March 29, 2022 at 7:02 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18445
[quote quote=18407]
I am also having a problem. Within 1-2 days after installing the modem firmware, the Snr setting remains stable at the point I set stable, and then starts to drop. I reset the modem again, it is fixed again, but after 1-2 days the snr drops again. I give an example; The SNR I set to 4 is now fluctuating between 3 and 3.5. How can I fix this?
SNR values will fluctuate a little during the day/night is common, as your variation is very small, unless it is causing you issues, nothing to worry about
<noscript>
</noscript>[/quote]thank you :)
March 24, 2022 at 10:06 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18397March 24, 2022 at 9:49 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18393I added the image of my dsl settings.
Note: the SNR setting dropped even while taking the picture :)Attachments:
March 24, 2022 at 9:48 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18391I am also having a problem. Within 1-2 days after installing the modem firmware, the Snr setting remains stable at the point I set stable, and then starts to drop. I reset the modem again, it is fixed again, but after 1-2 days the snr drops again. I give an example; The SNR I set to 4 is now fluctuating between 3 and 3.5. How can I fix this?
March 24, 2022 at 9:40 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18390[quote quote=18384]Dsl Ac51u works fine with Comnet in Turkey
I disabled “Stability Adjustment” in DSL settings. Everything seems good.[/quote]do you use Bitswap?
March 23, 2022 at 2:55 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18363[quote quote=18359]The same problem continues with ASUS AC51 965, all the lights are on, no internet, but after turning it off and on, it is fixed ASUS does not work with turknet in turkey, it is problematic ASUS should take this into account and intervene, but old software is recommended 790 and before, which is dangerous in terms of security.[/quote]
please can you try different modems? i lived same problem at Turknet and i passed Ttkom and problem solved
March 22, 2022 at 6:04 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18358[quote quote=18357]
The hardware can be up to whichever version is available.
I will have a chat with ASUS, but I realise that is a little more complicated than just upgrading the Kernel, there is commercial/business considerations etc.[/quote]
thanks, we are waiting for positive answers :)
March 22, 2022 at 4:40 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18354[quote quote=18353]
command writing 2.6 version.. asus can update this kernel..
Update Kernel to what version – 5.0.21 ?[/quote]
March 22, 2022 at 3:55 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18352when write
uname -a
March 22, 2022 at 12:40 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18349[quote quote=18346]
also, can you say for update kernel core? linux image is oldest
What do you mean ‘Linux Image’, do you mean Linux Version from which image/build is created ?[/quote]
yes, you can mean linux version
March 22, 2022 at 10:16 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18345[quote quote=18344]
Please update the pppd package to version 2.4.9. Because 2.4.7 has serious security vulnerabilities such as CVE-2020-8597
I will ask ASUS to add this request to there list
<noscript>
</noscript>[/quote]also, can you say for update kernel core? linux image is oldest
March 20, 2022 at 10:23 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18325[quote quote=18324]It makes more sense to buy another ISP expensive new modem with the same speed and throw the Asus device in the trash.[/quote]
Well, the choice is yours :)
March 20, 2022 at 10:16 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18323[quote quote=18320]Thanks for your reply, I contacted asus a lot, I am adding the answer they sent me, there is no solution, they say send me to the service, but they will upload software and send it to the service until then, I will be without internet until then, I know you are an expert in technical issues, there is no physical problem, but this modem ac51 is problematic, exchange and return is not accepted. they didn’t[/quote]
can you change iss?
March 20, 2022 at 8:49 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18318March 20, 2022 at 7:32 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18316[quote quote=18314]I did it, dear person, I did it in 805, 858, 960. 805 and earlier software is a little better, but 858-960 is very very bad, I installed 965. It’s been 8 hours, good, let’s see, this asus ac51 has tired me out. I have technical knowledge, I think, since it doesn’t have a broadcom chipset, it’s always problematic in turkey. modemels should be banned from being sold in turkey, there are also everyone i live with, especially read the seller comments on Hepsiburada.com my question is that the lights are on, the internet disappears after a certain time of working[/quote]
Necati, I’m sorry to say, but the problem of not having internet while this light is on belongs to Turknet. I switched to Türk Telekom and that problem was solved.
