Viewing 15 posts - 976 through 990 (of 1,421 total)
  • #23301
    AvatarNicky
    • Replies 58
    It’s there again?
    The CPU and Ram are not maxed out.
    Mar 22 17:45:49 kernel: CPU: 1 PID: 19422 Comm: asd Tainted: P O 4.1.52 #2
    Mar 22 17:45:49 kernel: Hardware name: Generic DT based system
    Mar 22 17:45:49 kernel: task: d91b8400 ti: d19b0000 task.ti: d19b0000
    Mar 22 17:45:49 kernel: PC is at 0xb6892ec0
    Mar 22 17:45:49 kernel: LR is at 0xb6893bb0
    Mar 22 17:45:49 kernel: pc : [<b6892ec0>] lr : [<b6893bb0>] psr: 80000010
    Mar 22 17:45:49 kernel: sp : bebea340 ip : b68a7150 fp : b68961f8
    Mar 22 17:45:49 kernel: r10: 00024164 r9 : b68960c0 r8 : 00000000
    Mar 22 17:45:49 kernel: r7 : 01fd7c18 r6 : 01fd79c0 r5 : bebea360 r4 : 01ff4428
    Mar 22 17:45:49 kernel: r3 : b6502428 r2 : 00000000 r1 : 00000080 r0 : 00000000
    Mar 22 17:45:49 kernel: Flags: Nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
    Mar 22 17:45:49 kernel: Control: 10c5387d Table: 0e2b404a DAC: 00000015
    Mar 22 17:45:49 kernel: [<c00270a0>] (unwind_backtrace) from [<c0022cf8>] (show_stack+0x10/0x14)
    Mar 22 17:45:49 kernel: [<c0022cf8>] (show_stack) from [<c04c76bc>] (dump_stack+0x8c/0xa0)
    Mar 22 17:45:49 kernel: [<c04c76bc>] (dump_stack) from [<c003ad2c>] (get_signal+0x490/0x558)
    Mar 22 17:45:49 kernel: [<c003ad2c>] (get_signal) from [<c0022290>] (do_signal+0xc8/0x3ac)
    Mar 22 17:45:49 kernel: [<c0022290>] (do_signal) from [<c0022718>] (do_work_pending+0x94/0xa4)
    Mar 22 17:45:49 kernel: [<c0022718>] (do_work_pending) from [<c001f58c>] (work_pending+0xc/0x20)
    Mar 22 17:45:49 rc_service: service 21670:notify_rc restart_firewall
    This is my current set up, all  hard wired.
    ZenWiFi AX
    Current Version : 3.0.0.4.388_22525-gd35b8fe
    AiMesh Node
    ZenWiFi AX Mini
    Current Version : 3.0.0.4.386_49599-g8352df7
    ZenWiFi AX Mini
    ZenWiFi AX
    #23304
    • Replies 8,726
    [quote quote=23301]The CPU and Ram are not maxed out.[/quote]
    Hi @Nicky, in your above log, above the first entry, are the previous logs just repeated (Control: 10c5387d Table: 0e2b404a DAC: 00000015) etc.
    Have you noticed any issues with your XT8 set-up like it crashing, or is it just the log error message has got you curious  ?
    #23311
    AvatarNicky
    • Replies 58
    The two posts are not the same entry, they have been cut and pasted as was in the log. The router has not crashed (yet). It’s just the error log, I’ve never seen this before and was getting a little curious as to what and why?
    I’ve just checked the log again and it’s not reoccurred since.
    #23312
    AvatarLarryR
    • Replies 33
    Had to reboot today after about 34 days uptime. Node was only connecting on 2.4 even though i had it set to fixed channel (173) 5-2. Interestingly enough, rebooting the node did not get it back on 5 backhaul. Had to do a system reboot from the app and then router and node were fine. Still, 30+ days for me is small miracle.
