Viewing 15 posts - 361 through 375 (of 718 total)
  • #7048
    • Replies 8,709
    I would assume router would re-synch if Bitswap is disabled, alas I am not so familiar with BDC commands so will have to look into how to disable bitswap on the HG612, unless you have seen how to do this already ?
    So looks like you have a choice to cap speeds at modem or disable bitswap ?
    #7049
    Bully
    • Replies 386
    I do not know how to do either.
    #7050
    AvatarMrk26
    • Replies 465
    xdslcmd configure –maxDataRate 35000 12000 100000
    You will cap line to 35Mb on downstream, upstream stays at 12Mb. Cap working straight away once you hit enter and modem will resync with lower speed and higher snr(what should make your line more stable). To remove cap you will need to reboot modem. If you reboot modem accidentally you need to reapply cap.
    #7051
    Bully
    • Replies 386
    xdslcmd configure –maxDataRate 35000 12000 100000 You will cap line to 35Mb on downstream, upstream stays at 12Mb. Cap working straight away once you hit enter and modem will resync with lower speed and higher snr(what should make your line more stable). To remove cap you will need to reboot modem. If you reboot modem accidentally you need to reapply cap.
    Thanks.  So when the modem resycns will it disconnect the internet and give me a new IP ?
    #7052
    AvatarMrk26
    • Replies 465
    It may give you new IP, or may it be the same. When I capped my line last week I still was on same IP, but can’t guarantee.
    Edit
    Yes, it will disconnect.
    #7054
    Bully
    • Replies 386
    It may give you new IP, or may it be the same. When I capped my line last week I still was on same IP, but can’t guarantee. Edit Yes, it will disconnect.
    Ok, thanks.
    #7059
    AvatarMrk26
    • Replies 465
    Hi @Bully,
    Did you try cap your line?
    #7061
    Bully
    • Replies 386
    Hi @Bully, Did you try cap your line?
    Not yet.
    #7062
    Bully
    • Replies 386
    I know you are all probably getting fed up with seeing my stats, but here are today’s –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 12133 Kbps, Downstream rate = 49708 Kbps
    Bearer: 0, Upstream rate = 12198 Kbps, Downstream rate = 39994 Kbps
    Link Power State: L0
    Mode: VDSL2 Annex B
    VDSL2 Profile: Profile 17a
    TPS-TC: PTM Mode(0x0)
    Trellis: U:ON /D:ON
    Line Status: No Defect
    Training Status: Showtime
    Down Up
    SNR (dB): 6.6 6.0
    Attn(dB): 19.5 0.0
    Pwr(dBm): 13.4 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 18 20
    B: 31 238
    M: 1 1
    T: 64 63
    R: 10 16
    S: 0.0255 0.6235
    L: 13200 3272
    D: 1283 1
    I: 42 255
    N: 42 255
    Counters
    Bearer 0
    OHF: 131441945 375914
    OHFErr: 88 0
    RS: 3228911719 2683893
    RSCorr: 905547 10
    RSUnCorr: 3836 0
    Bearer 0
    HEC: 675 0
    OCD: 31 0
    LCD: 31 0
    Total Cells: 3305294218 0
    Data Cells: 1029739641 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 34 2655
    SES: 0 31
    UAS: 26 86680
    AS: 322458
    Bearer 0
    INP: 3.50 0.00
    INPRein: 0.00 0.00
    delay: 8 0
    PER: 2.45 9.85
    OR: 78.26 21.09
    AgR: 40072.04 12219.06
    Bitswap: 220069/221500 18/18
    Total time = 1 days 17 hours 34 min 44 sec
    FEC: 905547 10
    CRC: 88 0
    ES: 34 2655
    SES: 0 31
    UAS: 26 86680
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 4 min 44 sec
    FEC: 152 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 820 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 17 hours 34 min 44 sec
    FEC: 141122 1
    CRC: 5 0
    ES: 3 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 287755 2
    CRC: 16 0
    ES: 5 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Since Link time = 3 days 17 hours 34 min 17 sec
    FEC: 905547 10
    CRC: 88 0
    ES: 34 2655
    SES: 0 31
    UAS: 0 86654
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    DSL mode: VDSL2 Profile 17a
    Status: Showtime
    Uptime: 3 days 17 hours 34 min 18 sec
    Resyncs: 0 (since 07 May 2020 18:21:24)
    Downstream Upstream
    Connection speed (kbps): 39994 12198
    SNR margin (dB): 6.6 6.0
    Power (dBm): 13.4 6.7
    Interleave depth: 1283 1
    INP: 3.50 0
    Vectoring status: 5 (VECT_UNCONFIGURED)
    RSCorr/RS (%): 0.0280 0.0004
    RSUnCorr/RS (%): 0.0001 0.0000
    ES/hour: 0 0
    #7063
    AvatarMrk26
    • Replies 465
    No, not fed up, however you could entertain us a little bit
    You sync now with 6.6 db snr on upstream, I wonder how your stats will looks like at 8 db snr on downstream
    From this what I can see, amount of errors per day is pretty much same, so if you don’t help DLM, it will not change much more on your line.
    #7064
    • Replies 8,709
    A higher SNR will reduce synch speed/rate? slightly
    #7065
    AvatarMrk26
    • Replies 465
    Yes, but it may give a kick for DLM.
    #7066
    • Replies 8,709
    Miracles can happen
    #7067
    AvatarMrk26
    • Replies 465
    Maybe @Bully with broadcom based modem will have more luck than I with vigor, who knows 😜
    #7069
    Bully
    • Replies 386
    @Mrk26 – I want to setup my modem and router for 2 cabled connection.  I have already reserved ip addresses on my router from 01 to 34 and also 100, the ip pool ending address is 254, what do you recommend i set the modem ip address to and the wan address of the router?  I want it to be clear and understand before i set it all up.
    Thanks in advance.
