RT-AC86U 384.16
Viewing 15 posts - 661 through 675 (of 718 total)
  • #8184
    AvatarMrk26
    • Replies 465
    It’s all depend how good will be with phone disconnected, if total amount of errors let’s say will be up to 300k FEC/ day then line can be capped down to 30Mb, if that reduce amount of errors then we should see light in the tunnel.
    Maybe is worth to try something like this, I got one of these (bought a while ago and forgot to test it), plugged about 2 weeks ago and my line even survived storm without being interleaved. What it does on my line, increase slightly line attenuation and best benefit so far is when attienable speed going down (due to network overloaded I suspect) then snr go dow, when attienable speed go up snr go back up, with vigor I only noticed that snr keep going down, never came back to 6db on downstream in the past. Also amount of errors is still low with this plugged in.
    #8185
    AvatarMrk26
    • Replies 465
    Nearly forgot about extended g.inp trial as per info here, maybe @Bully could request from BT to get g.inp activate on his line, that should help, I guess.
    #8186
    • Replies 8,708
    The BROADBAND STABILISER sounds like a REIN filter, nice idea and could be an option for @Grisu if the error bursts continue if phone is not changed/unplugged etc.
    #8187
    Bully
    • Replies 386
    I have ordered the stabiliser.
    any way to check line stats on my iPad so I don’t have to turn laptop on every time I want to check HG612 stats ?
    #8188
    AvatarMrk26
    • Replies 465
    Not sure if you will have it in app store, but on android phone I use mobile telnet.
    #8189
    • Replies 8,708
    It is called Terminal, I have used it on my MAC, but not iPhone
    Get Terminal for iOS to Bring the Command Line to iPad and iPhone
    #8190
    Bully
    • Replies 386
    Found a free one called Termius seems very good.  Terminal/Openterm you suggested is £3.99
    #8191
    • Replies 8,708
    Cheapskate, but do agree, free is my second favorite thing
    #8192
    Bully
    • Replies 386
    And your first ?
    #8193
    • Replies 8,708
    And your first ?
    Saying is from Babylon 5 (I am sure there are others)
    #8205
    Bully
    • Replies 386
    The stabiliser arrived.  Just need to find the right time to plug it in and switch back to the Draytek 130.
    #8207
    Bully
    • Replies 386
    Found the right time (I man’d up and shouted the internet is going off for a couple of minutes).
    stats –
    DS Actual Rate          : 35000000 bps   US Actual Rate       : 10469000 bps
    DS Attainable Rate      : 47201376 bps   US Attainable Rate   : 10547479 bps
    DS Interleave Depth     :      585       US Interleave Depth  :        1
    NE Current Attenuation  :       20 dB    Cur SNR Margin       :        7  dB
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 1  dB
    NE CRC Count            :        4       FE CRC Count         :     4141
    NE ES Count             :        2       FE  ES Count         :     2702
    Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
    VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
    > vdsl status more
    Bitswap      :      0               1
    LOS          :      0               0
    FECS         :   2563            59428 (seconds)
    ES           :      2            2702 (seconds)
    UAS          :     34            90371 (seconds)
    CRC          :      4            4141
    INP          :      0              15 (symbols)
    InterleaveDelay :      0             800 (1/100 ms)
    NFEC         :    255              76
    LSYMB        :   2809            11189
    INTLVBLOCK   :    255              76
    > vdsl status counts
    [ Counters: Showtime ]
    ElapsedTime  :    116             116 (seconds)
    CRC          :      4            4141
    FEC          :   2563            59428
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      2            2702
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    176             176 (seconds)
    CRC          :      4            4141
    FEC          :   2563            59428
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      2            2702
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    CRC          :      4            4141
    FEC          :   2563            59428
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      2            2702
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    #8208
    • Replies 8,708
    Couple of minutes, an optimist
    Will be interesting to see if this works ?
    #8209
    AvatarMrk26
    • Replies 465
    Yeah, looking forward to see stats with that on after couple of hours.
    #8210
    Bully
    • Replies 386
    DS Attainable Rate      : 43536096 bps   US Attainable Rate   : 10525058 bps
    DS actual PSD           :     6. 5 dB    US actual PSD        :    13. 2  dB
    NE CRC Count            :       10       FE CRC Count         :     4141
    NE ES Count             :        4       FE  ES Count         :     2702
    > vdsl status more
    LOS          :      0               0
    FECS         :   102220            59428 (seconds)
    ES           :      4            2702 (seconds)
    CRC          :     10            4141
    NFEC         :    255              76
    LSYMB        :   2809            11189
    INTLVBLOCK   :    255              76
    > vdsl status counts
    ElapsedTime  :   12988            12988 (seconds)
    CRC          :     10            4141
    FEC          :   102220            59428
    HEC          :      0               0
    CRC_P        :      6               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      4            2702
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 15Min ]
    ElapsedTime  :    528             528 (seconds)
    CRC          :      0               0
    FEC          :    114               0
    HEC          :      0               0
    CRC_P        :      0               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      0               0
    SES          :      0               0
    LOSS         :      0               0
    UAS          :      0               0
    LOFS         :      0               0
    [ Counters: 1DAY ]
    ElapsedTime  :   14928            14928 (seconds)
    CRC          :     10            4141
    FEC          :   102220            59428
    HEC          :      0               0
    CRC_P        :      6               0
    CRCP_P       :      0               0
    CVP_P        :      0               0
    ES           :      4            2702
    SES          :      0              31
    LOSS         :      0               1
    UAS          :      0               0
    LOFS         :      0               0
  • The topic ‘RT-AC86U 384.16’ is closed to new replies.
