- This topic has 713 replies, 37 voices, and was last updated 2 weeks, 5 days ago by
September 29, 2021 at 10:28 am #15598
Great news, no mention in changelog with regards to the DDNS/Let’ Encrypt issue they did have, so hopefully all working as expected
Any issues then tell me so I can inform ASUS .
October 2, 2021 at 3:29 pm #15624The updated OpenVPN version together with the apparent ability to have simultaneous vpn tunnels and set policies to determine which lan devices use which tunnels seems useful.
I imagine there are processor and performance overheads, but presuming the ability to use no tunnel at al is part of it, that could presumably avoid double tunnels with devices that have their own vpn client software permanently active
October 2, 2021 at 3:47 pm #15625Good to know – VPN’s love eating CPU resources – the VPN feature does sound very simular to what ASUS use in there GTX gaming routers (vpn fusion)
October 2, 2021 at 7:22 pm #15626The GUI interface looks exactly the same as the GTX VPN help, so I guess it is the same. With just one VPN tunnel it seems OK in terms of resource use, but it will be interesting to see what adding another concurrent one does. All in all though I am happier with this Modem / router than any I have had for years.
October 2, 2021 at 7:26 pm #15627[quote quote=15626]The GUI interface looks exactly the same as the GTX VPN help, so I guess it is the same. With just one VPN tunnel it seems OK in terms of resource use, but it will be interesting to see what adding another concurrent one does. All in all though I am happier with this Modem / router than any I have had for years.[/quote]
Interesting, what is CPU /RAM usage with just one VPN running ?
October 3, 2021 at 9:18 pm #15649From 67% ram use to 69%. FWIW from memory both figures are better than it has been previously, however the device has only been up for 24 hours or so.
It is is really difficult to gauge CPU use as core use fluctuates, so there is a health warning with these numbers. With an 8Mb/s BT download of a Linux distro and None or an OpenVPN tunnel:
5% or less increase on baseline core 1 use and 5% typically to 10% max occasionally on the other cores. (core 1 peaking at 90 in both cases, core 2 and 3 getting up to 25% at most but typically fluctuating between 3 and 14.
All in all it does not seem like either CPU or memory are stretched by running a single tunnel.
October 4, 2021 at 6:30 am #15650Does sound like the DSL-AX82U is not being over utilised with a single VPN, so 2 x VPN’s would be interesting ;-)
October 5, 2021 at 6:14 pm #15665Hi everyone,
I just took a VDSL2 subscription in Belgium via EDPNET and I would like a very good modem router to replace my Fritz!Box 7530. The modem router will be in my garage and the wifi will be disabled, there will only be 3 game consoles connected to it (Xbox Series X, Series S and PS5) I want a modem router specially made for gaming to ensure the best latency possible.
Do you recommend this DSL-AX82U?
October 5, 2021 at 7:57 pm #15666The DSL-AX82U with Stock firmware works OK, for gaming but QOS I have found to be not ideal
THe DSL-AX82U is supported by a third party firmware called GNUton and this has CAKE QoS, I have used this and it is very good at reducing buffer bloat and latency if set up correctly
Is there a reason why you want both a modem and router in one device as a separate modem a router for gaming gives you more choices ?
NETGEAR XR500 or XR1000 with Geofilter
October 5, 2021 at 9:04 pm #15667Fine for gaming. As you would be moving from a single box solution it would have the benefit of simplicity. Asus also seem to be supporting the firmware quite well.
As UK Sentinel said however a two box solution might be better. Depends on what you need or would like overall and what would be OK for you in terms of price
October 6, 2021 at 11:58 am #15681Modem + router is ok. I have a fritzbox 7350 actually. It doesn’t have bridge mode but pppoe passthrough.
No limit for pricing.
I don’t need wifi (it was deactivated) i need best router option for gaming only
October 6, 2021 at 1:32 pm #15683Using Fritz!Box in PPPoE pass through then all you need is Gaming router.
- ROG Rapture GT-AX11000
Triple-level Game Acceleration – Accelerate game traffic every step of the way – from device to game server.
1.8GHz quad-core CPU and 2.5GBase -T port for ultimate performance.
2. Netgear XR1000 or XR500
1.5GHz Triple-Core Processor
GeoFilter
Ping Heatmap
3. TP-Link Archer GX90 AX6600 or DSL-AX82U (GNUton Firmware)
I would put the Netgear XR1000 / 500 in first place as I own the XR500 and the GeoFilter and Ping Heatmap gives you very good information regarding gaming servers location and distances etc. alas the Firmware updates are poor quality and delayed currently, hence second place.
October 6, 2021 at 3:21 pm #15688Why not consider the asus ax89x which seems to be the replacement for the ax1100?
October 6, 2021 at 3:27 pm #15691[quote quote=15688]Why not consider the asus ax89x which seems to be the replacement for the ax1100?[/quote]
The ASUS RT-AX89X has an internal fan which is always a worry !
Best for Gamers : ASUS GT-AX11000
Best for Power Users – ASUS RT-AX89X
Source: https://consumerreviews.store/asus-rt-ax89x-vs-gt-ax11000-differences/
October 6, 2021 at 3:49 pm #15692 -
