Viewing 15 posts - 271 through 285 (of 714 total)
  • #13733
    Black Bird
    • Replies 146
    [quote quote=13731] @black-bird – Did you have access this version (version 9.0.0.4_386_13892) already ?[/quote]
    Unfortunately I couldn’t access it but I know this firmware version was the latest
    #13734
    @black-bird – I will ask
    #13735
    [quote quote=13721]Hi Got a friend looking for a recommendation to replace ISP box of crap. Is the DSL-AX82U any good? This will need to be handed over to a non techy so is it stable? Thanks in advance……[/quote]
    Not fully stable as yet but the next Stck release should address most of the current issues (whenever that is) as you know, ASUS DSL kit is not ideally suited for the non-technical,
    #13736
    Avatardwskittles
    • Replies 12
    so i set the snr to 6db but i think my line has been banded so it showing 10db at the moment.
    #13737
    Black Bird
    • Replies 146
    [quote quote=13736]so i set the snr to 6db but i think my line has been banded so it showing 10db at the moment.[/quote]
    The way it works is different, so there’s inconsistency. The next firmware was also more understandably updated.
    #13741
    Avatardwskittles
    • Replies 12
    mine looks like this on 9.0.0.4.386_13831-g7ade778
    So if your original SNR was 10dB and you have set Stability Adjustment to -4dB then you should end up with SNR of 6dB – lots of variables so hopefully ASUS will update to suit how it should work with newer releases.
    Leave yours at 6dB overnight and see what happens
    #13745
    Black Bird
    • Replies 146
    [quote quote=13741]mine looks like this on 9.0.0.4.386_13831-g7ade778[/quote]
    Yes, this firmware version was introduced for VDSL SNR tuning and remained obsolete. Because you installed an old beta firmware, you are already writing down a known issue.
    #13752
    Ok, so spoke with ASUS and they have kindly shared DSL-AX82U beta Firmware (DSL-AX82U_9.0.0.4_386_43563-g9919a0d_cferom_puresqubi) which now the UI of Stability adjustment has changed to  -1 dB, -2 dB, … and +1 dB, +2dB etc. and should work for both ADSL and VDSL connections.
    This is a beta firmware so normal UKTH ASUS beta firmware T&Cs apply (see top of forum)
    [download id="13749"]
    Would be good if someone could verify if VDSL  Stability adjustment  actually works ?
    #13761
    Avatardwskittles
    • Replies 12
    the only difference i can see is the max rate has gone up a bit. Also the log shows 6db for a couple of seconds after restarting the router then it jumps to 11
    #13767
    [quote quote=13761]the only difference i can see is the max rate has gone up a bit. Also the log shows 6db for a couple of seconds after restarting the router then it jumps to 11[/quote]
    Why is router restarted (do you mean rebooted) does router reboot automatically after setting are applied ?
    #13768
    Avatardwskittles
    • Replies 12
    was re doing my settings because i pressed the reset button on the back of the router.
    #13770
    [quote quote=13768]was re doing my settings because i pressed the reset button on the back of the router.[/quote]
    I see, so if you SNR is currently 11dB and you set your Stability adjustment to -6, does that hold  and show your new SNR to be 4dB ?
    #13771
    Avatardwskittles
    • Replies 12
    correct but it still says 11db
    dlm is just doing its job
    #13772
    Shame
