Thank you, I will look into the spacing points you have made and see if I can make any adjustments
Not tried any of his firmwares but always good to see new and established SNB Forum members getting involved.
Based (Registered) in Florida (US) I believe, should be interesting watching his progress.
October 7, 2026 at 4:45 pm in reply to: ASUS RT-BE88U – Official Thread ASUS RT-BE88U WiFi 7 Dual-Band Router Promotion Link https://press.asus.com/news/asus-unveils-rt-be88u-wifi-7-dual-band-router/ —- Initial firmware release ASUS RT-BE88U Firmware version 3.0.0.6.102_33911 Version 3.0.0.6.102_33911 2024/03/26 Initial firmware release https://www.asus.com/uk/supportonly/rt-be88u/helpdesk_bios/ #44170ASUS RT-BE88U Firmware version 3.0.0.6.102_39450
2026/10/07
– Supports Surfshark VPN account login for a smoother user experience. (Supported model only)
Security Fixes:
– Web management interface: Strengthened data handling for the connected device list and added stricter content checks when importing configuration profiles.
– Network speed test service: Added allowlist validation for service command parameters, so that only expected values are accepted.– AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
– AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
– AiCloud: Strengthened authentication and path validation for remote file access.
– System protection service: Adjusted address parameter validation and event logging, strengthening access control between local services.– Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
– Third-party account authorization: Narrowed the recipients of authorization data to better protect authorization information.
– Web management interface: Adjusted the output handling of feedback content.
– Notification service: Added identity verification for local connection sources and tightened the related file permission settings.
– Mobile device connection authorization: Added a device matching check to strengthen the access token issuance process.
– Device discovery service: Removed a non-essential internal function endpoint to strengthen overall access control.
– AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.– System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
– Network diagnostic data query: Strengthened value range checks for time interval parameters.
– Network diagnostic data query: Added allowlist validation for query fields.
– Internal data query: Improved field matching logic and optimized the memory release process under error conditions.
– Time synchronization settings: Strengthened parameter validation for the server name.
– File upload handling: Fixed an issue where certain input formats could cause the web management service to become unresponsive.– Wireless channel selection tool: Adjusted the handling of command parameters to prevent unintended command execution.
– Certificate upload: Added a pre-check of archive contents to prevent files from being written to unintended locations.
– System configuration file generation: Strengthened parameter content checks to prevent abnormal configuration values from affecting network service settings.
– VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
October 6, 2026 at 5:05 pm in reply to: ASUS GT-AXE16000 – Official Thread Latest ASUS GT-AXE16000 Firmware 3.0.0.4.388.23012 Firmware version 3.0.0.4.388_23012 New features: – Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections.... #43993ASUS GT-AXE16000 Firmware Version 3.0.0.6.102_37547
2026/10/06
Security Fixes:
System protection service: Adjusted address parameter validation and event logging, strengthening access control between local services.Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
https://rog.asus.com/uk/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
ASUS RT-AX92U Firmware version 3.0.0.4.388_23895
2026/10/05
Security Fixes:
New Asuswrt-Merlin 3006.102.9 release …
Good to see the introduction of AQM for some ASUS models (not RT-BE92U – RT-BE58_Go) which helps reducing bufferbloat through improved queue management and I just noticed the Security Update notifications tab under > System Log, but that may have been there previously and I never noticed.
Have been running this for about a week now on my RT-BE92U and so far no real issues.
https://www.asuswrt-merlin.net/download
ASUS are currently making changes to the built-in Speedtest feature across their routers. No word on a BQ16-specific fix, but I’d keep an eye on upcoming firmware releases.
ASUS ZenWiFi BT8 Firmware version 3.0.0.6.102_58600
2026/10/01
Security Fixes:
October 2, 2026 at 10:42 am in reply to: ROG Rapture GT-BE98 Pro – Official Thread ASUS GT-BE98 Pro Firmware version 3.0.0.6.102_34491 Version 3.0.0.6.102_34491 2024/05/07 New Features: Introduced AURA Night Mode. Added Multi-link Operation (MLO) network in Guest Network Pro. Added automatic WAN/LAN detection feature.... #43833ASUS GT-BE98 Pro Firmware version 3.0.0.6.102_39441
2026/10/01
Security Fixes:
Fixed VLAN related issues.We recommend updating to this version to maintain optimal protection.
https://rog.asus.com/networking/rog-rapture-gt-be98-pro/helpdesk_bios/
. dodgydrains Said:Looks like the BQ16 is not recieving the Asus firmware update love this time round, maybe they are working on it for a bit longer to make it even better.
I went over 100 days of uptime with no issues at all.
Crytptic as always they are.
Yes, I think that’s what makes the wording interesting. I had a look at ASUS’s actual announcement here:
https://www.asus.com/support/faq/1057454/
ASUS says the Speedtest service is being “adjusted” from October 2026 and refers to it as a “unified optimisation adjustment”, but doesn’t actually explain what has changed.
My guess would be that something has changed on the backend/service side, which means ASUS needs to change the implementation in the firmware. If this is related to a change by Ookla, for example, that would explain why the existing Speedtest implementation suddenly needs a firmware update.
But that’s only speculation, ASUS doesn’t mention Ookla, losing access to the old backend, or any backend problems.
ASUS ZenWiFi BT10 Firmware version 3.0.0.6.102_39436
2026/09/30
Security Fixes:
September 29, 2026 at 1:18 pm in reply to: ASUS RT-BE86U – Official Thread New ASUS RT-BE86U Firmware version 3.0.0.6.102_37022 Firmware version 3.0.0.6.102_37022 2024/10/17 Security: 1.Strengthened system code execution processes. 2.Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts. 3.Refined input validation in... #43784ASUS RT-BE86U Firmware version 3.0.0.6.102_39436
2026/09/29
Security Fixes:
September 26, 2026 at 11:37 am in reply to: Asus ROG Rapture GT-BE19000AI – world’s first AI-powered gaming router Asus ROG Rapture GT-BE19000AI launches as world’s first AI-powered gaming router with built-in NPU The ROG Rapture GT-BE19000AI at CES led the announcement as a high-performance gaming router with a... #43441ASUS GT-BE19000AI Firmware version 3.0.0.6.102_40770
2026/09/23
https://www.asus.com/support/faq/1057454/Supports Surfshark VPN account login for a smoother user experience. (Supported model only)
Security Fixes:
https://rog.asus.com/uk/networking/rog-rapture-gt-be19000ai/helpdesk_bios/
