Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750
Viewing 15 posts - 211 through 225 (of 1,130 total)
  • #6215
    • Replies 8,721
    [quote quote=6213] @uk-sentinel new driver more successful than older, I have been connected for 21 hours. I got much less crc error. there is going well. Firmware Version: v9.1.2.3_828 DSL Driver Version, FwVer:5.6.36.0_A_A60901[/quote]
    #6225
    byrallier
    • Replies 21
    I don’t know why but My wifis have experienced unstable connection with the latest update
    DSL-AC55U
    v9.1.2.3_828
    #6227
    • Replies 8,721
    [quote quote=6225]I don’t know why but My wifis have experienced unstable connection with the latest update DSL-AC55U v9.1.2.3_828[/quote]
    That is odd, as the changelog makes no mention of any wifi updates, what version of firmware was you running previously ?
    If a much older version, maybe worth a factory reset and configure from scratch to see if issue remains ?
    Hopefully other DSL-AC55U owners can add value/comment
    #6229
    Avatarlostcause
    • Replies 53
    [quote quote=6202]
    Thank you Sentinel & Asus, great update ! Curious to see if this FW will make it past 6 days uptime. Fingers crossed ;-)
    Let us know how it goes [/quote]
    Still cant make it past 6 days without a reboot. Free mem drops to 4MB before each reboot.
    Seems no one else has this issue ?, so I have enabled the 5G radio with default settings to see if that might help to get it past 6 days.
    #6233
    • Replies 8,721
    Under System Log – General Log and DSL Log, are the uptimes the same – I cannot remember but if the times are the same then probable as you say a  Memory usage problem, caused by a service like wifi or AiProtection (if applicable) etc.
    Is the router doing anything special, like handling lots of wifi clients / VPN ?
    #6236
    Avatarlostcause
    • Replies 53
    [quote quote=6233]Under System Log – General Log and DSL Log, are the uptimes the same – I cannot remember but if the times are the same then probable as you say a Memory usage problem, caused by a service like wifi or AiProtection (if applicable) etc. Is the router doing anything special, like handling lots of wifi clients / VPN ?[/quote]
    Uptimes are the same, it just konks out every 6 days with around 4MB free memory.
    The router load is light (2-4 clients) and I am almost running default settings. No VPN, no Telnet , no UPnP.
    I am pinging the router every second over ethernet to keep my powerline adapter alive, but I assume this wont matter.
    #6237
    • Replies 8,721
    Are CRC values reasonable ?
    show us your DSL log / status page if u can ?
    #6238
    Avatarlostcause
    • Replies 53
    Thanks Sentinel,
    CRC is always 0/0 (capped VDSL line 5 MBit/3 MBit)
    Never had it running for more than 14 days without a reboot, but the latest FW’s last only 6 days.
    Must be some setting I use, or its just a firmware memory leak.
    Have enabled 5G again and disabled time settings, will see if that helps first.
    #6239
    • Replies 8,721
    Are you sure that it is VDSL (PTM) or should it be ADSL (ATM) as your synch / capped speed is low ?
    PPPoE / PPPoA
    Good luck with testing
    #6240
    Avatarlostcause
    • Replies 53
    [quote quote=6239]Are you sure that it is VDSL (PTM) or should it be ADSL (ATM) as your synch / capped speed is low ? PPPoE / PPPoA Good luck with testing[/quote]
    I understand why you would think that ;-) See screenshot.
    Very happy with the AC51 router so far, except for this reboot / memory leak issue.
    The last to syslog entries just before it reboots after ~6 days.
    2020-03-24 22:00:34 [Informational] kernel: MTPciPollTxRxEmpty
    2020-03-24 22:00:35 [Informational] kernel: br0: port 6(ra1) entering forwarding state
    #6243
    • Replies 8,721
    you do have an INP-SHINE issue, https://uktechhub.com/forums/topic/dsl-modem-and-router-technical-terms-and-abbreviations-etc/
    Some models have the option for ESNP under DSL Settings (enhanced sudden noise protection) is this ON ?
    #6244
    Avatarlostcause
    • Replies 53
    [quote quote=6243]
    Some models have the option for ESNP under DSL Settings (enhanced sudden noise protection) is this ON ?[/quote]
    It’s on default through DLA. Have some noise spikes on the line.
    #6247
    Avatarlostcause
    • Replies 53
    Switched ESNP to stable. Lower training speed as expected.
    I think the INP settings are set (too high) by the DSLAM.
    • Replies 8,721
    Alas the MediaTek DSL chipsets in these routers are very sensitive and you have a noisy line
    Just for testing, disable G.inp and reboot router, if after a say or so nothing looks any better, then disable UPBO as in UK. this has caused massive problems for others users at exchanges/dslams on upstream transmit signal strength.
    UPBO – Upstream Power Back Off
    Very high-speed digital subscriber line (VDSL) upstream data transmission in a distributed environment will suffer from relatively strong far-end crosstalk generated by the shorter lines in the binder. This effect can dramatically reduce the upstream capacity on longer lines. To secure the capacity on lines of all lengths, shorter lines will be required to systematically reduce their transmit power. This power reduction is known as (upstream) power backoff (PBO or UPBO)
    #6251
    Avatarlostcause
    • Replies 53
    Disabled G.INP but adds 30ms to my latency due to ridiculous interleaved settings.
    Also added pic of ISP modem, its on 35b profile which I cannot choose on the AC51. Purchased it before they switched to VDSL.
