RT-AC87U I recently won this fairly cheap on eBay, I wanted to get another ASUS router having owned the N66U, AC68U variants.  I see it does not have AI Mesh support…
UKTH forums 🛜 Wireless Routers & Modems ASUS & Wireless RT-AC87U I recently won this fairly cheap on eBay, I wanted to get another ASUS router having owned the N66U, AC68U variants.  I see it does not have AI Mesh support...
  • #1361
    AvatarRetired Account
    • Replies 19
    I recently won this fairly cheap on eBay, I wanted to get another ASUS router having owned the N66U, AC68U variants.  I see it does not have AI Mesh support but Merlin is available.  Spec wise it does not look bad but is there anything else I should know? :)
    • Replies 8,460
    I recently won this fairly cheap on eBay, I wanted to get another ASUS router having owned the N66U, AC68U variants. I see it does not have AI Mesh support but Merlin is available. Spec wise it does not look bad but is there anything else I should know? 🙂
    I used to own one of these back in 2015, the unit is rather old nowadays, as it was first introduced in 2014, it uses a combination of Broadcom and Quantenna chipsets, the Quantenna chipsets are for wifi and did have real issues with Battery draining/stability etc.
    Just looked thru the firmware’s for RT-AC87U and as you say, it does not mention AiMesh, so looks like ASUS are not prioritising this unit over similar Broadcom based units. (RT-AC68U)
    It should work fine, just don’t expect miracles, the unit is supported by ASUSWRT-Merlin firmware, so you are in good hands.
    #1364
    • Replies 19
    I wish I had checked with you first lol, I was looking at the AC86U but that was out of my budget.
    • Replies 8,460
    The RT-AC86U is a great little router, and has AiMesh etc, well worth the investment next time ;)
    #1366
    • Replies 19
    I think i’ll return this one and get that, even though its a little more expensive it seem the better choice.
    Thanks mate
    • Replies 8,460
    I think i’ll return this one and get that, even though its a little more expensive it seem the better choice. Thanks mate
    Enjoy ;-) – just keep in mind, try to buy a non Chinese version i.e. not from Gearbest etc, as these do have Language problems when used outside China, Forum Member @Grisu has ranted heavily about this on my old forum.
    #1368
    • Replies 19
    Enjoy ? – just keep in mind, try to buy a non Chinese version i.e. not from Gearbest etc, as these do have Language problems when used outside China, Forum Member @grisu has ranted heavily about this on my old forum.
    I saw them, if it’s cheaper it’s usually too good to be true.  I bought an AC86U from scan.co.uk, first order I placed with them since 2006 lol.
