February 14, 2022 at 11:56 am #17818
I am not sure when the CRC bursts happen. I just see them on the log, so I don’t know when they are happening. I’ll do the radio test though, to detect if there are any faulty devices around. Do you think a DSL splitter would help something like this, or there are other types of filters that might work for these kind of errors?
February 14, 2022 at 1:42 pm #17819Hard to say if DSL filter will help, depends where the original errors / interference are being created from.
Keep an eye on the log, to see if you can establish how often the CRC burst happen ?
February 14, 2022 at 7:03 pm #17821I’ve checked the general log if there are any downtimes, this is what I’ve found:
2022-02-11 23:44:37 kernel: tcphy[1]: Link-down!!!
2022-02-11 23:44:37 kernel: Link State: LAN_2 down.2022-02-12 04:00:02 kernel: tcphy[1]: Link-down!!!
2022-02-12 04:00:04 kernel: tcphy[1]: Link-up at 100F. tx_amp_save=0.2022-02-12 04:00:52 kernel: tcphy[1]: Link-down!!!
2022-02-12 04:00:53 kernel: Link State: LAN_2 down.2022-02-12 06:00:59 kernel: tcphy[1]: Link-down!!!
2022-02-12 06:01:00 kernel: Link State: LAN_2 down.2022-02-12 09:55:29 kernel: tcphy[0]: Link-down!!!
2022-02-12 09:55:30 kernel: Link State: LAN_1 down.2022-02-12 12:57:42 kernel: tcphy[0]: Link-down!!!
2022-02-12 12:57:42 kernel: Link State: LAN_1 down.2022-02-13 00:19:59 kernel: tcphy[1]: Link-down!!!
2022-02-13 00:19:59 kernel: Link State: LAN_2 down.2022-02-13 00:24:18 kernel: tcphy[0]: Link-down!!!
2022-02-13 00:24:19 kernel: Link State: LAN_1 down.2022-02-13 04:00:02 kernel: tcphy[1]: Link-down!!!
2022-02-13 04:00:03 kernel: tcphy[1]: Link-up at 100F. tx_amp_save=0.2022-02-13 04:00:46 kernel: tcphy[1]: Link-down!!!
2022-02-13 04:00:46 kernel: Link State: LAN_2 down.2022-02-13 06:00:56 kernel: tcphy[1]: Link-down!!!
2022-02-13 06:00:57 kernel: Link State: LAN_2 down.2022-02-13 10:30:30 kernel: tcphy[0]: Link-down!!!
2022-02-13 10:30:30 kernel: Link State: LAN_1 down.Probably I’m getting CRC jumps during these moments. One weird thing though, there is a consistency around 4 am and 6 am. I don’t think there are any devices working around the home at that hour :)
February 14, 2022 at 7:50 pm #17822These may note relate to CRC ? and ca n be a setting on PC “wake up lan” via Ethernet
Whats plugged into LAN1 and LAN 2 ?
February 15, 2022 at 4:11 am #17825LAN1 is connected to pc.
LAN2 is connected to TV.
Is it just about turning off these devices? I wasn’t using internet at those hours so I don’t know if the DSL link was down or not.
February 15, 2022 at 7:35 am #17826If you can unplug Ethernet cable from TV and PC tonight, and see if ‘ Link State: LAN_1 down’ log message appears overnight, (for test purposes)
February 15, 2022 at 8:49 am #17827February 15, 2022 at 9:06 am #17829[quote quote=17827]I’ll try that tonight, thanks for the suggestion :)[/quote]
February 18, 2022 at 1:12 pm #17856February 18, 2022 at 2:48 pm #17857[quote quote=17856]we need new firmware with updated kernel[/quote]
Send ASUS a feedback form and make request for new Firmware with updated Kernel
February 18, 2022 at 3:33 pm #17858[quote quote=17857]
<noscript><noscript>
<noscript>
</noscript>[/quote]Looks like ASUS gave up on the ac51 :(
February 18, 2022 at 4:19 pm #17859[quote quote=17858]Looks like ASUS gave up on the ac51 :([/quote]
February 24, 2022 at 11:09 am #17936Asus was released a new official firmware for AC-750
Version 1.1.2.3_960
2022/02/22ASUS DSL-AC750 Firmware version v1.1.2.3_960 (This product supports both Annex A and Annex B)
Security:
– [Wi-Fi] FragAttacks WiFi Security Vulnerabilities
– [Web] Enhanced protection against XSS attacks.
– [Wi-Fi] Fix the vulnerability of KR00K (CVE-2019-15126).
– [LPRng] Fix the issue that lpd crashed caused by nmap attack.
– [Web] Fix the vulnerability in the network analysis command.DSL:
– VDSL WAN (PTM) QIS manual setting list updated, added Lebanon ISP Ogero, Australia ISP Superloop and Croatia ISP Hrvatski Telekom (TCom).
– [dsl] Set MCT tlb parameter for dmt.
– [DLA] Drop changing modulation to G.DMT.
– [DSL] Add ‘G.INP Stability Adjustment’ option for VDSL in DSL Setting > VDSL section.Bug fixes and enhancements:
– [Wi-Fi] Fix sometimes 2.4G Wireless cannot use iPhone Airplay to Apple TV.
– [Wi-Fi] Fix some customers might not be able to connect to WiFi 5G again after using it for a long time.
– [Wi-Fi] Fix the problem that the DUT crashes when running stress on PON and Wi-Fi for a long time.
– [OPENVPN] Fix openvpn client does not work when there is no “port” in the configuration file.
– [DDNS][Web] Fix unable to login after using DDNS(https 8443 port) for about 3 days.
– [diagnostic] Fix the loss of DSL / WiFi Diagnostic and inaccurate time issue.
– Support option, lcp-echo-adaptive.
– [WLAN][5G] Fix DUT restarts without triggering the force update mechanism.
– [QIS] Set pre-filled ppp login/password for United Kingdom/Scotland/Ireland ISP: BT braodband & BT Business & BT infinity.
– [Web UI] Correct field naming “Class-identifier (option 61)”.
– [Web] Correct time zone ‘Novosibirsk’ in Russia.
– [Web UI] Add a validation to validate target URL.
– [Web] Fix js errors.
– Fix the problem of for IPv6 PPPoE.
– [OPENVPN] update openvpn for CVE.
– [DSL] Enhanced the time for DSL WAN recover from disconnection.
– [Web] Set Stability Adjustment(VDSL) to 15 dB while manual setting area to Turkey.Please unzip the firmware file first then check the MD5 code.
MD5: 8f91c36eb77af3b1b51ffe16aa7cd38chttps://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AC750/FW_DSL-AC750_1123960.zip
February 24, 2022 at 11:37 am #17937February 24, 2022 at 12:00 pm #17938 -
