BT Infinity Disconnects I am getting disconnects. I have BT infinity FTTC I am Using Draytek 130 modem and Asus Rt-AC66u running latest Merlin fw, my Draytek System Uptime is 430:25:32 and I…
› UKTH forums › Broadband Tech & ISP’s › BT › BT Infinity Disconnects I am getting disconnects. I have BT infinity FTTC I am Using Draytek 130 modem and Asus Rt-AC66u running latest Merlin fw, my Draytek System Uptime is 430:25:32 and I...
  • This topic has 102 replies, 4 voices, and was last updated 7 years ago by AvatarSH.
Viewing 13 posts - 91 through 103 (of 103 total)
  • #4725
    • Replies 8,739
    Ahh, so no REIN/SHINE concerns, If I remember, you original had SKY, was that speed any less/more ?
    #4757
    Bully
    • Replies 386
    I really cant remember, its my age you know
    #4758
    • Replies 8,739
    Did you try the HG612 modem ,?
    #4759
    Bully
    • Replies 386
    No not yet
    #4937
    Bully
    • Replies 386
    Decided to try my HG612 3B, I tried to update the firmware to access the GUI (as per the Kitz forum), I can start the update process but when complete it wont allow me to access the gui, nor can I ping its ip address?
    #4938
    • Replies 8,739
    I updated my HG612 the other day after talking with you and manged it, if accessing HG612, you have to change IP address of Connection PC/Laptop to say 192.168.1.9 and plug ethernet cable into LAN port 2 to gain access
    Access to UI is via http://192.168.1.1
    #4939
    Bully
    • Replies 386
    [quote quote=4938]I updated my HG612 the other day after talking with you and manged it, if accessing HG612, you have to change IP address of Connection PC/Laptop to say 192.168.1.9 and plug ethernet cable into LAN port 2 to gain access Access to UI is via http://192.168.1.1[/quote]
    I have set laptop to 192.168.1.100, and connecting to lan port 2 on HG612 but no joy.
    #4940
    • Replies 8,739
    [quote quote=4939]
    I have set laptop to 192.168.1.100, and connecting to lan port 2 on HG612 but no joy.[/quote]
    I believe you may have to flash the firmware several times in order to get it to stick, which firmware did you use in the end ?
    When flashing new firmware, connect laptop to Lan 1 port
    #4941
    Bully
    • Replies 386
    [quote quote=4940]
    I believe you may have to flash the firmware several times in order to get it to stick, which firmware did you use in the end ? When flashing new firmware, connect laptop to Lan 1 port[/quote]
    Will give lan 1 a try.
    Using – bcm96368MVWG_fs_kernel_HG612V100R001C01B030SP08_webgui
    #4942
    • Replies 8,739
    Sorry, just read the instruction and LAN port 2 is the one described / needed
    Firmware looks good
    #4943
    Bully
    • Replies 386
    [quote quote=4942]Sorry, just read the instruction and LAN port 2 is the one described / needed Firmware look good[/quote]
    oh dear, I have tried flashing it 10 + times and can’t access the gui.
    #4944
    • Replies 8,739
    Oh well, worth a try it was, U can still can use HG612 as is, but you will not have access to stats etc.
    The Firmware upgrade provided the ability to use G.inp and ability to access stats. as your DSLAM/Cab is ECI, they have not enabled G.inp on them yet, so no real loss
    #4946
    AvatarSH
    • Replies 81
    Does DSLstats program will work ? to see DSL stats ?
    -> https://kitz.co.uk/routers/dslstats.htm
    -> http://dslstats.me.uk/downloads.html
