Viewing 15 posts - 196 through 210 (of 1,130 total)
  • #6141
    • Replies 8,721
    Try Version 1.1.2.3_790 for DSL-AC750 ?
    and factory reset after loading firmware and configure from scratch – if this is still problem we can chat about your router settings etc. Just make sure you use ASUS QiS ‘Wizard’ to set-up router after factory reset.
    #6142
    Avatarjmpr
    • Replies 3
    I have 1.1.2.3_790 in N55U D1. Do you think it is going to be the last one?
    I use this router with a FFTH line, and is rock solid, much better that the ZTE AC1200 that ISP installed.
    I downloaded it from:
    https://www.asus.com/Networking/DSLN55U_D1/HelpDesk_BIOS/
    #6143
    • Replies 8,721
    As far as I am aware the DSL-N55U – D1 is still supported by ASUS
    #6144
    Avatarjmpr
    • Replies 3
    Thanks. Where can I see when a router has ended being supported?
    #6145
    • Replies 8,721
    [quote quote=6144]Thanks. Where can I see when a router has ended being supported?[/quote]
    I use this link, usually upto date –
    https://www.asus.com/event/network/EOL-product/
    #6146
    Avatarlostcause
    • Replies 53
    [quote quote=6139]Hi to All! I have the latest version of Fw: V1.1.2.3_805 for DSL-AC750 and my connection is not good, need more time to be connected DSL, and I must all time wait many time, what is about you guys, and how we resolve this problem… I must try the V9.1.2.3_743 Thanks in advance[/quote]
    No connection issues here (VDSL) on a AC51 (which is a rebranded AC750 ?) on beta firmware 9.1.2.3_rev708fa_0.  I am on a capped line though.
    The DSL Driver Version is FwVer:5.5.2.11_B_A60901 HwVer:T14.F7_0.2
    #6200
    • Replies 8,721
    Latest DSL ASUSWRT firmware v9.1.2.3_828-ga5512a3 now available, release note as follows.
    Note: Usual ASUS BETA T&C’s apply (see top of Forum)
    https://www.asuswebstorage.com/navigate/a/#/s/93FA84838DDE42949D1DB3F65DF33E2AY
    [MT751x] xDSL driver updated – v5.6.36.0_20191030_DT, addressed some xDSL interoperability issues.
    Enhanced workaround for VDSL2 G.INP issue.
    Modified the SSL option to speed up HTTPS connection.
    Fixed Web UI related issues.
    Fixed the device which support TR-069 experience boot up issue after disable one interface of 2.4G or 5G.
    Fixed OpenVPN related issues.
    ADSL WAN (ATM) QIS manual setting list updated: Added United Kingdom ISP Cloudscape Connect.
    VDSL WAN (PTM) QIS manual setting list updated: Added United Kingdom ISP Cloudscape Connect and Australia ISP iiNet (PPPoE) (VLAN ID 2).
    Update:
    ASUS have informed me of possible ADSL synch issue with firmware release v9.1.2.3_828
    For MT751x based models, recent beta firmware release v9.1.2.3_828, there is possible ADSL sync issue. It’s just been identified today.
    However, no issue if connect to VDSL2. So for customers using ADSL and raised concern, please help to inform ccustomers to revert back to earlier official v1.1.2.3_805, which is available on support site.
    In the meantime, we are working on updated version, will be available early next week
    Update 1:
    Updated beta firmware now available that fixes earlier ADSL sync problems
    v9.1.2.3_835-g5ced613 (UKTH)
    https://www.asuswebstorage.com/navigate/a/#/s/50F2BE9BC89E44F98860E933B7D0E618Y
    #6201
    Avatarlostcause
    • Replies 53
    Thank you Sentinel & Asus, great update !
    Curious to see if this FW will make it past 6 days uptime. Fingers crossed ;-)
    #6202
    • Replies 8,721
    [quote quote=6201]Thank you Sentinel & Asus, great update ! Curious to see if this FW will make it past 6 days uptime. Fingers crossed ;-)[/quote]
    Let us know how it goes
    #6203
    Avatarboyelroy
    • Replies 10
    after update the new beta firmware (DSL-AC51), the link (dslam) never connected. (link is down).
    #6204
    • Replies 8,721
    [quote quote=6203]after update the new beta firmware (DSL-AC51), the link (dslam) never connected. (link is down).[/quote]
    I assume you have rebooted the DSL-AC51 ? Is there any indication as to problem in the DSL Log or General Log etc.?
    #6205
    Avatarboyelroy
    • Replies 10
    this time is back to previous firmware but before, the Log showed “initialized – link down – initialized – link down” and repeat around.
    #6206
    • Replies 8,721
    Will be interesting to see if others have issue with the DSL-AC51 and the latest firmware?
    #6207
    Avatarlostcause
    • Replies 53
    No issues here with DSL-AC51 on VDSL/G.INP 17a profile Broadcom DSLAM, no VPN enabled.
    Firmware Version: v9.1.2.3_828
    DSL Driver Version, FwVer:5.6.36.0_A_A60901
    #6213
    Avatarjonathan
    • Replies 11
    @uk-sentinel
    new driver more successful than older, I have been connected for 21 hours. I got much less crc error. there is going well.
