April 21, 2022 at 10:03 am #18741April 21, 2022 at 1:47 pm #18742
Ok, so I spoke with ASUS and they have confirmed what we all had thought in that the DSL-AC750 and simular will not support DDNS behind CGNAT.
Unsure of timescales but ASUS have agreed to add DNS over TLS (DoT) support to the DSL-ASUSWRT (MediaTeK) based modem/routers
Back to my day job now
April 21, 2022 at 6:59 pm #18743[quote quote=18729]ASUS have kindly given me two early release beta firmware’s (DSL-AC52U – DSL-AC51) which have the following fixes. ASUS are currently still working on the reported OPEN VPN bug- but this will be released very soon
- OPENSSL bug,
- enable DDNS support SSL for DNS-O-Matic issue.
DSL-AC52U_v9.1.2.3_972-g3171d62.zip https://www.asuswebstorage.com/navigate/a/#/s/4FF935BD81C843DC93B52E2112725192Y DSL-AC51_v9.1.2.3_972-g3171d62.zip https://www.asuswebstorage.com/navigate/a/#/s/537B9D3067BA437FBDA24A5D2AE727EAY —— Edit: ASUS have also released the same fixes (as above) for the DSL-AC750 DSL-AC750_v9.1.2.3_972-g3171d62.zip https://www.asuswebstorage.com/navigate/a/#/s/7312658A25A74B5E873768BFAD503F72Y —— Note: Usual UKTH ASUS Beta Firmware Policy applies (top of Forum)[/quote]
Thanks, it solved the DDNS issue but unfortunately my ISP has decided to put in CGNAT on this week
. Hope that DNS server can accept domain name when the DoT feature is available.You need to login in order to vote
April 21, 2022 at 7:26 pm #18745[quote quote=18743]Thanks, it solved the DDNS issue but unfortunately my ISP has decided to put in CGNAT on this week . Hope that DNS server can accept domain name when the DoT feature is available.[/quote]
Will be an interesting experiment for your
April 21, 2022 at 8:45 pm #18746[quote quote=18742]Ok, so I spoke with ASUS and they have confirmed what we all had thought in that the DSL-AC750 and simular will not support DDNS behind CGNAT. Unsure of timescales but ASUS have agreed to add DNS over TLS (DoT) support to the DSL-ASUSWRT (MediaTeK) based modem/routers
[/quote]Thanks, that is great news.
April 26, 2022 at 6:57 pm #18829April 26, 2022 at 7:54 pm #18832[quote quote=18829]any new fw??[/quote]
I will check progress with ASUS
April 27, 2022 at 8:44 am #18844[quote quote=18829]any new fw??[/quote]
Ok, so I spoke with ASUS and the DSL-N14U is now officially EOL (End of Life)
ASUS have kindly created one last firmware for the DSL-N14U and have added to my list of EOL firmware’s for ASUS DSL routers
I will email you the link for this firmware release and UKTH ASUS Beta T&C’s apply etc.
Enjoy
April 27, 2022 at 9:40 am #18845April 28, 2022 at 7:37 pm #18855can i use the dsl n14u as ap?because i am moving to ftth and i have already setup a vpn server from the dsl n14u..
April 28, 2022 at 9:45 pm #18856[quote quote=18855]can i use the dsl n14u as ap?because i am moving to ftth and i have already setup a vpn server from the dsl n14u..[/quote]
I believe the DSL-N14U does not have a setting to automatically configure it as an Access Point, but you can manually configure the DSL-N14U to act like Access Point by manually turning DHCP off and also nat qos off and copy Wifi SSID etc.
Been a while since I have used a DSL-N14U and there is the WDS > AP option, but I seem to recall this was more trouble than it was worth ?
April 29, 2022 at 10:28 am #18862April 29, 2022 at 11:57 am #18863Look under Advanced Settings > Wireless > WDS
I thought the DSL-N14U had this option, it was 7 years ago the DSL-N14U was first released, so I maybe mistaken
April 29, 2022 at 11:57 pm #18865yes its under there..i am looking for ftth 200 Mb/s..can the dsln14 handle all the bandwidth?
April 30, 2022 at 6:57 am #18866AC[quote quote=18865]yes its under there..i am looking for ftth 200 Mb/s..can the dsln14 handle all the bandwidth?[/quote]
No it cannot !
Wireless N has a Maximum throughput: 450Mbps but in practice, especially due to hardware limitiations, 150Mbps is more likely.
The DSL-N14U has 4 LAN ports: each supporting 10Base-T/100Base-TX (100Mbps) max
