September 9, 2018 at 12:44 pm in reply to: Draytek Vigor 130 modem My modem never shows the correct time in its UI dashboard? #533
For DNS, you will be using the Routers DNS, as DrayTek 130 is in Bridge Mode, everything passes through to Router. modem only converts what BT sends down the DSL line into something the Router can understand (PPPoE)
September 9, 2018 at 8:12 am in reply to: Draytek Vigor 130 modem My modem never shows the correct time in its UI dashboard? #530DNS is a means by which Real Name, (URL’s) are mapped to IP address, so when you type http://www.bbc.co.uk, the PC knows to go to 212.58.249.209, your DrayTeK is a modem and is in bridge mode, so any user typing in Real names, is automatically mapped to an IP address via your ASUS router, changing your DrayTeK DNS details offers no advantage, as the DNS on the modem is not used by user in a typical scenario.
Above is short explanation, as I realise DNS is way more complicated, but trying to keep user explanation user friendly.
Hope that helps?
DNS: https://en.wikipedia.org/wiki/Domain_Name_System
Bridge Mode:Â https://en.wikipedia.org/wiki/Bridging_(networking)
September 7, 2018 at 9:25 pm in reply to: Draytek Vigor 130 modem My modem never shows the correct time in its UI dashboard? #525I used to wonder about that also, From the DrayTeK 130 user guide, the date and Time can be adjusted from System Maintenance > Date and Time, but as we are running the special BT approved build, this option is not available via the GUI.
When you log on to the DrayTeK 130, it should say ‘User Mode is OFF’, and I have always assumed, this means I is locked down and never found the a way to enable user mode?
I never tried the CD that came with the disk, but I assumed it does nothing extra ?
September 7, 2018 at 5:25 pm in reply to: ASUS – DSL-AC88U / DSL-AC3100 Firmwares (beta's) etc. Looks like a new Beta Release for the DSL-AC88U is available, this version has Telnet enabled and improved 2.4GHz wifi (I believe). DSL-AC88U_v9.10.06_build581_debug.w.zip https://www.asuswebstorage.com/navigate/s/604D61534F2541D1B3CE1CC031A697E4Y UK Sentinel In a completely... #518ASUS have given me the following firmware for the DSL-AC88U, this version has had Broadcom patch 5 removed and ASUS say it fixes Broadcom Memory leak, so have dug out my DSL-AC88U and running this version now, feel free to trial this firmware if you wish, factory reset and build router from scratch (not backup) is advised.
let us know if memory leak is fixed, so I can feed this back to ASUS
DSL-AC88U/ DSL-AC3100 beta non-debug Build583 as follows.
DSL-AC88U_v9.10.06_build583.zip
https://www.asuswebstorage.com/navigate/s/EE16CBFAA88C4D599899BBB09AF662B7Y
DSL-AC3100_v9.10.06_build583.zip
https://www.asuswebstorage.com/navigate/s/D7C811CC648B434EB6E1D0D6E4E8E465Y
Alternate links,
https://www.asuswebstorage.com/navigate/s/A4551D582D014BB5A41C17931CEDB2C04
https://www.asuswebstorage.com/navigate/s/8A3BD84484124396A6ED1EECF13A7D694
Good news then, How did you become aware of the random disconnects, was this by looking in the logs, or via using the service, and then it not being available for a couple of minutes, the DrayTeK and ASUS logs are more comprehensive, where as the logs for the Netgear D7800 are much more basic.
Either way, just keep an eye on your line stats, to see if over time, the synch speeds changes dramatically ?
Glad I asked, In my view, this is perfectly normal, the DSLAM/Exchange does periodically reset connection with modem device, just to refine connections etc, mine is also every other week, and this is regardless of DSL Chipset, I did at one stage (like you I think) have the DSL-AC68U and this re-sync’d almost every few days.
Does the Synch cause any problems, ie. does this leave router hanging afterwards, if not then I would not worry about this at all ;-)
Is this Random, once a week, every few days?
Just before you do that, when you say you have had the five disconnects, are these every day, or random, I forgot to ask last night ?
You do seem to be having fun, does the DrayTeK at any point say it is in training mode in the UI, if so then I think a call with ISP is needed, to check for line faults, (again) also make sure DrayTek 130 is running firmware 3.8.3 BT
Also maybe worth looking at ASUS router and see if you can do the following, change the settings of the router to enable baby jumbo frames and an MTU of 1508, see if this helps?
Alas a case of trial an error ;-)
September 5, 2018 at 10:26 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #485Thanks Babis3g as always ;-)
August 27, 2018 at 8:33 am in reply to: ASUS VIP Support, Feature Request and Complaints Link To contact ASUS VIP Support , try ……… WiFi Router:        router_feedback@asus.com xDSL Modem Router: xdsl_feedback@asus.com / For BCM6313x series models(such as DSL-AC88U series): iad_feedback@asus.com 4G... #389 -
