Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
› UKTH forums › 🛜 Wireless Routers & Modems › DrayTeK & Wireless › Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
Viewing 15 posts - 46 through 60 (of 87 total)
  • #6036
    AvatarMrk26
    • Replies 465
    It’s difficult to be busy in wonderful weather like this 😂😂
    #6057
    AvatarMrk26
    • Replies 465
    After few out of my control disconnections (wife on duty 😂) I managed to keep zyxel connected for three days constantly, today morning checked and dlm resync after 1AM and put fastpatch on upstream 😁. If old scheme still works, after 5 days I should be back on fastpatch on downstream. Was thinking if won’t be worth put now vigor and see if fastpatch won’t kick on it, I only keep small cap on downstream now 🤔
    #6058
    • Replies 8,708
    Good to hear the Broadcom Zyxel worked for you ;-)
    #6059
    AvatarMrk26
    • Replies 465
    Yes, Broadcom based modems are best to stabilise line, but for long term use… Noooo 😂
    #6061
    • Replies 8,708
    #6062
    • Replies 1,035
    … fastpatch … fastpatch …  fastpatch …
    Please write fastpath, there is no such thing like fastpatch.
    Only in firmwares or other software they may release a fast patch.
    #6063
    AvatarMrk26
    • Replies 465
    That’s what probably confuse me.
    #6082
    AvatarMrk26
    • Replies 465
    Probably best record (so far) on my ECI cabinet. After full three days fastpath was enabled on upstream, after another three days fastpath kicked in on downstream. Zyxel modem sync with just under 75Mb/s but throughput seems to be very poor, achievable speed only 61Mb/s where ip profile is 69. Time for vigor, will see if it don’t mess up this time.
    #6083
    • Replies 8,708
    Just out of interest, have you tried a ‘quite line test’, to see if there is any noise on your line as Broadcom are good at dealing with a problem lines, so you may have an underlying line problem that Lantiq may struggle with ?
    (only a thought)
    Performing the Quiet Line Test:
    Step 1
    Plug an analogue phone into the main BT test socket.
    Step 2
    Dial the test number 17070, Choose option 2 from the menu “Quiet Line Test”
    Step 3
    If your telephone has the option, put it on mute. you should hear nothing through the handset.
    Step 4
    If you hear any line noise, crackling, buzzing, popping or humming note the time you conducted the test. as you may have a line problem
    https://community.bt.com/t5/BT-Fibre-broadband/How-quiet-should-the-Quiet-Line-Test-be/td-p/1666911
    #6084
    AvatarMrk26
    • Replies 465
    After I eliminate aluminum extension in my house I don’t have any issues with line at all. Also bear in mind that old bt eci modem was constantly on fastpath for three months. I remember doing quite line test in past (before sorted aluminum extension) and line was quite. I personally think that there was too many disconnections with vigor before I managed to setup that damn thing properly 😅. Will see tomorrow morning. Based on last experience I didn’t have to wait long for dlm with vigor on my line 😜.
    I think is worth to mention that on my line lantiq based modem have slighty lower latency comparing to broadcom based modems, also I realise that even with QOS set (of course individually to line speed) on vigor I have a lot less bufferbloat than on zyxel. I like zyxel for abilities to maintain line in need, but other than that I’m struggle to force myself to use it on daily basis.
    #6086
    • Replies 8,708
    Understood, I have learnt the hard way that what ‘was’ can change, my case was BT engineer in cabinet at end of road damaging perfectly good crimp connections etc, such fun ;-)
    #6087
    AvatarMrk26
    • Replies 465
    At least is sorted 👍
    I don’t have any reason to think or suspect that something may be wrong with my line, so I blame myself at the moment. I don’t even think about to reduce snr (tiny – 0.8db) to get full speed as I spoke with people on ee community forum regarding g.inp, unfortunately they wasn’t able yet to confirm if ee opt in for trial but if they will they will try to push me in to the trial.
    #6089
    AvatarMrk26
    • Replies 465
    Just a quick update.
    Vigor 2760 survived whole 24h and still going on fastpath. Must be then too many disconnections (due to setup) what pushed dlm to put my line on absolute interleave.
    #6090
    • Replies 8,708
    Role on G.inp in your area for ECI Cabs ;-)
    #6100
    AvatarMrk26
    • Replies 465
    Hey @Uk Sentinel,
    I was playing with vigor a little bit and wonder if this is something similar to pbParams on broadcom modems:
    DrayTek> vdsl status bandinfo
    [ BAND INFORMATION ]
    US:
    Band=0, LATN=   0, SATN=   0, SNR=   6, Border=[   9-  31], Limits=[   6-  31]
    Band=1, LATN=  14, SATN=  13, SNR=   7, Border=[ 882-1193], Limits=[ 882-1193]
    Band=2, LATN=  21, SATN=  21, SNR=   6, Border=[1984-2770], Limits=[1984-2770]
    DS:
    Band=0, LATN=   7, SATN=   7, SNR=   6, Border=[  33- 857], Limits=[  33- 857]
    Band=1, LATN=  16, SATN=  16, SNR=   6, Border=[1218-1959], Limits=[1218-1959]
    Band=2, LATN=  27, SATN=  27, SNR=   5, Border=[2795-4083], Limits=[2795-4083].
    Looks like is a bit more details?
    Also was wondering why my vigor don’t show decimal values just full, I mean snr 6.2db and just show 6 db. I’m pretty sure I see some screenshots on internet from different vigor modems and they show decimal values.
