: LOG
    May  5 06:05:18 crashlog: <6>protocol 0000 is buggy, dev archer
    May  5 06:05:18 kernel: klogd started: BusyBox v1.24.1 (2022-01-05 16:07:57 CST)
    And it carried on with similar logs
    Not sure if it means anything
    #17304
    A bug, definitely
    Was both 2.4GHz and 5GHz effected ?
    Is Guest WiFi enabled by any chance ?
    #17305
    AvatarDave
    • Replies 17
    I’ve factory reset mine this morning, not had chance to run a proper test but I was wondering what settings you guys use for the 5.2 backhaul?
    On mine, channel and wireless mode on auto things seem to be fine – but if I try and fix a channel or select AX mode only my node wont reconnect?
    If I choose the channel (100) and Mode as AUTO the node will only connect on 2.4ghz
    Any thoughts?
    #17306
    • Replies 634
    These are my Wireless backhaul settings
