- This topic has 1,129 replies, 77 voices, and was last updated 1 year, 7 months ago by
March 26, 2020 at 10:46 am #6254March 26, 2020 at 11:54 am #6256
[quote quote=6254]What is your ISP Modem model ?[/quote]
ZTE ZXHN H288A
Agree with you Sentinel there is something weird with the INP values. However the line is very stable and for now I am only concerned with the 6 day reboot issue. Which is why I have put some settings back to default. And have to wait another 6 days to see if it has any effect , hehe ;-)
March 26, 2020 at 1:05 pm #6258No problem, I spoke with ASUS and the DSL-AC51U does not support 35b Profile but was told that it should synch OK via VDSL 17a for your speeds and work just fine.
Looks like a weekly reboot is the only way around this
March 27, 2020 at 9:54 am #6263FYI
ASUS have notified me of the following:
For MT751x based models, recent beta firmware release v9.1.2.3_828, there is possible ADSL sync issue. It’s just been identified today.
However, no issue if connect to VDSL2. So for customers using ADSL and raised concern, please help to inform customers to revert back to earlier official v1.1.2.3_805, which is available on support site.
In the meantime, we are working on updated version, will be available early next week
March 28, 2020 at 7:16 am #6275[quote quote=6258]No problem, I spoke with ASUS and the DSL-AC51U does not support 35b Profile but was told that it should synch OK via VDSL 17a for your speeds and work just fine. Looks like a weekly reboot is the only way around this
[/quote]Still got 8 MB free RAM now after 4 days runtime, so I am definitely moving in the right direction….
BTW thanks for the above update
March 30, 2020 at 8:29 am #6289Updated beta firmware now available that fixes earlier ADSL sync problems
v9.1.2.3_835-g5ced613 (UKTH)
https://www.asuswebstorage.com/navigate/a/#/s/50F2BE9BC89E44F98860E933B7D0E618Y
Note: Normal ASUS Beta Firmware T&C’s apply, see top of forum
March 31, 2020 at 11:55 pm #6296[quote quote=6289]Updated beta firmware now available that fixes earlier ADSL sync problems v9.1.2.3_835-g5ced613 (UKTH) https://www.asuswebstorage.com/navigate/a/#/s/50F2BE9BC89E44F98860E933B7D0E618Y Note: Normal ASUS Beta Firmware T&C’s apply, see top of forum[/quote]
Made it past 6 days runtime for the first time in a long time.
Now I have to revert the changes I made one by one to see which setting is causing the memory leak and sub-sequential reboot every 6 days.Attachments:
April 1, 2020 at 6:20 am #6299April 1, 2020 at 8:11 am #6301From Firmware Version:v9.1.2.3_835
36 hours,
RAM: 56 mb used, 67 mb free
CPU Core 1: ~%7CRCs:
April 1, 2020 at 8:29 am #6303[quote quote=6301]From Firmware Version:v9.1.2.3_835 36 hours, RAM: 56 mb used, 67 mb free CPU Core 1: ~%7 CRCs:[/quote]
April 1, 2020 at 10:30 am #6304[quote quote=6299]What was memory usage / free memory value after seven days ?[/quote]
7 MB free (DSL-AC51) after 7 days.
With the old settings it went down to 4 MB free within 6 days, and rebooted every 6 days.
Will leave it running a few days more to see what it does.You need to login in order to vote
April 1, 2020 at 10:42 am #6305[quote quote=6304]
7 MB free (DSL-AC51) after 7 days. With the old settings it went down to 4 MB free within 6 days, and rebooted every 6 days. Will leave it running a few days more to see what it does.[/quote]
April 2, 2020 at 6:35 am #6300[quote quote=6296]
Düzeltmeleri önceki ADSL senkronizasyon problemleri (UKTH)-g5ced613 v9.1.2.3_835 o firmware anda mevcut Güncelleme beta https://www.asuswebstorage.com/navigate/a/#/s/50F2BE9BC89E44F98860E933B7D0E618Y Normal ASUS Beta Firmware T & C’ler uygulamak, bkz: Not forumun başı
Uzun bir süre içinde ilk kez 6 gün çalışma süresi yaptı. Şimdi, hangi ayarın her 6 günde bir bellek sızıntısına ve alt sıralı yeniden başlatmaya neden olduğunu görmek için yaptığım değişiklikleri tek tek geri almalıyım.[/quote]TURKTELEKOM IPTV TIVIBU does not work with this firmware …
April 2, 2020 at 6:42 am #6312[quote quote=6300]
Uzun bir süre içinde ilk kez 6 gün çalışma süresi yaptı. Şimdi, hangi ayarın her 6 günde bir bellek sızıntısına ve alt sıralı yeniden başlatmaya neden olduğunu görmek için yaptığım değişiklikleri tek tek geri almalıyım.TURKTELEKOM IPTV TIVIBU does not work with this firmware …[/quote]
Did older firmware work, if so maybe try a factory rest to make sure nothing is damaged during the update ?
are you on ADSL or VDSL ?
April 2, 2020 at 10:41 am #6313[quote quote=6300]Did older firmware work, if so maybe try a factory rest to make sure nothing is damaged during the update ?[/quote]
We have more testers from Turkey, Hoşgeldin Yakup :)
Please, post your dsl logs and other detailsYou need to login in order to vote
