› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › RT-AC86U 384.16 Hi, I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. ...
- This topic has 717 replies, 4 voices, and was last updated 6 years, 3 months ago by
Bully.
April 11, 2020 at 1:18 pm #6345
I updated to the latest Merlin firmware this morning (about 9 am) and since doing so my NE CRC count has gone up to 326598 over 5 hours. The FE CRC/ES count has not increased at all.
NE CRC Count : 326598 FE CRC Count : 4011
NE ES Count : 8819 FE ES Count : 2625Me updating the firmware seems to be the only connection to the spike in counts.
What could I do to fix this?
April 11, 2020 at 1:46 pm #6346Is the EC and CRC from a DrayTek modem attached to the ASUS RT-AC86U, I forget what you have
I cannot see why the Modem would be effected by the recent upgrade of your RT-AC86U, Maybe worth just switching both the modem and router off for 15 minutes and then bringing back online and see if that settles down the modem etc.?
But this is most odd ?
April 11, 2020 at 1:53 pm #6347April 11, 2020 at 1:57 pm #6348April 11, 2020 at 2:04 pm #6349Nope, cant see anything.
Very strange, gone up to 449564 since starting this thread.
April 11, 2020 at 2:40 pm #6350I would power everything off as mentioned above (when family permits) and see if it happens again,
If you have the same high CRC count after power reboot, try reverting back to 384.15 and see if this is still cause of high CRC’s count from DrayTeK modem ?
April 11, 2020 at 2:44 pm #6351Ok, Will have to be after midnight or first thing in the morning, don’t want to upset anyone in the house, and with the lock down i cant escape the carnage
. I will let you know how it goes.You need to login in order to vote
April 11, 2020 at 2:48 pm #6353I am with you on the lockdown
dinner time is my favourite time for reboots etc
April 11, 2020 at 3:19 pm #6354April 11, 2020 at 5:52 pm #6355Turned off router and modem at 18.10, it has made no difference –
stats after 40 mins
NE CRC Count : 73740 FE CRC Count : 4011
NE ES Count : 2630 FE ES Count : 2625You need to login in order to vote
April 11, 2020 at 7:41 pm #6356Try reverting RMerlin firmware back to previous version, I am surprised the reboot did not work
April 11, 2020 at 7:52 pm #6357yeah that’s what I was thinking. Thanks for the help. I will let you know how it goes tomorrow.
April 11, 2020 at 8:14 pm #6358April 12, 2020 at 8:27 am #6359Right, I reverted back to 384.15, this has made no difference after the flash and a power down for 15 mins. It must just of been a coincidence.
My interleave depth has gone up over night –
DS Actual Rate : 34416000 bps US Actual Rate : 10666000 bps
DS Attainable Rate : 42690000 bps US Attainable Rate : 10841414 bps
DS Interleave Depth : 1441 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 5 dB
DS actual PSD : 6. 4 dB US actual PSD : 12. 9 dB
NE CRC Count : 48488 FE CRC Count : 4012
NE ES Count : 1411 FE ES Count : 2626These stats are 15 minutes after the 15 minute power down of router and modem – NE CRC Count : 48488 FE CRC Count : 4012 NE ES Count : 1411. The DS Actual Rate of 34416000 bps has dropped over night from 40251000 bps.
Is there anything I can do to get the errors down and my interleave depth down in way of snr or speed capping or should I just leave things alone?
April 12, 2020 at 8:36 am #6361That does make sense that the Asuswrt-Merlin firmware had no impact on your DSL line faults.
Yes your Interleaving has kicked in, it is not a happy ECI DSLAM or DSL line.
Did you ever try your BT HG612 modem, or is my memory fading as given the long history with your line a Broadcom DSL chipset is more forgiving ;-)
