Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
› UKTH forums › 🛜 Wireless Routers & Modems › DrayTeK & Wireless › Draytek Vigor2760 Any advice with extra settings for vigor 2670 used in bridge mode?
Viewing 15 posts - 31 through 45 (of 87 total)
  • #5990
    • Replies 8,707
    Pc.
    Yes for PC, then ping is vey important, hopefully your Son can be patient
    #6014
    • Replies 8,707
    How’s the Interleaving depth, has it gone yet ?
    #6015
    AvatarMrk26
    • Replies 465
    No, still interleaved on booth (upstream and downstream) after five days I put up snr on downstream up to 8db,will see if that change anything soon, if not may have to put on my line zyxel VMG1312-B10A for little while for better control on speed on downstream and upstream. How long it takes for you to go back on fastpatch when you switch modems?
    #6019
    • Replies 8,707
    I forget, what Exchange/Cab are you connected to ?
    #6020
    AvatarMrk26
    • Replies 465
    Eci, and I don’t have idea what’s going on . I only got some FEC errors like 30k per day, no other errors. I wonder if BT didn’t change anything on cabinet, apparently they going to launch g.inp trial again in March for ECI cabinets (not necessary mine).
    #6023
    • Replies 8,707
    Maybe better to put back in Zyxel for a few days to see if this settles the DLM and switches back on Fastpath.
    I read that yesterday also – Interesting to find the test locations it would be
    Openreach UK Trial Finally Brings G.INP to ECI FTTC Broadband
    #6024
    AvatarMrk26
    • Replies 465
    This is exactly the one I read. I will give one more week for vigor and then will play with zyxel. The thing is that last time when I had situation like this nothing didn’t changed for 15 days until I capped speed.. Will see.
    #6026
    AvatarMrk26
    • Replies 465
    I keep thinking about this, it’s just annoying because I setup all to work properly with vigor now will have to change back configuration for zyxel. Instead of waiting for two weeks I may be able to achieve something earlier. Just need to wait for family to go out so I can play with it in peace.
    #6028
    • Replies 8,707
    We have all been there, I had the DrayTeK 130 in for ages and G.inp would not kick in, I finally plugged in my Fritz!Box 3490 and two days later G.inp was working. for me it appears that most DSL chipsets keeps FastPath/G.inp enabled, but only certain ones are suitable to re-enable a service and/or the firmware also ?
    DrayTek 130 = Lantiq (VR9)
    Fritz!Box 3490 = Lantiq (VRX288)
    https://openwrt.org/docs/techref/hardware/soc/soc.lantiq
    #6029
    AvatarMrk26
    • Replies 465
    Well previously I was on asus dsl-ac88u and fastpatch didn’t kicked until I capped speed. So not sure if modem abilities play here on my line. For some reason cabinet stuck on these settings until it get kick.
    #6030
    • Replies 8,707
    Roll on FTTP / FTTH
    #6031
    AvatarMrk26
    • Replies 465
    Wish I could….
    I will have to change house to get FTTP but is not worth, love my current one
    I use opportunity that most of my family go out and put in place zyxel, capped straightaway to 60/15Mbs and will wait for magic to start working.
    edit
    Was actually smoother than I expected, configured zyxel to use on one cable as well, just changed ip to slightly different than vigor
    #6033
    • Replies 8,707
    #6034
    AvatarMrk26
    • Replies 465
    We have all been there, I had the DrayTeK 130 in for ages and G.inp would not kick in, I finally plugged in my Fritz!Box 3490 and two days later G.inp was working. for me it appears that most DSL chipsets keeps FastPath/G.inp enabled, but only certain ones are suitable to re-enable a service and/or the firmware also ? DrayTek 130 = Lantiq (VR9) Fritz!Box 3490 = Lantiq (VRX288) https://openwrt.org/docs/techref/hardware/soc/soc.lantiq
    I was looking into this and looks like vigor 2760 is on same chipset as your fritzbox…
    Wondering if they didn’t mess up with fw? 🤔
    #6035
    • Replies 8,707
    Trail and error I am afraid via testing, glad you are not busy currently
    Edit: did u ever try the unofficial (non BT) firmware  ?
