Viewing 15 posts - 211 through 225 (of 718 total)
  • #6781
    • Replies 8,724
    That is strange because @Bully is exact opposite to yours as his actual Synch speed/rate and Real Synch speed/rate have both increased whilst he has been using a Broadcom, modem,
    HG612 Modem Stats (Broadcom)
    Max: Upstream rate = 12136 Kbps, Downstream rate = 50748 Kbps
    Bearer: 0, Upstream rate = 12097 Kbps, Downstream rate = 39709 Kbps
    DrayTek Vigor Stats (Lantiq)
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10760000 bps
    DS Attainable Rate      : 44789800 bps   US Attainable Rate   : 10862952 bps
    #6782
    AvatarMrk26
    • Replies 465
    Yes, I see these and actually broadcom based modem improve on @Bully line where on mine this time cause more bad than good. I usually use broadcom modem to mantain line from interleave to fastpath, as you know. What happens yesterday, no idea, one of these bad memories which I would kike to erase from my memory 😜
    #6784
    • Replies 8,724
    [quote quote=6782]Yes, I see these and actually broadcom based modem improve on @Bully line where on mine this time cause more bad than good. I usually use broadcom modem to mantain line from interleave to fastpath, as you know. What happens yesterday, no idea, one of these bad memories which I would kike to erase from my memory 😜[/quote]
    (tech)
    #6785
    • Replies 8,724
    [quote quote=6750]Is the Below WAN setup correct?[/quote]
    See my WAN settings for comparison, only differences is (mine are all default)  my Bridge Type is IP_Bridged and you have 802.1p enabled and I do not .
    I think your Bridge Type should change if your are having problems  but not so sure regarding 802.1p as that is QoS and unsure if you have set this up. ?
    Mine seems to work well and no complaints from family as yet
    Bully
    • Replies 386
    Today’s Stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 6
    Max: Upstream rate = 12121 Kbps, Downstream rate = 50128 Kbps
    Bearer: 0, Upstream rate = 12015 Kbps, Downstream rate = 39617 Kbps
    Link Power State: L0
    Mode: VDSL2 Annex B
    VDSL2 Profile: Profile 17a
    TPS-TC: PTM Mode(0x0)
    Trellis: U:ON /D:ON
    Line Status: No Defect
    Training Status: Showtime
    Down Up
    SNR (dB): 6.1 6.1
    Attn(dB): 19.6 0.0
    Pwr(dBm): 13.4 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 15 20
    B: 25 238
    M: 1 1
    T: 64 31
    R: 10 16
    S: 0.0209 0.6330
    L: 13792 3223
    D: 2803 1
    I: 36 255
    N: 36 255
    Counters
    Bearer 0
    OHF: 28975885 94221
    OHFErr: 22 1
    RS: 96107058 404081
    RSCorr: 226629 2
    RSUnCorr: 105 0
    Bearer 0
    HEC: 14 0
    OCD: 1 0
    LCD: 1 0
    Total Cells: 887550679 0
    Data Cells: 126460610 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 71 7948
    SES: 40 93
    UAS: 115 251579
    AS: 68033
    Bearer 0
    INP: 8.00 0.00
    INPRein: 0.00 0.00
    delay: 14 0
    PER: 2.34 9.84
    OR: 71.55 21.11
    AgR: 39688.52 12036.07
    Bitswap: 46829/47149 1/1
    Total time = 1 days 1 hours 38 min 30 sec
    FEC: 1119500 64
    CRC: 17099 3
    ES: 71 7948
    SES: 40 93
    UAS: 115 251579
    LOS: 4 3
    LOF: 26 3
    LOM: 18 0
    Latest 15 minutes time = 8 min 30 sec
    FEC: 935 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 4227 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 1 hours 38 min 30 sec
    FEC: 17256 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 534737 61
    CRC: 9876 3
    ES: 40 2652
    SES: 23 31
    UAS: 47 83903
    LOS: 3 1
    LOF: 13 1
    LOM: 11 0
    Since Link time = 18 hours 53 min 53 sec
    FEC: 226629 2
    CRC: 22 1
    ES: 7 2652
    SES: 0 31
    UAS: 0 83878
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Stats recorded 27 Apr 2020 17:58:47
    DSL mode: VDSL2 Profile 17a
    Status: Showtime
    Uptime: 18 hours 56 min 53 sec
    Resyncs: 0 (since 27 Apr 2020 17:52:13)
    Downstream Upstream
    Line attenuation (dB): 19.6 0.0
    Connection speed (kbps): 39617 12015
    SNR margin (dB): 6.3 6.1
    Power (dBm): 13.4 6.7
    Interleave depth: 2803 1
    INP: 8.00 0
    Vectoring status: 5 (VECT_UNCONFIGURED)
    RSCorr/RS (%): 0.1767 0.0001
    RSUnCorr/RS (%): 0.0001 0.0000
    ES/hour: 8.57 0
    #6790
    AvatarMrk26
    • Replies 465
    Only FEC still bit high, rest looks O.K.
    However as your DLM card is on different fw than mime you may get fastpath, from this what I realised the one you are on is “more user friendly”.
