RT-AC86U 384.16
Viewing 15 posts - 646 through 660 (of 718 total)
  • #8161
    AvatarMrk26
    • Replies 465
    Do you still hav phone plugged in to the faceplate?
    #8162
    • Replies 8,708
    With that amount of errors, I would say yes old phone is still in,
    BTW- I have noticed with my shiny new MK4 Face Plate, It is more sensitive to errors than my previous MK3
    #8163
    Bully
    • Replies 386
    Yeah old phone is still plugged into faceplate.
    #8164
    AvatarMrk26
    • Replies 465
    With that amount of errors, I would say yes old phone is still in, BTW- I have noticed with my shiny new MK4 Face Plate, It is more sensitive to errors than my previous MK3
    I mentioned earlier that mk3 is best of all 👍
    #8166
    • Replies 8,708
    You did indeed which was why I mentioned it ,
    #8174
    Bully
    • Replies 386
    Thought I’d plug the HG612 back in to see if i get better speed –
    DSL mode: VDSL2 Profile 17a
    Status: Showtime
    Uptime: 3 hours 56 min 6 sec
    Resyncs: 0 (since 28 Jun 2020 18:37:50)
    Downstream Upstream
    Line attenuation (dB): 19.7 0.0
    Connection speed (kbps): 34998 11746
    SNR margin (dB): 8.1 6.0
    Power (dBm): 13.1 6.7
    Interleave depth: 1123 1
    INP: 3.50 0
    Vectoring status: 5 (VECT_UNCONFIGURED)
    RSCorr/RS (%): 0.0033 0.0000
    ES/hour: 0 0
    VDSL2 profiles:
    8a Enabled
    8b Enabled
    8c Enabled
    8d Enabled
    12a Enabled
    12b Enabled
    17a Enabled
    30a Enabled
    US0 Enabled
    Phone line pair:
    Inner pair
    Capability:
    bitswap On
    sra On
    trellis On
    sesdrop Off
    CoMinMgn Off
    24k On
    phyReXmt(Us/Ds) Off/On
    TpsTc AvPvAa
    monitorTone: On
    dynamicD: On
    dynamicF: Off
    SOS: On
    Training Margin(Q4 in dB): -1(DEFAULT)
    xdslcmd info –vectoring
    Status: Showtime
    Retrain Reason: 0
    Max: Upstream rate = 11747 Kbps, Downstream rate = 48628 Kbps
    Bearer: 0, Upstream rate = 11746 Kbps, Downstream rate = 34998 Kbps
    Vectoring state: 5
    VCE MAC Address: 0:0:0:0:0:0
    Total error samples Ethernet pkts sent: 0
    Total error samples Ethernet pkts discarded: 0
    Total error samples statuses sent: 0
    Total error samples statuses discarded: 0
    xdslcmd info –stats
    Status: Showtime
    Retrain Reason: 0
    Link Power State: L0
    Mode: VDSL2 Annex B
    VDSL2 Profile: Profile 17a
    TPS-TC: PTM Mode(0x0)
    Trellis: U:ON /D:ON
    Line Status: No Defect
    Training Status: Showtime
    Down Up
    SNR (dB): 8.1 6.0
    Attn(dB): 19.7 0.0
    Pwr(dBm): 13.1 6.7
    VDSL2 framing
    Bearer 0
    MSGc: 36 21
    B: 31 238
    M: 1 1
    T: 64 7
    R: 10 16
    S: 0.0290 0.6474
    L: 11568 3151
    D: 1123 1
    I: 42 255
    N: 42 255
    Counters
    Bearer 0
    OHF: 5081671 1395249
    OHFErr: 0 0
    RS: 1951226030 1982734
    RSCorr: 64786 0
    RSUnCorr: 0 0
    Bearer 0
    HEC: 0 0
    OCD: 0 0
    LCD: 0 0
    Total Cells: 956526282 0
    Data Cells: 79542383 0
    Drop Cells: 0
    Bit Errors: 0 0
    ES: 0 2699
    SES: 0 31
    UAS: 26 90194
    AS: 14226
    Bearer 0
    INP: 3.50 0.00
    INPRein: 0.00 0.00
    delay: 8 0
    PER: 2.79 10.23
    OR: 120.03 21.10
    AgR: 35117.67 11767.19
    Bitswap: 10528/10556 0/0
    Total time = 3 hours 57 min 32 sec
    FEC: 64786 0
    CRC: 0 0
    ES: 0 2699
    SES: 0 31
    UAS: 26 90194
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Latest 15 minutes time = 12 min 32 sec
    FEC: 1218 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    FEC: 1707 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Latest 1 day time = 3 hours 57 min 32 sec
    FEC: 64786 0
    CRC: 0 0
    ES: 0 2699
    SES: 0 31
    UAS: 26 90194
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    Previous 1 day time = 0 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 0 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Since Link time = 3 hours 57 min 5 sec
    FEC: 64786 0
    CRC: 0 0
    ES: 0 2699
    SES: 0 31
    UAS: 0 90168
    LOS: 0 1
    LOF: 0 1
    LOM: 0 0
    #8175
    • Replies 8,708
    Just as a side thought, I am not sure how friendly you are with your neighbours’ as it would be interesting to see what synch rate they had ?
    #8176
    Bully
    • Replies 386
    Still seem to be capped at 35mbps.
    #8177
    AvatarMrk26
    • Replies 465
    Looks like it.
    Did you manage to change/unplug telephone?
    #8178
    Bully
    • Replies 386
    not yet.  Is there a cmd to reverse the cap i put on?  Capped it at 35mbps.
    #8179
    AvatarMrk26
    • Replies 465
    On which modem? If you put cap on hg612 recently it will be removed once modem is rebooted. If you still on 35Mb after hg612 is rebooted than is banded profile set by DLM.
    #8180
    Bully
    • Replies 386
    oh ok.  I thought it was odd that both modems are only getting 35mbps.  must be DLM then.
    #8181
    • Replies 8,708
    @Mrk26 – what’s the next step
    #8182
    AvatarMrk26
    • Replies 465
    I think next step was suggested already couple of times, we need to see how line will perform with telephone disconnected. There is a burst of errors every day (I think was afternoon) on @Bully line. Once face plate was changed the FEC errors was under control, kind of. Now with snr 8db he still getting bunch of them (where should get barely any) , and DLM consider these with his decisions.
    #8183
    • Replies 8,708
    Perfect, any thought’s and throttling throuput (capping) as you have suggested in the past ?
  • The topic ‘RT-AC86U 384.16’ is closed to new replies.
