Viewing 15 posts - 241 through 255 (of 1,130 total)
  • #6314
    • Replies 8,687
    The ‘Testing Team from Turkey’ – Welcome
    #6318
    AvatarHirakis
    • Replies 2
    Hi! Where is DSL-N66U firmware ???
    #6319
    • Replies 8,687
    Welcome, alas the DSL-N66U is no longer supported by ASUS for firmware updates
    The latest copy of the DSL-N66U firmware we have is – DSL-N66U_v9.1.2.3_790-g61d41b5.trx
    https://uktechhub.com/forums/topic/latest-dsl-asuswrt-firmware-v9-1-2-3_502-g2bdb05b-now-available/page/12/#post-5820
    #6326
    AvatarAlexandr82
    • Replies 2
    Why is the more expensive model no longer supported, while different cheaper models are supported?
    #6327
    • Replies 8,687
    Big business and commercial outsourcing strategy not working as expected
    #6328
    Avatarboyelroy
    • Replies 10
    VPN still not work. if add new vpn, not connected. but if add on at very old firmware, VPN work.
    (DSL-AC51, fw .835)
    2020-04-06 18:16:20 [Informational] WEB: Configuration changed: LogAccess_ClearLog
    2020-04-06 18:16:57 [Informational] kernel: tun: Universal TUN/TAP device driver, 1.6
    2020-04-06 18:16:57 [Informational] kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    2020-04-06 18:16:57 [Informational] kernel: ADDRCONF(NETDEV_UP): tun14: link is not ready
    2020-04-06 18:16:57 [Informational] kernel: device tun14 entered promiscuous mode
    2020-04-06 18:16:57 [Notice] vpnclient4[29543]: OpenVPN 2.4.7 mips-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Mar 28 2020
    2020-04-06 18:16:57 [Notice] vpnclient4[29543]: library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.09
    2020-04-06 18:16:57 [Warning] vpnclient4[29547]: NOTE: the current –script-security setting may allow this configuration to call user-defined scripts
    2020-04-06 18:16:57 [Notice] vpnclient4[29547]: TCP/UDP: Preserving recently used remote address: [AF_INET]91.xxx.xxx.xxx:0
    2020-04-06 18:16:57 [Notice] vpnclient4[29547]: Socket Buffers: R=[124928->124928] S=[124928->124928]
    2020-04-06 18:16:57 [Notice] vpnclient4[29547]: UDP link local: (not bound)
    2020-04-06 18:16:57 [Notice] vpnclient4[29547]: UDP link remote: [AF_INET]91.xxx.xxx.xxx:0
    2020-04-06 18:16:57 [Error] vpnclient4[29547]: write UDP: Invalid argument (code=22)
    2020-04-06 18:16:57 [Informational] WEB: Configuration changed: VPNC_Entry
    2020-04-06 18:16:59 [Error] vpnclient4[29547]: write UDP: Invalid argument (code=22)
    2020-04-06 18:17:03 [Error] vpnclient4[29547]: write UDP: Invalid argument (code=22)
    2020-04-06 18:17:12 [Error] vpnclient4[29547]: write UDP: Invalid argument (code=22)
    #6329
    • Replies 8,687
    @boyelroy – Can you send ASUS a feedback form via routers UI and mention at the beginning you have spoken with UK Sentinel and write about your VPN issue.
    Let me know when you have done this and I will speak to them
    #6330
    Avatarboyelroy
    • Replies 10
    feedback sended ;)
    #6331
    • Replies 8,687
    feedback sended ;)
    #6337
    • Replies 8,687
    @boyelroy  – ASUS wish to contact you, is your email address the same as the one you have used for this forum and can I use this to give to ASUS ?
    #6338
    Avatarboyelroy
    • Replies 10
    yes.
    #6339
    • Replies 8,687
    yes.
    I will PM you
    Update: PM Sent
    #6435
    Avatarlecoq
    • Replies 5
    I have v9.1.2.3_835  installed on my AC750. Router’s admin panel notifies me of a new version which is 1.1.2.3_805. Should I ignore it? 835 seems to be newer, why is the first digit is 9 in the beta?
    #6436
    • Replies 8,687
    Yes, any ASUS DSL firmware  release which starts with a 9 is a beta version, I would keep your v9.1.2.3_835 unless your are experiencing problems
    #6464
    • Replies 8,687
    Latest DSL ASUSWRT beta firmware v9.1.2.3_854-g837bd26 now available.
    Note; Normal ASUS  beta Firmware T&C’s applies, see top of Forums
    2020_04_16_v9.1.2.3_854-g837bd26
    https://www.asuswebstorage.com/navigate/a/#/s/EEAC28BE937F42628055856245A0B366Y
    Changelog:
    • Fixed Web UI related issues.
    • Clear button now added for Web UI > Web History Log/ Access Log.
    • OpenVPN related enhancements adopted.
