Viewing 15 posts - 331 through 345 (of 714 total)
  • #14741
    • Replies 8,738
    AvatarNessuno
    • Replies 11
    A new beta has been released, DSL-AX82U_9.0.0.4_386_45519-ga7b82a1.
    #15031
    • Replies 8,738
    Great news, I will ask ASUS for a link also
    #15032
    AvatarNessuno
    • Replies 11
    [quote quote=15031]Ottime notizie, chiederò anche ad ASUS un link <noscript><noscript></noscript>[/quote]
    You can get it from here:
    https://k2s.cc/file/ffe7cbb4aa5ba/DSL-AX82U_9.0.0.4_386_45519-ga7b82a1_cferom_puresqubi.w.7z
    Bye
    #15033
    • Replies 8,738
    That is a members (registration) site –
    But thank you for sharing
    #15048
    • Replies 8,738
    [quote quote=15030]A new beta has been released, DSL-AX82U_9.0.0.4_386_45519-ga7b82a1.[/quote]
    Ok, so I had feedback from ASUS and for that firmware release – there is a known ASUS DDNS/Let’ Encrypt issue in this version.
    So it will not be an official beta version that is released
    #15049
    AvatarEl3rt1cal
    • Replies 33
    Are there any details on what it does do?
    #15050
    • Replies 8,738
    This is the changelog I received for that release – unsure how many overlap with previous releases … (DSL-AX82U_9.0.0.4_386_45519-ga7b82a1)
    Security Fixes and Improvements:
    – Fixed Busybox CVE-2016-2148, CVE-2016-6301, CVE-2018-1000517, CVE-2015-9261, CVE-2016-2147, CVE-2018-20679, CVE-2019-5747.
    – Fixed Lighttpd CVE-2018-19052.
    – Fixed Linux CVE-2020-14305, CVE-2020-25643, CVE-2019-19052.
    – Fixed lldpd CVE-2020-27827.
    – Fixed Avahi CVE-2017-6519.
    – Fixed hostapd CVE-2021-30004, CVE-2019-16275.
    – Updated cURL to 7.78.0.
    – Updated OpenVPN to 2.4.11.
    – Fixed wpa_supplicant CVE-2021-30004, CVE-2021-27803, CVE-2019-11555, CVE-2019-9499, CVE-2019-9498, CVE-2019-9497, CVE-2019-9496, CVE-2019-9495, CVE-2019-9494, CVE-2017-13086, CVE-2017-13084, CVE-2017-13082, CVE-2016-4476, CVE-2015-8041
    – Fixed DoS vulnerability from spoofed sae authentication frame. Thanks to Efstratios Chatzoglou, University of the Aegean, Georgios Kambourakis, European Commission at the European Joint Research Centre, and Constantinos Kolias, University of Idaho.
    – Fixed envrams exposed issue. Thanks to Quentin Kaiser from IoT Inspector Research Lab contribution.
    – Fixed dropbear brute-force protection.
    – Fixed httpd stack overflow.
    Bug Fixes and Improvements:
    – Updated WiFi version to 17.10.157.2802.
    – Fixed and enhanced AiMesh/Guest network/Bandwidth Limiter related issues.
    – Fixed Instant Guard IKEv2 profile virtual subnet issue.
    – Added httpd IPv6 support.
    – Fixed fail to surf internet after connecting with IG server.
    – Fixed AiCloud related bugs.
    – Added Hostname in LAN DHCP server Manually Assigned IP List.
    – Fixed OpenVPN server TAP + DHCP related issue.
    – Fixed VPN client cannot access USB HDD on AiMesh node.
    – Updated WAN bridge to LAN if not setting STB port.
    – Fixed to limit the size of the IPSec log file.
    – Fixed mtd erase issue if there are badblocks.
    – Updated some WiFi parameters.
    – Fixed watchdog crash in certain case.
    #15299
    Black Bird
    • Replies 146
    • It would be so much better if AURA RGB had a time program. there is only the manual on and off option. I see that some users only want to use AURA RGB at night.
    • We can turn my notification LEDs on or off via the mobile app, but we can’t do this through the WEB interface, it directs us to press the hardware key.
    #15301
    • Replies 8,738
    That would be a nice option, send a feedback form and request this option, miracles might happen
    #15442
    AvatarAdnan008
    • Replies 10
    Here is another link for DSL-AX82U_9.0.0.4_386_45519-ga7b82a1
    https://ufile.io/lcar2kvy
    #15443
    • Replies 8,738
    [quote quote=15442]Here is another link for DSL-AX82U_9.0.0.4_386_45519-ga7b82a1 https://ufile.io/lcar2kvy[/quote]
    #15444
    AvatarAdnan008
    • Replies 10
    btw sorry for messaging back to back but while researching latest beta, found newer one
    DSL-AX82U_9.0.0.4_386_45659-g5af6269
    https://asus-my.sharepoint.com/:u:/p/sam_wen/ET2osIXCEEROpfXK8iACF9EBX65ooFrCi4DgLAjWgMpTEw?e=5EtQTu
    MD5: 8cd3e51b49825ae23b975cf057d95560
    changelog, according the forum post, obtained from taiwan channel
    – Updated some Ethernet WAN UI settings.
    – Fixed Open NAT Enable button.
    seems like only changes from older beta (DSL-AX82U_9.0.0.4_386_45519-ga7b82a1) are those:
    “- Updated some Ethernet WAN UI settings.
    – Fixed Open NAT Enable button.”
    #15448
    • Replies 8,738
    Good find
    #15596
    AvatarNessuno
    • Replies 11
    New official firmware available 3.0.0.4386_45660.
    https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AX82U/FW_DSL_AX82U_300438645660.zip
    ASUS DSL-AX82U Firmware version 3.0.0.4.386.45660
    Bug fixes and Improvement:
    – Minor GUI bug fixes.
    MD5: 28d71f7382571a5c6fe2d8f2c76d283a
    Bye
