- January 26, 2022 at 7:23 pm #17401
In this version, after connecting to vpn l2tp and pptp, the modem will restart when disconnected. Please report to Asus
January 26, 2022 at 7:25 pm #17402[quote quote=17353]So ASUS have come back and they have spoken with the Chipset Venodor, they have agreed that SNR has changed to 15 dB A new firmware below with the adjustments to try for the DSL-AC51 only – if feedback is positive, the change will be made to other MediaTek based modem/routers also in future firmware’s for other models (factory reset advisable) I have made the firmware only available for members to download, as this is a test firmware version. DSL-AC51_9.1.2.3_960-g795fbf6.trx.zip (28 downloads) [/quote]
January 26, 2022 at 7:59 pm #17403[quote quote=17401]In this version, after connecting to vpn l2tp and pptp, the modem will restart when disconnected. Please report to Asus[/quote]
I will inform ASUS of VPN disconnects
January 26, 2022 at 8:02 pm #17404[quote quote=17403]
<noscript>
</noscript>[/quote]i returned 959 and no problem nowly.
January 26, 2022 at 9:20 pm #17406[quote quote=17404]i returned 959 and no problem nowly.[/quote]
Are you using 959 now ?
January 26, 2022 at 9:35 pm #17408[quote quote=17406]
Are you using 959 now ?[/quote]
yes. i hate from late connection problem at 960. And i solved crc problems at 959.
January 26, 2022 at 9:53 pm #17411[quote quote=17408]yes. i hate from late connection problem at 960. And i solved crc problems at 959.[/quote]
Apart from delayed connection issue with 960 and 2x CRC, was stability better ?
January 26, 2022 at 10:29 pm #17412[quote quote=17411]
Apart from delayed connection issue with 960 and 2x CRC, was stability better ?[/quote]
I couldn’t find any help at 960.
January 27, 2022 at 7:41 am #17413Did 960 firmware force SNR at 15dB ?
Any feedback I can pass to ASUS to help them make the next firmware better ?
January 27, 2022 at 9:31 am #17417[quote quote=17413]Did 960 firmware force SNR at 15dB ? Any feedback I can pass to ASUS to help them make the next firmware better ?[/quote]
no 960 fw didnt force 15db, i could adjust snr margin..
Everything is ok nowly for 959v.. I wont pass any version to fix late connection problem. I happy with 959.
January 27, 2022 at 9:41 am #17418Understood, if any body else is using this firmware and was experiencing DSL stability issues, did leaving the SNR at 15dB make the DSL connection more stable, less DSL disconnections ?
January 27, 2022 at 10:34 am #17420[quote quote=17418]Understood, if any body else is using this firmware and was experiencing DSL stability issues, did leaving the SNR at 15dB make the DSL connection more stable, less DSL disconnections ?[/quote]
my iss default snr is 8. I use 102mbps vdsl2. So i dont know how is 15db. Now i pulled my snr to 3db, and no problem
January 27, 2022 at 1:04 pm #17421Do you have many CRC with 8 or 3dB ?
Have you tried SNR to 15dB to see if CRC reduce ?
January 27, 2022 at 3:01 pm #17422[quote quote=17421]Do you have many CRC with 8 or 3dB ? Have you tried SNR to 15dB to see if CRC reduce ?[/quote]
When I set the snr to 15db, I do not get Crc errors in any version. I will write like this; For 960 version, same settings same 3db higher Crc error. Same settings same 3db I get less Crc error in 959 version.
January 27, 2022 at 5:21 pm #17425[quote quote=17422]When I set the snr to 15db, I do not get Crc errors in any version. I will write like this; For 960 version, same settings same 3db higher Crc error. Same settings same 3db I get less Crc error in 959 version.[/quote]
Perfect,
Edit: Do you have many DSL line disconnects with 3dB SNR with .959 ?
