› UKTH forums › Wireless Routers & Modems › DrayTeK & Wireless › Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
- This topic has 86 replies, 4 voices, and was last updated 6 years, 6 months ago by
- March 1, 2020 at 8:20 am #6103
Yes very similar, it basically shows the Band status (usually 3 streams) of a DSL signals (frequency)
The DSL-AC88U has this option also in pictorial form (see attachment)
Does the same happen with regards to the decimal place if you try a different PC/Laptop, most Odd ? also are you accessing draytek via Telnet or via the UI (Web Console) or the equivalent for 2760
I assume if you run the cmd (vdsl status) and (vdsl status more) are any of these stats to a single decimal place (my Draytek 130 is not plugged in currently) to check
March 1, 2020 at 9:13 am #6105Right now using mobile telnet.
DrayTek> vdsl status
DS Actual Rate : 77976000 bps US Actual Rate : 20000000 bps
DS Attainable Rate : 78065656 bps US Attainable Rate : 22670304 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 12 dB Cur SNR Margin : 6 dB
DS actual PSD : 1. 2 dB US actual PSD : 1. 4 dB
NE CRC Count : 383 FE CRC Count : 42313
NE ES Count : 307 FE ES Count : 38055
Xdsl Reset Times : 0 Xdsl Link Times : 1
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Test Mode : DISABLE
Far Current Attenuation : 11 dB Far SNR Margin : 6 dB
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544eb206
DSLAM CHIPSET VENDOR :DrayTek> vdsl status counts
[ Counters: Showtime ]
Near End Far End Note
ElapsedTime : 228064 228064 (seconds)
CRC : 383 42313
FEC : 5503 3919747
HEC : 0 0
CRC_P : 134 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 307 38055
SES : 0 67
LOSS : 0 1760
UAS : 0 0
LOFS : 0 0[ Counters: 15Min ]
ElapsedTime : 464 464 (seconds)
CRC : 1 1
FEC : 13 4
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 1
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0[ Counters: 1DAY ]
ElapsedTime : 2264 2264 (seconds)
CRC : 1 2
FEC : 26 11
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 1 2
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0DrayTek> vdsl status more
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 5505 3919747 (seconds)
ES : 307 38055 (seconds)
SES : 0 67 (seconds)
LOSS : 0 1760 (seconds)
UAS : 33 16569854 (seconds)
HECError : 0 0
CRC : 383 42313
INP : 0 0 (symbols)
INTLVDelay : 0 0 (1/100 ms)
NFEC : 255 255
RFEC : 16 16
LSYMB : 5410 20895
INTLVBLOCK : 255 255
AELEM : 0 —-Only PSD info is with decimal values, but snr it’s just round to full.
March 1, 2020 at 10:00 am #6106Does PC Telnet show same results (decimal) ?
Chipset Vendor is not showing anything ?
March 1, 2020 at 10:06 am #6107Only for PSD, and for some reason on “vdsl status” mobile telnet glitch because missing vendor chipset info which is IFTN (putty on pc/laptop show this correct, but that is not a problem). Also in draytek UI show only round values (apart of PSD values).
March 1, 2020 at 12:46 pm #6109[quote quote=6107]Only for PSD, and for some reason on “vdsl status” mobile telnet glitch because missing vendor chipset info which is IFTN (putty on pc/laptop show this correct, but that is not a problem). Also in draytek UI show only round values (apart of PSD values).[/quote]
Must be equivalent to what Microsoft call a ‘feature’
March 2, 2020 at 10:54 am #6130[quote quote=6028]We have all been there, I had the DrayTeK 130 in for ages and G.inp would not kick in, I finally plugged in my Fritz!Box 3490 and two days later G.inp was working. for me it appears that most DSL chipsets keeps FastPath/G.inp enabled, but only certain ones are suitable to re-enable a service and/or the firmware also ? DrayTek 130 = Lantiq (VR9) Fritz!Box 3490 = Lantiq (VRX288) https://openwrt.org/docs/techref/hardware/soc/soc.lantiq[/quote]
Was thinking about this, that vigor don’t want to enable g.inp, do you know which modem code was used (there is two to choose), if you set default, modem could use one which is not suitable for g.inp.
March 2, 2020 at 1:06 pm #6133For my Vigor 130, I used BT Firmware which supported G.INP since 2015 with modem code 576D17, probable same as your 2760 as reading both changelogs, they seem similar
March 2, 2020 at 1:33 pm #6134Yes, I was on 576D17 (was chosen by default option), but I realised that on downstream snr go below 6db after three days, what didn’t happened on old eci modem so decided to use 574307 (sync couple bytes slower) and will see how this one will perform. I also read that 574307 perform better for g.inp, which may be the case for you if (ever) you decide to back to vigor.
March 2, 2020 at 1:47 pm #6135[quote quote=6134]Yes, I was on 576D17 (was chosen by default option), but I realised that on downstream snr go below 6db after three days, what didn’t happened on old eci modem so decided to use 574307 (sync couple bytes slower) and will see how this one will perform. I also read that 574307 perform better for g.inp, which may be the case for you if (ever) you decide to back to vigor.[/quote]
Next time I will try 574307
March 5, 2020 at 10:18 pm #6149Just to update, on modem code 574307 everything nice and smooth, snr still on 6db, speed nice and stable.
March 6, 2020 at 7:10 am #6152[quote quote=6149]Just to update, on modem code 574307 everything nice and smooth, snr still on 6db, speed nice and stable.[/quote]
Good news and thanks for update, are you on the G.INP trial for ECI cabs ?
March 6, 2020 at 7:40 am #6155I spoke with ee (my isp) good week ago and they wasn’t aware of trial, at least people who answer on ee community forum. However they asked me for my details and they told me if ee will be in trial they will try to put me in. I will ask them again for update, obviously March already and twelve is in next week. 😉
March 6, 2020 at 10:20 am #6156April 20, 2020 at 8:43 pm #6585I see something strange happening on my line. Not sure if this is normal as until last year I never looked on vdsl stats. From approx two weeks when temperatures get higher outside I notice that between 9AM and 9PM my attienable speed dropping about 2Mb on downstream only. If my modem sync at 77Mb it will stay like that even than attienable speed drop to 75Mb and this drop don’t cause rebot. Is it possible that warm temperatures cause drop like this? 🤔
April 20, 2020 at 8:53 pm #6586Line synch rates do vary during the day, based on temps and how busy cabs are etc.
