Viewing 15 posts - 256 through 270 (of 712 total)
  • #13608
    AvatarTrainzer
    • Replies 17
    Thanks UK Sentinel! Appreciate it!
    #13609
    • Replies 8,689
    Ok, so I have had feedback from ASUS and they have asked if you could run the check firmware option again and then afterwards send another feedback form with (UK Sentinel) in text , let me know when you have completed this task so I can chase .
    Such fun
    #13610
    AvatarTrainzer
    • Replies 17
    <p style=”text-align: right;”>
    </p>
    <p style=”text-align: right;”>Ok, so I have had feedback from ASUS and they have asked if you could run the check firmware option again and then afterwards send another feedback form with (UK Sentinel) in text , let me know when you have completed this task so I can chase . Such fun <noscript></noscript>
    Done!
    #13613
    • Replies 8,689
    Did the check firmware option fail again ?
    #13614
    AvatarTrainzer
    • Replies 17
    I did. Checked for firmware, it failed and then I sent feedback.
    #13615
    • Replies 8,689
    #13707
    Black Bird
    • Replies 146
    any idea what the Stability Adjustment setting does?
    SNR Margin Tweak: Better quality lines can provide higher connection speed.
    only works for adsl ?
    Asus has released a narrative about this.
    https://www.asus.com/support/FAQ/1046037
    9.0.0.4.386_13831 was first tested in beta and VDSL SNR Tweaking is now active. The recently tested version 9.0.0.4_386_13892 (beta) or higher will be available in a very short time as a firmware, a Broadcom DSL device AX82U as I mentioned earlier VDSL SNR Tweaking is active.
    #13708
    • Replies 8,689
    @black-bird – have you managed to make this option work for VDSL ?
    #13718
    Black Bird
    • Replies 146
    Yes, it works on beta firmware that I mentioned in the previous message, I only experienced it in 9.0.0.4.386_13831 firmware.
    At the first stage, the SNR was selected directly, but 2 dB was more connected. For example, 2 dB is selected and 4 dB is connected. Then they changed this part and you can choose a dB according to the default link – and + . When a new official firmware update arrives, it will work as shown in the statement on the ASUS page.
    #13719
    Avatardwskittles
    • Replies 12
    any chance of sharing the beta firmware or can i ask asus?
    #13720
    • Replies 8,689
    @black-bird – Great news and thanks for letting us Know
    #13721
    AvatarSix
    • Replies 55
    Hi
    Got a friend looking for a recommendation to replace ISP box of crap.
    Is the DSL-AX82U any good? This will need to be handed over to a non techy so is it stable?
    Thanks in advance……
    #13725
    • Replies 8,689
    Had a chat with ASUS and they have kindly allowed me to share the beta that @black-bird was refereeing to that now supports VDSL Stability Adjustment
    Note: usual UKTH ASUS Beta Firmware terms still apply
    (DSL-AX82U_9.0.0.4_386_13831-g7ade778_cferom_puresqubi.w)
    DSL-AX82U_9.0.0.4_386_13831-g7ade778_cferom_puresqubi.w (856 downloads
    #13727
    Black Bird
    • Replies 146
    Had a chat with ASUS and they have kindly allowed me to share the beta that @black-bird was refereeing to that now supports VDSL Stability Adjustment Note: usual UKTH ASUS Beta Firmware terms still apply (DSL-AX82U_9.0.0.4_386_13831-g7ade778_cferom_puresqubi.w) DSL-AX82U_9.0.0.4_386_13831-g7ade778_cferom_puresqubi.w (3 downloads)
    DSL-AX82U_9.0.0.4_386_13892-gf9b01b6_cferom_puresqubi.w  Is it possible to access firmware version numbered ?
    #13731
    • Replies 8,689
    @black-bird – Did you have access this version (version 9.0.0.4_386_13892) already ?
