› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AC86U 384.16
Bully.
- July 2, 2020 at 5:44 am #8214July 2, 2020 at 5:03 pm #8216
DS Actual Rate : 35000000 bps US Actual Rate : 10469000 bps
DS Attainable Rate : 44109792 bps US Attainable Rate : 10611539 bps
DS Interleave Depth : 585 US Interleave Depth : 1
NE Current Attenuation : 20 dB Cur SNR Margin : 7 dB
DS actual PSD : 6. 5 dB US actual PSD : 13. 0 dB
NE CRC Count : 242 FE CRC Count : 4144
NE ES Count : 36 FE ES Count : 2705
Xdsl Reset Times : 0 Xdsl Link Times : 1
VDSL Firmware Version : 05-07-09-0F-01-07 [with Vectoring support]
Test Mode : DISABLE
DSLAM CHIPSET VENDOR : < IFTN >
> vdsl status more———————- ATU-R Info (hw: annex A, f/w: annex A/B/C) ———–
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 10371770 59753 (seconds)
ES : 36 2705 (seconds)
SES : 0 31 (seconds)
LOSS : 0 1 (seconds)
UAS : 34 90371 (seconds)
HECError : 0 0
CRC : 242 4144
RsCorrection : 0 0
INP : 0 15 (symbols)
InterleaveDelay : 0 800 (1/100 ms)
NFEC : 255 76
RFEC : 16 16
LSYMB : 2809 11189
INTLVBLOCK : 255 76
AELEM : 0 —-
> vdsl status counts[ Counters: Showtime ]
ElapsedTime : 74972 74972 (seconds)
CRC : 242 4144
FEC : 10375921 59753
HEC : 0 0
CRC_P : 127 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 36 2705
SES : 0 31
LOSS : 0 1
UAS : 0 0
LOFS : 0 0
[ Counters: 15Min ]
ElapsedTime : 468 468 (seconds)
CRC : 0 0
FEC : 198168 0
HEC : 0 0
CRC_P : 0 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 0 0
SES : 0 0
LOSS : 0 0
UAS : 0 0
LOFS : 0 0
[ Counters: 1DAY ]
ElapsedTime : 85968 85968 (seconds)
CRC : 242 4144
HEC : 0 0
CRC_P : 127 0
CRCP_P : 0 0
CVP_P : 0 0
NCD : 0 0
LCD : 0 0
ES : 36 2705
SES : 0 31
LOSS : 0 1
UAS : 0 0
July 2, 2020 at 5:32 pm #8217July 2, 2020 at 6:24 pm #8219plugged stabiliser into modem.
**EDIT – Added picture**
July 2, 2020 at 7:13 pm #8222July 2, 2020 at 7:41 pm #8223July 2, 2020 at 7:55 pm #8224I did wonder why your IP addressed changed country ;-)
Pic below I was basing my view of installation on which does look correct from filter to modem you recommended, unsure if that was same model as @bully purchased ? and whether they are indeed unidirectional etc
July 2, 2020 at 8:04 pm #8230I think I have plugged it in correctly, the stabiliser comes with the short black cable which was already plugged in the stabiliser, I removed it from packaging and plugged it into modem.
July 2, 2020 at 8:10 pm #8233<p style=”text-align: left;”>
I did wonder why your IP addressed changed country ;-) Pic below I was basing my view of installation on which does look correct from filter you recommended, unsure if that was same model as @bully purchased ?
</p>
I could connect through my vpn which I setup on my asus router but don’t need incognito mode for this forum ;-)I got exactly same but wondering if @Bully shouldn’t connect the other way round.
July 2, 2020 at 8:14 pm #8235I think I have plugged it in correctly, the stabiliser comes with the short black cable which was already plugged in the stabiliser, I removed it from packaging and plugged it into modem.
Yes, and apparently it should be right way, but if you check on the web or amazon on their pictures is the other way round. If it not working as expected you can always try the other way ;-)
July 2, 2020 at 8:40 pm #8239@Mrk26, I see what you mean from pics, @bully pic show coil at different end in relation to cable.
https://cpc.farnell.com/kauden/lx457/broadband-stabiliser-conditioner/dp/TE08180
July 2, 2020 at 8:47 pm #8240I believe these filters are all same, just not sure if people who pack them plug cable correctly. According to pictures provided by @Bully they are opposite side that the one which are on website or amazon. So if filter not working as expected maybe is worth turn it the other way round.
July 2, 2020 at 9:20 pm #8241When I back home (not sure when due to nature of business I work for) I will do test if there is a difference how this filter is plugged in.
July 2, 2020 at 9:34 pm #8242I will turn it around when I get the opportunity, probably in the morning before I go to work.
July 2, 2020 at 9:37 pm #8243 - AuthorPosts
- The topic ‘RT-AC86U 384.16’ is closed to new replies.
