Viewing 15 posts - 256 through 270 (of 1,130 total)
  • #6486
    • Replies 8,738
    post duplicate (removed)
    #6488
    AvatarHirakis
    • Replies 2
    Why DSL-N66U  model is no longer supported while other models (older and cheaper) are still supported ????
    #6490
    • Replies 8,738
    [quote quote=6488]Why DSL-N66U model is no longer supported while other models (older and cheaper) are still supported ????[/quote]
    Alas a while ago, ASUS unofficially supported the DSL-N66U even beyond its EOL (end of life) status, alas somebody complained (long story) and ASUS decided to stop supporting this unit and a few others.
    The main reason why the DSL-N66U reached it EOL (my opinion)  is its DSL processor is RALINK, where most of the other DSL chipsets are MediaTek (I believe)
    #6509
    Avatarlecoq
    • Replies 5
    With 854 installed, I see a more stable 5Ghz connection.
    My AC68U used to download at 87 Mbit/s on iPhone 7, now I’m on an AC750 and my maximum download speed is only 60 Mbit/s on iPhone 11 Pro. I miss my AC68U, it stopped working after 3 years usage and Asus did not repair it.
    #6510
    • Replies 8,738
    [quote quote=6509]With 854 installed, I see a more stable 5Ghz connection. My AC68U used to download at 87 Mbit/s on iPhone 7, now I’m on an AC750 and my maximum download speed is only 60 Mbit/s on iPhone 11 Pro. I miss my AC68U, it stopped working after 3 years usage and Asus did not repair it.[/quote]
    Good news about 5Ghz stability, lots of cheap AC68u on Ebay
    #6511
    Avatarlostcause
    • Replies 53
    [quote quote=6464]Latest DSL ASUSWRT beta firmware v9.1.2.3_854-g837bd26 now available. Note; Normal ASUS beta Firmware T&C’s applies, see top of Forums 2020_04_16_v9.1.2.3_854-g837bd26 https://www.asuswebstorage.com/navigate/a/#/s/EEAC28BE937F42628055856245A0B366Y Changelog:
    • Fixed Web UI related issues.
    • Clear button now added for Web UI > Web History Log/ Access Log.
    • OpenVPN related enhancements adopted.
    [/quote]
    Thanks for the update !
    Have not installed it yet as I’m still honing in on the reboot bug. Getting close now… ;-)
    #6512
    • Replies 8,738
    [quote quote=6511]
    Thanks for the update ! Have not installed it yet as I’m still honing in on the reboot bug. Getting close now… ;-)[/quote]
    #6582
    Avatarmerrychap
    • Replies 1
    Hello everybody!
    I have the router ASUS DSL-N66U. Can you post a screenshot of the IPv6 menu after the firmware to version DSL-N66U_v9.1.2.3_790-g61d41b5?
    Thank you in advance and I look forward to your prompt reply!
    Best regards,
    Aleksey
    #6583
    • Replies 8,738
    Firmware DSL-N66U_v9.1.2.3_790-g61d41b5 is the newest firmware available for the DSL-N66U, hopefully someone will be able to help with IPv6 screen shot
    Unsure if you are aware, the DSL-N66U is no longer supported by ASUS
    #6640
    Avatarlostcause
    • Replies 53
    Free memory DSL-AC51 is dropping to 4 MB within 6 days , and then it usually reboots. But this time it managed to save itself by freeing up memory to 8 MB. See log.
    Note: Free memory dropping to 4 MB within 6 days is due to my particular settings. Other users will likely not experience this.
    Will reboot it manually and see what happens the next 6 days.
    2020-04-23 05:38:10 [Informational] kernel: tcphy[1]: Link-down!!!
    2020-04-23 05:38:10 [Informational] kernel: Link State: LAN_2 down.
    2020-04-23 05:42:11 [Warning] kernel: mtd: page allocation failure. order:4, mode:0x40d0
    2020-04-23 05:42:11 [Informational] kernel:
    2020-04-23 05:42:11 [Informational] kernel: Call Trace:
    2020-04-23 05:42:11 [Informational] kernel: [<8000bf10>] dump_stack+0x8/0x34
    2020-04-23 05:42:11 [Informational] kernel: [<8008adcc>] __alloc_pages_nodemask+0x51c/0x69c
    2020-04-23 05:42:11 [Informational] kernel: [<8008af64>] __get_free_pages+0x18/0x4c
    2020-04-23 05:42:11 [Informational] kernel: [<801ab098>] mtd_read+0x2ac/0x2c4
    2020-04-23 05:42:11 [Informational] kernel: [<800b3d28>] vfs_read+0xc0/0x15c
    2020-04-23 05:42:11 [Informational] kernel: [<800b3eec>] sys_read+0x58/0xc0
    2020-04-23 05:42:11 [Informational] kernel: [<80004450>] stack_done+0x20/0x40
    2020-04-23 06:00:26 [Informational] kernel: ##### mbss_cr_enable, BssId = 1
    2020-04-23 06:00:26 [Informational] kernel: br0: port 6(ra1) entering forwarding state
    2020-04-23 06:03:15 [Informational] kernel: AP SETKEYS WPA2 MAC=5C:1D:D9:41:1E:B8
    2020-04-23 06:57:20 [Alert] monitorcfgmgr[374]: cfg_manager is er.
    2020-04-23 06:57:20 [Alert] monitorcfgmgr[374]: restart cfg_manager!!
    2020-04-23 06:57:21 [Debug] kernel: cfg_manager used greatest stack depth: 8028 bytes left
    2020-04-23 06:57:22 [Informational] kernel: arpstorm_init
    2020-04-23 06:57:22 [Informational] kernel: The number of cache node is 5
    2020-04-23 06:57:22 [Informational] kernel: [restore_tmp_romfile, 186]restore file(/tmp/var/romfile.cfg)
    2020-04-23 06:57:22 [Informational] kernel: [restore_tmp_romfile, 199]restore success.
    2020-04-23 06:57:22 [Informational] kernel: lanHost_read: Create node LanHost !
    2020-04-23 06:57:22 [Informational] kernel: Link State: PVC_8_0 logistic interface up.
    2020-04-23 06:57:22 [Informational] kernel: Link State: LAN_1 up.
    #6644
    • Replies 8,738
    Great news about memory usage and finally working well for you and your settings
    (I will relay this positive news back to ASUS)
    #6646
    Avatarlostcause
    • Replies 53
    [quote quote=6644]Great news about memory usage and finally working well for you and your settings (I will relay this positive news back to ASUS) [/quote]
    Think this time was just lucky that it freed-up RAM by itself. Will report the setting bug once I am sure about it.
    Not a big deal, just for reporting to the Asus FW team.
    #6647
    • Replies 8,738
    [quote quote=6646]
    Think this time was just lucky that it freed-up RAM by itself. Will report the setting bug once I am sure about it. Not a big deal, just for reporting to the Asus FW team.[/quote]
    #6807
    byrallier
    • Replies 21
    I couldn’t keep track the subject for a while and I see the new version 854. Now I am going to upgrade it guys
    #6808
    • Replies 8,738
    [quote quote=6807]I couldn’t keep track the subject for a while and I see the new version 854. Now I am going to upgrade it guys[/quote]
