March 16, 2022 at 5:34 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18280
Thanks for letting us know, I will pass this feedback back to ASUS also
we wait for ddns
Half-Life 1 Server IP: hl.oyunsen.com:27015
We will re-write code of world…
March 15, 2022 at 5:28 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18273this vpn problem on fw.959 and 960, whats wrong:
Ok, so have have come back to me and provided updated firmware for the DSL-AC51 and the DSL-AC52U that should fix the VPN issue. Let me know if this fix works so I can feedback to ASUS
<noscript><noscript>
<noscript>
</noscript>Note: normal UKTechHub.com ASUS Beta Terms & Conditions Apply (top of forum) —– For the VPN issue, please help to upgrade this beta FW and confirm again: DSL-AC51_v9.1.2.3_965-g81447d0.trx.zip https://www.asuswebstorage.com/navigate/a/#/s/7E16999EE6D2414EA67826AECCD33CBAY DSL-AC52U_v9.1.2.3_965-g81447d0.trx.zip https://www.asuswebstorage.com/navigate/a/#/s/9C9FF0F953C644438BF4D03225155664Y —–for fix ddns?
March 12, 2022 at 5:27 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18228yes. ddns not working at 960fw
Why ?
i will send my friends for use
can you send me all versiyon for all those modems ?
March 10, 2022 at 2:02 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18205Welcome back
thanks, i changing iss for you :))
March 10, 2022 at 12:56 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #18203
i returned area:)
February 26, 2022 at 9:35 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17958
Best regards
February 25, 2022 at 7:18 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17953MediaTeK,
no problem left, i got 23 crc error in 14 hours(5db snr margin) . Thank you to Asus and you guys for your hard work for the new firmware.
tr; herhangi bir sorun kalmadı, 14 saatte 23 crc hatası aldım(5db snr margin) . Asus’a ve emeklerinizden dolayı sizlere yeni firmware için teşekkür ederim.
February 24, 2022 at 7:20 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17944there is crc problem at this version :(
Did you try a factory reset ? and what is your SNR (up-down) ?
yes, i resetted to factory reset with reset button. i use snr margin 5db. I was also using snry 5db in firmware version 959 but I was seeing 24 max 60-70 crc function on it. I just made new settings and 2 crc errors occurred in 30 minutes. Let’s see, after 24 hours, I will write the full results, it seems that there is no problem at the moment.
February 24, 2022 at 5:59 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17941Great news and I think @TSuNaMi will be happy
</noscript>Just had a look and seems also new stock firmware for …- DSL-AC51
- DSL-N16
- DSL-AC55U
February 24, 2022 at 12:00 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17938Great news and I think @TSuNaMi will be happy
<noscript>
- DSL-N16
- DSL-AC55U
ooovvvvv you are and asus kingg :))) i will install tonightt
February 18, 2022 at 3:33 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17858we need new firmware with updated kernel
Send ASUS a feedback form and make request for new Firmware with updated Kernel
<noscript>
</noscript>Looks like ASUS gave up on the ac51 :(
February 18, 2022 at 1:12 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17856we need new firmware with updated kernel
February 11, 2022 at 7:30 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #17757 -
