› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AC86U 384.16
Bully.
- April 12, 2020 at 4:58 pm #6398
I will monitor the line over the next couple of days and see what happens.
Thanks again for the help.
April 13, 2020 at 8:40 am #6401Morning stats
DS Actual Rate : 32400000 bps US Actual Rate : 8585000 bps
DS Attainable Rate : 43875488 bps US Attainable Rate : 8683861 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 1479 US Interleave Depth : 181
NE Current Attenuation : 20 dB Cur SNR Margin : 6 dB
DS actual PSD : 6. 4 dB US actual PSD : 13. 3 dB
NE CRC Count : 2 FE CRC Count : 4044
NE ES Count : 1 FE ES Count : 2644
Xdsl Reset Times : 0 Xdsl Link Times : 2
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Test Mode : DISABLE
CO ITU Version[0] : b5004946 CO ITU Version[1] : 544ed086You need to login in order to vote
April 13, 2020 at 8:56 am #6402Interleaving on both Up and Down and loss of 2 Mbps – will be interesting to see what it does tomorrow and the day after?
Edit: if still no better , try changing bitswap to Off – trial and error unfortunately
“vdsl optn bitswap bi 1 off”
April 13, 2020 at 8:10 pm #6403I notice that on my vigor 2760 (also old eci modem) after reboot bitswap are not on immediately, usualy upstream within an hour downstream up to 3 hours.
When I used modem with broadcom chipset bitswap was on immediately after reboot.
April 14, 2020 at 5:56 am #6404I notice that on my vigor 2760 (also old eci midem) after reboot bitswap are not on immediately, usualy upstream within an hour downstream up to 3 hours. When I used modem with broadcom chipset bitswap was on immediately after reboot.
Thanks for info, is your Exchange/ DSLAM ECI and bitswap is On in both direction (eventually) ?In a completely sane world, madness is the only freedom (J.G.Ballard).
April 14, 2020 at 7:25 am #6409Yes, I’m on eci, and bitswap are “On”, booth direction as per above post.
April 14, 2020 at 8:03 am #6411Yes, I’m on eci, and bitswap are “On”, booth direction as per above post.
April 14, 2020 at 5:05 pm #6412Todays stats
DS Actual Rate : 32400000 bps US Actual Rate : 8537000 bps
DS Attainable Rate : 44138432 bps US Attainable Rate : 8604280 bps
DS Interleave Depth : 1515 US Interleave Depth : 179
DS actual PSD : 6. 3 dB US actual PSD : 13. 1 dB
NE CRC Count : 1 FE CRC Count : 4044
Xdsl Reset Times : 0 Xdsl Link Times : 3
Test Mode : DISABLE
DSLAM CHIPSET VENDOR : < IFTN >You need to login in order to vote
April 14, 2020 at 5:21 pm #6413April 14, 2020 at 5:24 pm #6414[ Counters: Showtime ]
Near End Far End Note
ElapsedTime : 155301 155301 (seconds)
CRC : -1 4044
FEC : 80240 53789
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 2644
SES : 3 31
LOSS : 2 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 722 722 (seconds)
CRC : 0 0
FEC : 731 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 5222 5222 (seconds)
CRC : 0 0
FEC : 3866 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
April 14, 2020 at 5:37 pm #6415When you playing up with vdsl snr make sure you reboot your modem otherwise it will report negative values like on your CRC – 1,this is incorrect and can cause higher interleave (at least did for me until I realised). Even that you change snr values and you back to stock settings, modem need to be rebooted. Not sure if that is not the case why you don’t have any errors reported on upstream, there should be at least single values.
Can you also do “vdsl status bandinfo”
Edit
Should be together “bandinfo”
April 14, 2020 at 6:21 pm #6417I have not adjusted any snr value.
[ BAND INFORMATION ]
US:
Band=0, LATN= 6, SATN= 6, SNR= 8, Border=[ 9- 31], Limits=[ 6- 31]
Band=1, LATN= 30, SATN= 29, SNR= 6, Border=[ 882-1193], Limits=[ 882-1193]
Band=2, LATN= 45, SATN= 45, SNR= 6, Border=[1984-2769], Limits=[1984-2770]
DS:
Band=0, LATN= 14, SATN= 14, SNR= 6, Border=[ 33- 857], Limits=[ 33- 857]
Band=1, LATN= 36, SATN= 36, SNR= 6, Border=[1218-1959], Limits=[1218-1959]
Band=2, LATN= 56, SATN= 54, SNR= 7, Border=[2795-3590], Limits=[2795-3779]
April 14, 2020 at 6:51 pm #6418April 14, 2020 at 7:38 pm #6419Just want to add, if there was changes made in settings, bitswap may not turn on until modem is rebooted. Instead of messing around with settings I will power down for solid 10 mins, disconnect all cables also unplug telephone cable (if on filtered faceplate), and after 10 min plug all back in. All should be O.K and bitswap should kick in.
April 14, 2020 at 8:25 pm #6420 - AuthorPosts
- The topic ‘RT-AC86U 384.16’ is closed to new replies.
