Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
› UKTH forums › 🛜 Wireless Routers & Modems › DrayTeK & Wireless › Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
Viewing 12 posts - 76 through 87 (of 87 total)
  • #6590
    AvatarMrk26
    • Replies 465
    I guess will have to wait till coronavirus trend finish for more accurate measurements 😂🤣😂
    #7056
    AvatarMrk26
    • Replies 465
    I decided to carry on here, about exercises made in this thread. With SRA disabled modem sync about 2Mb faster, also after 16h of uptime modem still give good throughput on speed tests (will test this further), speed is more constant, no drops. About 6k FEC errors for 16h uptime, this is no more than with SRA “on” with interleave on downstream.
    #7057
    • Replies 8,702
    Speed synch increase is good, did the SNR value drop slightly ?
    #7058
    AvatarMrk26
    • Replies 465
    Not really, I applied light cap to my downstream, and is exactly same as was with SRA enabled, but once reboted with SRA disabled, attienable speed was 2Mb higher than before reset, and it keep it like that even now. I think more about snr I should be able to say once I back on fastpath and remove cap. So far no harm notice with SRA disabled.
    #7182
    AvatarMrk26
    • Replies 465
    After exactly 5 days, today morning (day 6th ) back on fastpath on downstream. SRA still disabled no issues at all.
    #7183
    • Replies 8,702
    Fastpath downstream, great news, are FEC low ?
    #7184
    AvatarMrk26
    • Replies 465
    Yes, all nice and smooth, I rebooted modem just over hour ago to remove cap and since then 59 FEC errors. Also seems like bitswap turn on faster now, usually on upstream within 2-3h from reboot, now after couple of minutes from reboot, booth upstream and downstream enabled.
    #7186
    • Replies 8,702
    #7218
    AvatarMrk26
    • Replies 465
    After first 24h on fastpath with SRA disabled I’m actually impressed with amount of errors. On downstream FEC 1323, ES 77, CRC 88, upstream even lower than these.
    #7219
    • Replies 8,702
    What’s synch rate/speed ?
    Draytek’s are good in the fact you have lots of options to tweak them easily
    #7220
    AvatarMrk26
    • Replies 465
    Sync speed is 74Mb and I believe this best what I can get without tweaking at the moment.
    #7221
    • Replies 8,702
    74Mbps without G.inp is pretty good for an ECI cab
