- This topic has 1,441 replies, 107 voices, and was last updated 12 hours, 45 minutes ago by
etdome.
March 6, 2020 at 7:30 am #6154
Hi Sentinel, I did try that method but the router still reverted back to the setting that I had before flash firmware & factory reset. I managed to factory reset it and setting up the new setting, after holding the reset button for like 20s~30s and have to try multiple time. However, as soon as I reboot or turn off and turn on the modem, the new setting is gone and reverted back to the old setting. it’s kinda weird bug I think.
March 6, 2020 at 10:30 am #6157Interesting, Have you tried using a different browser / PC to factory reset via UI.
Maybe an option to load very old firmware (Version 1.10.04_Build460 ) and see if that does the trick.
With pushing the factor reset button on back of router, I have found with other ASUS models, this has to be repeated several times to actually get working
March 6, 2020 at 10:45 am #6158[quote quote=6157]Interesting, Have you tried using a different browser / PC to factory reset via UI. Maybe an option to load very old firmware (Version 1.10.04_Build460 ) and see if that does the trick. With pushing the factor reset button on back of router, I have found with other ASUS models, this has to be repeated several times to actually get working
[/quote]I tried Edge (Chromium), Firefox and Chrome. I also tried to flash the oldest version I could found on the Asus page but every setting back to the previous setting instead of the factory default page and the only thing that remain changed is the firmware version.
The reset button at the back did work after tried around 5 times but have to hold it kinda longer than usual but then after setting everything up and click reboot or turn off/on then all the new setting will gone haha, so now I guess I just keep it turn on and re-setting it if it got wiped
It kinda bad since I saw your message about ASUS stop support this model
March 6, 2020 at 11:03 am #6160Bad news indeed, Not sure what RMA polices are like in your part of the world, but if you can return it, then this maybe a wise move and think of this as an opportunity ;-)
March 6, 2020 at 11:17 am #6161[quote quote=6160]Bad news indeed, Not sure what RMA polices are like in your part of the world is, but if you can return it, then this maybe a wise move and think of this as an opportunity ;-)[/quote]
Yeah I might try to contact them about the case, the warranty is the end of this year, so it should be fine I hope
thanks for helpingYou need to login in order to vote
March 6, 2020 at 11:22 am #6162No problem, need any guidance on new Router/Modem, feel free to ask
March 6, 2020 at 6:48 pm #6163[quote quote=6126]Brave chap. PM will be sent (Note: alas your registered email address no longer works) ?[/quote]
I was unable to check which email I have linked to my forum account (or change it for that matter), so I am unsure, if the TLD is sm9 (dot) dev then the email should be correct, also, sorry for the late response, still looking into hacking this machine and seeing if I can do something with it
March 6, 2020 at 7:32 pm #6167March 6, 2020 at 7:41 pm #6168Yes, that is the correct email, I will look into how I have things setup on my webserver (Something seems off), thank you
March 6, 2020 at 8:04 pm #6172Sent message after receiving your email, alas email still bounced (NDR) and maybe DNS related, alas my Servers are via Hosting Company, so not much luck there.
April 15, 2020 at 6:12 pm #6429Hi All New to the Forum I’m after info on the ASUS AC-88U DSL
Iv been looking at setting up an access point with the ASUS RP-AC68
I have seen how to set it up on Yo#tu#e but I can not find the operation mode in the ASUS AC-88U
Any Help Would be great
April 15, 2020 at 6:34 pm #6430@walshy5050 – welcome, unfortunately the DSL-AC88U does not support AP / AiMesh – it was a bit of kit that ASUS no longer support over a year ago.
Have you had the DSL-AC88U long, can it be returned ?
In reality ASUS offers three options
- AiMesh -not available on DSL-AC88U (both units need to support this option)
- Access Point – Ethernet cable between two routers (set-up via ASUS RP-AC68)
- Repeater – Wifi connection between two routers (set-up via ASUS RP-AC68)
As AiMesh is not supported by DSL-AC88U, then using your ASUS RP-AC68 you should still be able to utilise its Access Point or Repeater functionality (as child) and still keep DSl-AC88U as main router etc?.
Link to youtube which should help clarify the differences and advantages/ disadvantages of each option – https://www.youtube.com/watch?v=ic0bgo_ueQ0
April 21, 2020 at 8:01 am #6598Hi,
I’m finding that I also need ssh access to my AC88U, any chance that you could direct me to where I can use the debug edition of the firmware please ?
Many thanks.
April 21, 2020 at 8:29 am #6599[quote quote=6598]Hi, I’m finding that I also need ssh access to my AC88U, any chance that you could direct me to where I can use the debug edition of the firmware please ? Many thanks.[/quote]
PM will be sent
April 28, 2020 at 8:27 am #6797@pavlf buddy, where art thou? Hope you are doing well.
Just reporting in regarding our friendly comp.
After several power outages, I’ve finally managed to get my 88U back to 123 days uptime. It’s at 306MB RAM used, so I’ll probably get 2 months more till it becomes unstable due to memory exhaustion.
How’s yours going?
