- July 5, 2021 at 10:35 am #14225
Ok, so have had several conversations with ASUS and seems they did deploy OpenSSL 1.1 but had issues so it was rolled back to OpenSSL 1.0.2d until the bugs are fixed.
July 7, 2021 at 4:24 pm #14250July 7, 2021 at 4:43 pm #14254[quote quote=14250]Latest beta firmware working good on DSL-AC51 Devre dışı means DISABLED Etkin means ACTIVE[/quote]
Welcome and thanks for letting us all know
August 14, 2021 at 11:51 pm #14697üstad modemde dsl ayarı yapınca modem hemen bağlanmıyor internete, bunun çözümü var mı ?
August 15, 2021 at 6:41 am #14699August 15, 2021 at 9:37 am #14700sorry. my DSL51 modem takes a very long time to connect back when my internet connection is lost. Is there any solution for this?
i use latest beta firmware.(946)
also i need latest beta firmware for n16p modem. Can you help me please about this?
August 15, 2021 at 10:15 am #14702Welcome.
The DSL-AC51 can take upto 5 minutes to connect, is that simular to yours ?
If your internet drops regularly, try…
at wan>internet connection>additional pppd options … insert the command
lcp-echo-interval 0
If 0 will not connect, try the commands 60,50,40,30
also
August 15, 2021 at 10:19 am #14703My internet connection is not interrupted regularly, but when I SET DSL, the internet disconnecting and does not connect to the internet for about 5 minutes. I tried that command you gave, but the result did not change.
August 15, 2021 at 10:21 am #14705August 15, 2021 at 10:46 am #14706August 15, 2021 at 1:38 pm #14710Check if your VDSL profile is 17a or 30a, I think in your country it should be 17a ?
Make sure ‘disconnect after time of inactivity (in seconds)’ is set to ‘0’
Also set .
Internet Detection: PPP Echo
PPP Echo Interval: 0
PPP Echo Max Failures: 0
If this does not help, try changing DNS Servers IP address on router ?
August 15, 2021 at 3:41 pm #14711August 15, 2021 at 3:51 pm #14713[quote quote=14711]please DSL-AC55U Beta firmware v9.1.2.3_946-gbd5b43b reload. Link broken… Thanks…[/quote]
Welcome, I will ask ASUS for a new link for the DSL-AC55U Beta firmware v9.1.2.3_946-gbd5b43b
August 15, 2021 at 4:54 pm #14714I did all of what you said but unfortunately the result did not change… The DSL light comes on immediately, but the internet light takes a minimum of 3-4 minutes.
August 15, 2021 at 5:34 pm #14715[quote quote=14714]I did all of what you said but unfortunately the result did not change… The DSL light comes on immediately, but the internet light takes a minimum of 3-4 minutes.[/quote]
Alas I am out of ideas, hopefully somebody else who owns an DSL-AC51 can advise how long there DSL-AC51 takes to connect to Internet ?
3-4 minutes does not sound long time to me, hopefully others can confirm time also
