Viewing 15 posts - 541 through 555 (of 714 total)
  • #21834
    • Replies 8,726
    Big improvements in line synch rate and no CRC’s, try not to reboot DSL-AX82U as this can cause issues with line synch rate (speed) as cabinet thinks issue with line and may increases interleaving and reduces synch rate (speed) etc.
    If you leave alone for a week and let us know if synch rate changes after 7 days ?
    Hopefully no rain in next 7 days
    #21837
    Avatar06f82
    • Replies 12
    Thanks! I’ll let you know after 7 days. I don’t think it will get affected by rain in short term, but in 6-12 months I expect it to cause some issues.
    #21891
    Avatar06f82
    • Replies 12
    [quote quote=21834]Big improvements in line synch rate and no CRC’s, try not to reboot DSL-AX82U as this can cause issues with line synch rate (speed) as cabinet thinks issue with line and may increases interleaving and reduces synch rate (speed) etc. If you leave alone for a week and let us know if synch rate changes after 7 days ? Hopefully no rain in next 7 days<noscript></noscript>[/quote]
    Hey,
    The values were same for 5 days. But I had a different problem, modem restarted itself for no reason. There are some logs about the qos, I sent a feedback to asus with full logs. I’m using the adaptive qos feature. Maybe I should try the merlin for QoS:
    https://gnuton.github.io/asuswrt-merlin.ng/
    Here are the logs:
    Nov 30 21:15:00 rc_service: ntp 3342:notify_rc restart_diskmon Nov 30 21:15:00 rc_service: waitting “restart_wan_line 0” via wanduck … Nov 30 21:15:02 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 54:48:E6:B8:CF:36, status: 0, reason: Previous authentication no longer valid (2), rssi:-52 Nov 30 21:15:02 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 54:48:E6:B8:CF:36, status: 0, reason: Previous authentication no longer valid (2), rssi:-52 Nov 30 21:15:03 BWDPI: fun bitmap = 83 Nov 30 21:15:03 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 54:48:E6:B8:CF:36, status: 0, reason: Disassociated due to inactivity (4), rssi:-52 Nov 30 21:15:04 A.QoS: qos_count=0, qos_check=0 Nov 30 21:15:04 kernel: [ 137.615961] ERR[parse_qos_conf:939] Can’t set new QoS conf while QoS is started! Nov 30 21:15:04 kernel: [ 137.623574] ERR[ioctl_iqos_op_config:3608] parse qos_conf error!! Nov 30 21:15:04 kernel: [ 137.630107] ioctl_iqos_op_config() fail! Nov 30 21:15:04 A.QoS: set_qos_conf fails Nov 30 21:15:04 A.QoS: restart A.QoS because set_qos_conf / set_qos_on / setup rule fail
    #21895
    • Replies 8,726
    probable the same issue will be with @GNUton also – has the line synch rate remained good after reboot ?
    Maybe just a one-time problem,  if it happens again then we know it is more important problem .
    #21897
    Avatar06f82
    • Replies 12
    Yeah it is good after the restart. I get 2-3 crc per hour which can be caused by the part of the old line they did not replace.
    One thing I noticed is when it is night snr margin drops to 13.1 and jumps back to 13.6 after morning every day. Something probably interferes with the signal. It is not the street lamp that close to my cable because it drops hours after lights on. It does not affect my speed but an interesting thing.
    I’m also trying to get fiber connection to my house from my neighbors backyard (his road has the fiber line, since he permits it isp will provide a gpon to me if I pay the costs) so hopefully I will not need the old cable anymore but we will see.
    #21901
    • Replies 8,726
    [quote quote=21897]One thing I noticed is when it is night snr margin drops to 13.1 and jumps back to 13.6 after morning every day. Something probably interferes with the signal.[/quote]
    SNR can change a little during the day and night so not uncommon but great news about possible fiber connection in the future and should be much better than you current DSL line
    #22099
    Avatarvitt13
    • Replies 45
    Asus GUI showing new firmware
    #22100
    Black Bird
    • Replies 146
    [quote quote=22099]Hi all, Asus GUI showing new firmware<noscript></noscript>[/quote]
    Thanks, I was able to upgrade directly to the beta version I had installed.
