- This topic has 709 replies, 37 voices, and was last updated 1 day, 2 hours ago by
October 10, 2022 at 7:01 am #21166
I have other local user near me same with DSL-AX82U and he has DNS Query under Network Monitoring turned off and 0 problems.
Good to know and interesting that DNS Query was issue, let us know if this does fix problem after a few more days ?
October 13, 2022 at 5:53 pm #21232October 13, 2022 at 8:28 pm #21236I encountered an interface problem. I uploaded the screenshots. There is also problem with different web browsers.
Is the issue the Antenna Scheme not showing and the Aura RGB Enable button not visible ?
Can you advise which browsers work correctly, and which ones do not ?
October 14, 2022 at 10:46 am #21249Nothing works in the area in the screenshot. Problematic in all browsers (I tried EDGE, Firefox and Opera).
For example, I can’t turn it on in the Aura RGB off position.You need to login in order to vote
October 14, 2022 at 1:39 pm #21253Remind me if you can which Firmware you are currently running, I can then let ASUS know 👍
October 14, 2022 at 4:50 pm #21255Current Version :Â 9.0.0.4.388_21184-g44bd437
The interface is locked when I want to look at the traffic data (http://router.asus.com/TrafficAnalyzer_Statistic.asp). I was able to access the traffic menu after the restart, but the aura RGB is still problematic. Aura RGB settings cannot be done in the mobile app. The same problem on the WEB page also appears in the mobile application.
October 14, 2022 at 5:52 pm #21260I will let ASUS know 👍
October 30, 2022 at 9:10 am #21483I have the same problem. I think it is a general issue for firmware 9.0.0.4.388_21184.
October 30, 2022 at 9:40 am #21484I have the same problem. I think it is a general issue for firmware 9.0.0.4.388_21184.
If you can send ASUS a Feedback form via UI, I am sure this will help ASUS with this beta 388 build, if you mention ‘UK Sentinel’ in description box, this should help
Good to know and interesting that DNS Query was issue, let us know if this does fix problem after a few more days ?Everything is perfectly fine.
November 1, 2022 at 5:13 pm #21502Everything is perfectly fine.
Thanks for letting us know
November 19, 2022 at 5:55 am #21711Hey guys,
I just purchased dsl-ax82u, its on the latest stable firmware 3.0.0.4.386_49608. I had dsl-ac52u before. I have a very noisy and unstable connection so I thought having a modem with a broadcom chipset might help.
I live in Turkey, so the standard here is annex a, which is my old dsl-ac52u was using. But on dsl-ax82u it sync ups with annex b and there is no way to change it. Also my dsl speed is worse when compared to my old modem, not sure if this is related to the annex thing. I sent a feedback to Asus but I wonder is there any workaround for this?
Thanks!
November 19, 2022 at 7:42 am #21715Welcome, you do seem to have a high CRC errors, which is not good and indicates a faulty line etc.
With VDSL, Annex A or Annex B are the same and does not really matter and is not changeable for the DSL-AX82U.
How much synch rate (speed) have you lost ?
November 19, 2022 at 8:25 am #21716Hey,
Yeah, I have lot of CRC errors, currently I can’t fix it because it is related to the lines on poles and my isp is refusing to fix it and I don’t have authority to replace the line on the poles. The lines are also very close to the naked electric lines, currently I’m trying to force them to move the line.
On ac52u: Snr margin: 8, line att: 15.1, max rate: 56000, current rate: 42000
On ax82u: Snr margin: 8, line att: 23.6, max rate: 33000, current rate: 35000Also I was enabling g.vector and non-standard g.vector on my old modem but ax82u lack those settings in dsl tweaking.
November 19, 2022 at 8:44 am #21718Under Administration > DSL Settings, can you show us a screen dump (image) of page settings ?
