- This topic has 711 replies, 37 voices, and was last updated 14 hours, 56 minutes ago by
El3rt1cal.
June 22, 2021 at 9:50 am #14023
Thanks Again
Feedback has been sent with what you also requested – UK etc etc mentioned
June 22, 2021 at 11:21 am #14030June 22, 2021 at 4:27 pm #14034Hi – been trying to track the definitive comments on this post as to whether the Asus DSL-AX82U works with BT G.Fast (or not) and if not why not? (Amazon indicated it did….already purchased and WiFi is super-quick but cannot get it to replace the BT Homehub
)If not compatible, any other suggestions for a WiFi6 modem/router which DOES work with BT G.Fast (I am on 250mbs)
thanks
June 22, 2021 at 5:00 pm #14035Alas the DSL-AX82U does not support G.fast – it does support super vectoring, but that is a different standard.
If you have already purchased the DSL-AX82u and you have G.fast access, then that is most unfortunate and I would return the DSL-AX82U or purchase a separate G.fast modem (Vigor 166) and use the DSL-AX82U as a router only
June 22, 2021 at 5:22 pm #14036OK thanks VM – finally some clarity !! If I wanted to broadcast a separate WiFi6 channel from the modem (planning on Asus AIMesh for the rest of the house), is there anything else that works with G.Fast? I had seen a previous list but these were all WiFi5?
June 22, 2021 at 5:38 pm #14037ASUS DSL-AC88U supports G.fast, but that model is no longer supported.
If you can return the DSL-AX82U – I would purchase the Vigor 166 modem (BT Approved) and then purchase say the ASUS RT Ax86u router or simular that will support AiMesh and all the AiMesh nodes etc. and G.fast is supported by the Vigor 166
Alas there is no wifi 6 modem / router (all in one device)Â that also supports G.fast DSL currently I believe.
Wifi 5 (AC) is still very respectable
August 6, 2021 at 5:55 pm #14579There has been a new fw update but it includes a simple improvement. The IPv6 internet problem persists.
3.0.0.4.386_43600
2021/08/06Â Â Â 53.35 MBytes
ASUS DSL-AX82U Firmware version 3.0.0.4.386_43600
1. Fix GUI issue.
2. Fix bugs during setup wizard.Please unzip the firmware file first then check the MD5 code.
MD5: 4fe1bf2879516744926b33d60d799de2https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AX82U/FW_DSL_AX82U_300438643600.zip
August 6, 2021 at 6:00 pm #14581There has been a new fw update but it includes a simple improvement. The IPv6 internet problem persists.
August 7, 2021 at 5:20 am #14582C’è stato un nuovo aggiornamento fw ma include un semplice miglioramento. Il problema Internet IPv6 persiste.
<noscript><noscript>
</noscript>ASUS DSL-AX82U Firmware version 3.0.0.4.386_43563
Security Fixes:
– Fixed XSS on login page.
– Fixed Buffer Overflow issue of httpd.
Bug Fixes:
– Fixed and enhanced AiMesh/Guest network related issues.
– Added AP mode support.
– Fixed sometimes ipv6 not work.
– Fixed IPTV not apply correctly.
– Update DSL diagnostic to capture training data.
– Fixed Parental Control not work when Network Service Filter is enabled.
– Fixed PPTP/L2TP client not start automatically.
– Fixed internet connection issue if setting LAN DNS in WAN.
– Fixed stability adjustment not work for VDSL2.Security Fixes:
Bug Fixes:
– Fixed stability adjustment not work for VDSL2.Bye from Italy
August 7, 2021 at 4:20 pm #14585I install and try all the firmware that comes out, the problem persists.
result on a different modem
https://i.ibb.co/fX3dG2W/zte1.jpg
https://i.ibb.co/dpt7XzR/zte2.jpg
these results belong to DSL AX82U
https://i.ibb.co/z8Krzk9/asus1.jpg
https://i.ibb.co/Yf4g2jn/asus2.jpg
August 7, 2021 at 4:22 pm #14587Are you ipv6 /64 ?
If you send feedback form and detail UK Sentinel in comments box – and explain issues, I can chat with ASUS next week
Let me know if you do this and when Feedback form was sent .
August 8, 2021 at 9:22 am #14593Are you ipv6 /64 ? If you send feedback form and detail UK Sentinel in comments box – and explain issues, I can chat with ASUS next week
<noscript>
</noscript>Let me know if you do this and when Feedback form was sent .Yes, ipv6/64
I just submitted a feedback with some explanation and included your name as well.You need to login in order to vote
August 8, 2021 at 9:32 am #14597Yes, ipv6/64 I just submitted a feedback with some explanation and included your name as well.
August 18, 2021 at 7:38 am #14735I have spoken with ASUS this morning and alas still no update / resolution as to the IPv6 issues wit the DSL-AX82U
I will keep chasing
August 18, 2021 at 3:55 pm #14740Thank you, ASUS has returned by e-mail and I’m sending answers according to questions.
It’s a strange problem and I think the modem doesn’t seem to be insisting on connecting again after the pppoe timeout. ipv4 works after a while, but it does not allow internet output, although ip addresses are assigned ip to ipv6 wan and local devices.