    3.0.0.4.388_22048-gf313579
    Security Fixes and Improvements:
    – Update OpenVPN to 2.4.12 for CVE-2022-0547.
    – Update strongswan to 5.9.8 for CVE-2021-45079, CVE-2022-40617.
    – Fixed status page HTML vulnerability. Thanks to David Ward.
    – Fixed busybox CVE-2022-28391, CVE-2021-42386, CVE-2021-42384, CVE-2021-42382, CVE-2021-42383, CVE-2021-42379, CVE-2021-42380, CVE-2021-42385, CVE-2021-30065.
    – Fixed dropbear CVE-2019-17362.
    – Updated cURL to 7.84.0.
    – Updated libexif to 0.6.24.
    – Fixed ntp libevent: CVE-2016-10195, CVE-2016-10196, CVE-2016-10197, isc: fix CVE-2018-5743, CVE-2012-3868
    – Updated ffmpeg to version 4.4.2.
    – Fxied open redirect vulnerability of web page.
    – Updated libssh2 to version 1.10.0 for CVE-2019-17498.
    – Fixed cfg_server security issue.
    – Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    New Features:
    – Supported WireGuard VPN server and client.
    – Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
    – Supported new devices connection notification.
    – Supported connection diagnostic on the ASUS router app.
    – Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
    – Upgraded parental control and added reward, new scheduler for flexible setting.
    – Supported Auto USB Backup WAN.
    Bug Fixes and Improvements:
    – Enhanced OpenVPN Client profile parser to support option “ignore-unknown-option”.
    – Enhanced DDNS to select method to register IPv4 address automatically.
    – Updated DSL PHY to A2x028b, A2pv6L047k by default.
    – Added DDNS HE.NET support.
    – Fixed and enhanced AiMesh related issues.
    – Updated OOKLA to 3.8.0.
    – Fixed dhd TRAP type 0x4 @ epc 0x39792 case.
    – Fixed 5G 160MHz download throughput issue.
    – Fixed Block-ACK transmission power have chance to over expectation.
    – Added iPhone USB tethering connection support.
    – Updated default timeout of DNS query in Networking Monitoring .
    – Fixed possible crash issue while using OpenVPN.
    – Disabled insecure DSS support of SSH server.
    – Fixed IPv6 firewall issue when enabled IPv4 Firewall.
    – Fixed the device list on the left side of Web AiCloud cannot correctly display connected devices.
    – Fixed Windows 10/11 (22H2) client cannot establish connection with IPsec VPN server.
    – Enhanced IPSec server to support packet size exceeds 32K bytes.
    – Fixed httpd login lock time issue.
    – Fixed memory leak issue of conn_diag.
    MD5: 8197deaeaf130372c0de6cb3e89625df
    https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AX82U/FW_DSL_AX82U_300438822048.zip
    #22102
    • Replies 8,726
    Black Bird
    • Replies 146
    It tells me I don’t have an Internet, so some features are disabled. I can send this message, I have an Internet, :) The beta didn’t have this problem, but it did occur in the full release.
    I can’t access my Internet through the access point that I put upstairs in addition to the ones above
    Problem Solving: Turn off “Network Monitoring > DNS Query”
    Avatarvitt13
    • Replies 45
    all working fine from my side, try to reboot..
    #22108
    Black Bird
    • Replies 146
    When I returned to the old beta software, the problem persisted again.
    The problem starts when IPv6 is turned on, I turned off this feature and it was fixed.
    #22109
    • Replies 8,726
    IPv6 Issue, interesting to see if others have this problem also ?
    #22110
    Black Bird
    • Replies 146
    I set it up again by taking it to the factory settings, there is a problem.
    #22114
    • Replies 8,726
    [quote quote=22110]I set it up again by taking it to the factory settings, there is a problem.[/quote]
    If you start a new thread, we can work through a few options and I will plug in my DSL-AX82U tonight and see if there are any issues with IPv6 from my connection ?