    #23313
    • Replies 8,726
    [quote quote=23312]Still, 30+ days for me is small miracle.[/quote]
    30+ days is most impressive
    #23314
    • Replies 8,726
    [quote quote=23311]The two posts are not the same entry, they have been cut and pasted as was in the log. The router has not crashed (yet). It’s just the error log, I’ve never seen this before and was getting a little curious as to what and why?[/quote]
    So had a chat with ASUS because the log entries where a little obscure and I wanted to make sure regarding the firewall reference,  I also  have some background information which may help other ASUS ZenWifi XT8 owners.
    ASUS ZenWifi XT8 Details
    1. The ASUS ZenWifi XT8 AiMesh Router (Primary/Master) can support upto 9 wireless AiMesh Nodes
    2. The ASUS ZenWifi XT8 can support upto a theoretical maximum number of wifi clients.
      1.  2.4G: 128 wifi clients
      2. 5G-1: 128 wifi clients
      3. 5G-2: 64 wifi clients
    ‘note: this is a theoretical maximum ‘
    Regarding your log messages, ASUS believe  the “asd” daemon crashed and the “restart_firewall” is called by “asd” after it restarted.
    The ASD is from a Linux perspective  stands for ‘anything-sync-daemon’ I believe and handles temp files and writing them to storage etc.
    The ‘CPU: 1 PID: 19422 Comm: asd Tainted: P O 4.1.52 #2’ in theory should not happen to much, but I have seen the same reference on other logs from ASUS users in the past, I assume it happens more often for yourself as you have a a lots of Nodes and wifi clients etc.
    It is nothing to worry about and it is LINUX doing its thing (I believe) and is now on ASUS radar for future consideration
    #23316
    AvatarNicky
    • Replies 58
    Thank you so much.
    There is a lot of useful information here, particularly with regards to the theoretical maximums.
    #23317
    • Replies 8,726
    No problem and they are ‘theoretical maximums’ no point having 128 wifi clients if you only have a 20Mbps internet connection, it would never work in practice
    #23354
    Jaime Salud CastilloJaime Salud Castillo
    • Replies 36
    6 days after hopping into the latest firmware and trying out suggested settings, my node reverted back to ‘weak’ 2.4g wireless backhaul. Bummer. Ever since purchasing this xt8, my longest run w/o reverting to 2.4g wireless backhaul is 8days uptime. So frustrating. Starting to get ‘buyers remorse’ now with this device. It’s so powerful and yet clunky.
    #23358
    • Replies 632
    Have you tried fixing the 5GHz-2 to 80MHz?
    #23361
    • Replies 36
    Yes that’s how i set it up once i updated to the latest firmware. 80ghz, unchecked auto select including dfs and unchecked enable 160ghz.
    #23376
    • Replies 8,726
    Also maybe worth trying disable – APSD (automatic power save delivery) and Airtime Fairness for the 5GHz-2 backhaul
    If above does not work maybe see below ?
    @Dodgydrains
    , I am thinking either the nodes are to far apart (40-50db for best results, 50-60db is ok) or a factory reset is required ?
    #23386
    • Replies 632
    Try checking in the app for the RSSI on each node.  All 4 of my XT8’s are under 55dBm.
    Also all the connection quality show as ‘Great’.
    #23399
    • Replies 36
    Ok all the suggested settings were already set at the time of updating firmware. The only additional setting i added now is the turning off of WMM APSD. Hope that tweak helps.
    also, my node isn’t really far from the main router, yes it’s on the second floor but i can still see the main router if i stand beside the node upstairs (around 10-15meters apart). And i consistently get -41 rssi (great) signal whenever i check from the app.
    Adding some screenshots of my settings:
    https://mega.nz/file/YZBB2b6S#q4kHT6kY4Qn8PCkltdpAwwIMaNI9HMlyTG6lWBqyCJI
    #23403
    • Replies 8,726
    If the above does not work, then try try disabling the 5Ghz (backhaul) roaming assistant.
    Do you live near an airport or military establishment as issue maybe radar interference ?