    #6791
    Bully
    • Replies 386
    [quote quote=6785]
    See my WAN settings for comparison, only differences is (mine are all default) my Bridge Type is IP_Bridged and you have 802.1p enabled and I do not . I think your Bridge Type should change if your are having problems but not so sure regarding 802.1p as that is QoS and unsure if you have set this up. ? Mine seems to work well and no complaints from family as yet [/quote]
    Just after I took the above stats I matched my settings to yours.  It did not loose connection nor did it ask to reboot  and I did not do a manually reboot.
    #6792
    • Replies 8,724
    A reboot is probable required at some point, how’s the modem generally, r u happy with increased bandwidth, any lag on gaming, is modem still getting to hot etc ?
    #6793
    Bully
    • Replies 386
    [quote quote=6792]A reboot is probable required at some point, how’s the modem generally, r u happy with increased bandwidth, any lag on gaming, is modem still getting to hot etc ?[/quote]
    Modem is not getting too hot now. I am happy with the increased bandwidth, and is pretty solid.  Wish i could access stats through router.  Was thinking about connecting lan 2 to router to access stats that way, but had heard it can cause disconnects?  Ping is higher than it use to be at about 25ms.  Not too much lag during gaming, hard to connect to servers under 50ms on COD MW 2019 on xbox one X due to higher demand cause of lock down.
    #6794
    AvatarMrk26
    • Replies 465
    It should work perfectly fine on two cables, I have it like that on my old eci modem for months, no issues at all. On other forum people used HG612 on two cables for ages and I didn’t heard that this was caused issues.
    @Uk Sentinel
    How is yours connected?
    #6796
    • Replies 8,724
    @Mrk26. mine just has single ethernet between Modem LAN1 and Router WAN Port, I have not set up second Cable for stats via router and I am only testing currently, and practising KIS (Keep it Simple)
    @Bully
    – Yes extra Bandwidth is very positive and hopefully in fastpath will kick in if errors are low enough ?
    #6798
    AvatarMrk26
    • Replies 465
    [quote quote=6796] @Mrk26. mine just has single ethernet between Modem LAN1 and Router WAN Port, I have not set up second Cable for stats via router and I am only testing currently, and practising KIS (Keep it Simple)[/quote]
    I don’t believe in such thing, if something working, it should work with full potential, disappointed now, though you will fully unleash the beast 😂😂
    #6800
    • Replies 8,724
    AvatarMrk26
    • Replies 465
    [quote quote=6800]https://www.google.co.uk/imgres?imgurl=https%3A%2F%2Fthefunnybeaver.com%2Fwp-content%2Fuploads%2F2017%2F08%2Fminion-better.jpg&imgrefurl=https%3A%2F%2Fthefunnybeaver.com%2F33-funniest-minion-quotes-pictures%2F&tbnid=rbnH1IZ9IsPP0M&vet=12ahUKEwiE5_66novpAhVKw4UKHRCNDzsQMygbegQIARA3..i&docid=qAXsaDJPqY3erM&w=404&h=368&q=work%20and%20effort%20funny%20quotes%20minion&ved=2ahUKEwiE5_66novpAhVKw4UKHRCNDzsQMygbegQIARA3[/quote]
    Love it
    #6809
    Bully
    • Replies 386
    Todays Stats –
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 6
    Max: Upstream rate = 12271 Kbps, Downstream rate = 50356 Kbps
    Mode: VDSL2 Annex B
    Trellis: U:ON /D:ON
    Down Up
    SNR (dB): 6.2 6.3
    Attn(dB): 19.6 0.0
    Pwr(dBm): 13.4 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 15 20
    B: 25 238
    M: 1 1
    T: 64 31
    R: 10 16
    S: 0.0209 0.6330
    L: 13792 3223
    D: 2803 1
    I: 36 255
    N: 36 255
    Counters
    Bearer 0
    OHF: 65834624 364801
    OHFErr: 77 2
    RS: 3723920158 1790063
    RSCorr: 539878 14
    RSUnCorr: 1578 0
    Bearer 0
    HEC: 222 0
    OCD: 5 0
    LCD: 5 0
    Total Cells: 3185027118 0
    Data Cells: 551275815 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 80 7949
    SES: 40 93
    UAS: 115 251579
    AS: 154573
    Bearer 0
    INP: 8.00 0.00
    INPRein: 0.00 0.00
    delay: 14 0
    PER: 2.34 9.84
    OR: 71.55 21.11
    Bitswap: 106505/107170 18/19
    Total time = 1 days 1 hours 40 min 50 sec
    FEC: 1432749 76
    CRC: 17154 4
    ES: 80 7949
    SES: 40 93
    UAS: 115 251579
    LOS: 4 3
    LOF: 26 3
    LOM: 18 0
    Latest 15 minutes time = 10 min 50 sec
    FEC: 4767 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 5110 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 1 hours 40 min 50 sec
    FEC: 57266 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 273239 12
    CRC: 55 1
    ES: 9 1
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Since Link time = 1 days 18 hours 56 min 13 sec
    FEC: 539878 14
    CRC: 77 2
    ES: 16 2653
    SES: 0 31
    UAS: 0 83878
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Stats recorded 28 Apr 2020 17:58:39
    Status: Showtime
    Uptime: 1 day 18 hours 56 min 43 sec
    Resyncs: 0 (since 28 Apr 2020 17:56:36)
    Downstream Upstream
    SNR margin (dB): 6.2 6.2
    INP: 8.00 0
    RSCorr/RS (%): 0.0145 0.0007
    ES/hour: 0 0
