BT Infinity Disconnects I am getting disconnects. I have BT infinity FTTC I am Using Draytek 130 modem and Asus Rt-AC66u running latest Merlin fw, my Draytek System Uptime is 430:25:32 and I…
› UKTH forums › 📡 Broadband Tech & ISP’s › BT › BT Infinity Disconnects I am getting disconnects. I have BT infinity FTTC I am Using Draytek 130 modem and Asus Rt-AC66u running latest Merlin fw, my Draytek System Uptime is 430:25:32 and I...
  • This topic has 102 replies, 4 voices, and was last updated 7 years ago by AvatarSH.
Viewing 15 posts - 16 through 30 (of 103 total)
  • #3240
    Bully
    • Replies 386
    Hi, Just looking at my line stats and noticed this line –
    InterleaveDelay :      0             800 (1/100 ms).  It used to be 0 0
    what does this mean ?
    #3241
    Is this with a DrayTeK, I forget, if so can you verify if your INP (far end)  value has also increased, to say 15?
    #3242
    Bully
    • Replies 386
    Yeah with the draytek 130
    Bitswap      :      0               1
    LOS          :      0               0
    FECS         :   5236            24550 (seconds)
    ES           :      1            1141 (seconds)
    SES          :      0              10 (seconds)
    LOSS         :      0               0 (seconds)
    UAS          :     33            23723 (seconds)
    CRC          :      2            1355
    INP          :      0              15 (symbols)
    NFEC         :    255              85
    LSYMB        :   2815            11849
    INTLVBLOCK   :    255              85
    AELEM        :      0            —
    #3243
    Looking at your stats and from my memory, looks like your ECI DSLAM still does not support G.inp, I had assumed BT would have sorted this out nationally by now ;-(
    INP (Impulse Noise Protection) has been applied to your connection and hence the increase in InterleaveDelay – which means for whatever reason you connection maybe having short electrical impluses from external sources and so the connection has introduced INP to compensate for this interference and hence this has increased the InterleaveDelay which means (simplistically) a very slight delay in terms of time (milliseconds)
    Does you connection drop at all ? or has line synch reduced ?
    #3244
    Bully
    • Replies 386
    rare drop outs now, slower speed on down stream, increased ping.
    #3245
    [quote quote=3244]rare drop outs now, slower speed on down stream, increased ping.[/quote]
    What’s all you stats like, can you cut and paste them ?
    #3246
    Bully
    • Replies 386
    DS Actual Rate          : 38285000 bps   US Actual Rate       : 10491000 bps
    DS Attainable Rate      : 44764888 bps   US Attainable Rate   : 10621809 bps
    DS Interleave Depth     :      558       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        6  dB
    DS actual PSD           :     6. 4 dB    US actual PSD        :    12. 9  dB
    NE CRC Count            :        2       FE CRC Count         :     1355
    NE ES Count             :        1       FE  ES Count         :     1141
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
    #3247
    Looks like you have lost 7Mb is speed and your DS Interleave Depth is 558
    Was previously 1, so I assume either modem is being switched on an off regularly or you have an issue with noise on you line.
    Is modem near microwave or on a shared power socket, if not you need to have a chat with BT ?
    EDIT: has any DSL cables been replaced recently ?
    #3248
    Bully
    • Replies 386
    It is not near a microwave, but it is in a shared socket with my Asus router.
    EDIT – No
    #3250
    Is your BT cable underground or via Telegraph poles ?
    #3251
    Bully
    • Replies 386
    Poles
    #3252
    [quote quote=3251]Poles[/quote]
    Interesting, does the outside DSL BT line run via/near  any street lights, tree branches or power cables (grid) etc?
    Is so then you maybe having REIN / SHINE issues ?
    REIN vs SHINE:
    #3255
    nice video: https://support.zen.co.uk/kb/knowledgebase/broadband-understanding-rein-and-shine
    maybe helpful to find REIN/SHINE with an AM radio receiver.
    #3256
    Bully
    • Replies 386
    It is approx 2 yards from a street light pole, the street light pole is approx 5 ft lower than the BT pole where the wires connect to it and connect into a box on the pole.
    #3257
    [quote quote=3256]It is approx 2 yards from a street light pole, the street light pole is approx 5 ft lower than the BT pole where the wires connect to it and connect into a box on the pole.[/quote]
    Well it ill give you something to talk about with BT Openreach if you decide to contact them ;-)
